Question about Coleman Powermate Premium Plus 6250W Portable Generator
It's 4 yrs old but only started once, the day i bought it. it started hard first and only time it ran. ran it out of gas and it has been stored. checked oil, ok. added new gas, pulled and checked plug. removed filter for easier start. bought ether easy start but can't get to carb. pulled cord 50 times with choke fully on, partially on and off. no start. some suggestions plz. the manual is VERY basic and not much help
    Scholar:
  • 54 Answers
After four years the magneto will become demagnetized. Get a small magnet and find the spot on the flywheel where there is some steel which will be slightly magnetic. You can just stick it on there for four days or work it and tap it lightly on the steel for many minutes. Two hours should be enough to get it started and from there it becomes very strong as it revolves past the magneto's steel core. They use to use Strontium alloy to make it keep it's magnetism but they are cheaping out on all steel alloys now. When you can get it to draw in a steel bolt or some other ferrous item so it goes clack against the flywheel, then you have it ready to fire. If it has a compression release, make sure that is all the way over to start, then when it fires bring it back towards you to get full power. I left mine without gas in stroreage for two years and it just barely started. I pushed the plug-in GFCI center buttons a few times and it came to life.
Posted on Apr 10, 2011
My six year old chainsaw won't start?
If it ran before you stored it and you left gas in it, you can thank ethanol for your troubles.Try fresh mixed gas with a heavy does of ethanol treatment or Seafoam in the tank, prime it and try to start it 10 times, then let it soak for a few days and try again. Good luck
Apr 03, 2015 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Generator is two yrs old only had a couple of outages maybe totaling thirty hrs Generator ran great and also ran every wk for its exerciser cycle. The generator didn't start on this cycle and the system...
Is this a natural gas fueled generator? Sounds like a fuel problem, i would go through the fuel system and find out whats wrong. If its a natural gas/propane unit its most likely a bad regulator or low pressure.
May 04, 2017 | Eaton Electrical Supplies
Honda gas power pressure washer runs for awhile then cuts off.
did you pour all of the old gas out before you started to use it. Sometimes condensation builds up in gas tank when stored. You need to dump old gas an put in new gas.
Jul 27, 2009 | Honda Karcher G4000RH Pressure Washer
Are the 1988 Johnson vro oil injection system dependable?
the older ones are dependable but they all exspecly being that old its better to be safe than sorry its if it were mine i would mix the gas thats what i tell all my coust the 90 thr 1999 omc vro were terrible the fill the carbs full of oil so i would just mix it that way u know its right just use good oil and that engine will last a very long time good luck
Jul 07, 2009 | Boating
My husqvarna chain saw won't start.... i brought it new,, used it a dozen times (light work) and storeds it for about 2 yrs.. got it out the outher day and could not get it to crank...
The oil and gas is probably bad if it was stored with them. I would change out the oil and gas and try then. If it still doesnt start change out the spark plug. SHould start right up after its primed.
Jun 15, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
My 1993 ford f-150 is backfiring and hard to start
Sounds like your timing is off. Try having your timing reset. and new timing chain.
Mar 16, 2009 | 1999 Chevrolet Blazer
Bad running craftsman 25cc trimmer 4 yrs old
You need to do a couple of things to get your trimmer back on track. First of all pour out the old gasoline and get rid of it. Then remove the spark plug and go to an auto parts store and get a new one just like the old. If you have your manual, check to see what the recommended spark plug gap is gap it to that specification.
Finally remove the air filter and clean it or replace it as necessary.
Once that is all done, but some new, fresh gasoline. Then put in the new plug and the new gas and u will be good to go. please rate this answer as a FixYa cause it is.
Feb 25, 2009 | Craftsman 25cc Gas Line Trimmer
Coleman Powermate Premium Plus 6250W Portable Generator Logo
184 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
