Question about Kenmore Side by Side Refrigerator
On my kenmore fridge the inside plastic panel that goes on the door is broken what to do? how to replace?
  • Kenmore Master
  • 2,128 Answers
Sall your parts store,give them the model number,tell them what part you need and they will give you a price for the part,you'll have to decide if you want to fix it or change out the machine depending on how old it is and if it's worth repairing.next time send the model number.
Posted on Apr 09, 2011
Past couple days the refrigerator side is freezing everything. turned the setting all the way back and still freezing......dont know if there is a thermostat and if its a DIY fix
Damper door is either broken, stuck open or stuck open and frozen with ice. Damper door is located in the top left corner of the "refrigerator side" of the fridge. Damper door may be concealed by an outer plastic covering usually held in place by a 1/4 inch screw.
Thanks and let me know if that helps,
Tips Provided by: www.HoustonRefrigeratorRepair.com Brian Gillespie GOFAR Services, LLC
Aug 26, 2011 | Kenmore Side by Side Refrigerator
The water line in my Kenmore side by side fridge broke in the door how do i remove the inside panel to replace the line??
It's a shot...but if I recall correctly the rubber seal thats between the door and the fridge can be peeled back or removed, and underneath are the screws that hold the inside panels on...
I would peel the seal back a little at a time until I actually locate a screw...then once located... I would feel more confident about the removal of the entire seal. Keep in mind the seal is much easier to remove than to replace...I used baby oil in some place to replace the seal...Good Luck!
Dec 20, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a Kenmore 500 that shuts off if the load touches the door from the inside or wont start unless I press the door in again after its shut. I'm assuming there is a safety switch the door touches to let...
sounds like the door catch is loose,this is what holds the door shut,when the clothes are spinning they hit the door opening it enough to reset the door switch,there's a metal or plastic tab that goes into the catch,easy to install and part is cheap money
Oct 13, 2010 | Kenmore 500 6952 Dryer
Kenmore sidexside light burned out. replaced bulb, won't light.
There is a plastic switch that works the light in the door jam. Unplugg the fridge before popping this plastic switch out. I would order one first but if your light fixture is in good shape and not burn on the inside and the wires look good it is most likely the door switch. The door switch is just like an on off switch for any light its just spring loaded to turn on when the door opens. good luck
Aug 15, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore side-by-side not dispensing ice or water, the ice maker has been replaced, no water going into the tray. I cannot locate the water filter, does this model have one?
Don't know what is the model number of your fridge. 1.Need check electric water valve under the fridge. If that fridge made by GE (Kenmore just a Sears brand name and they use several others manufacturers for refrigeration), usually it's a frozen plastic water supply line inside freezer door. You could unplug fridge for 24 hours (you have to put food from freezer to other freezer).
Jun 29, 2010 | Kenmore 24.5 cu. ft. Side-by-Side...
I have a kenmore top freezer refrigerator model 253 about 1 1/2 years old. The fridge door sticks at the bottom of the door and the bottom of the fridge inside. There are scratches on the fridge bottom...
i had the problem my self :)
you need to take the freezer door out then the fridg door and add small ring like 1mm to the hinges of the fridg door poot all back and see if it rais the door a bit....
what i did is on the top of the freezer there is option to move the door from side to side ...the plastic that go into the freezer body its a ring with long tube.. i cut the tube and use that plastic :) good luck
Jan 03, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
I need shelves for the fridge and the plastic shelf at the bottom of the door is broken and needs replacing.
hi there......you havent stated the manufacturer of your fridge...however obtaining shelves for your fridge should be no problem..provided you have the model and serial number and if possible the product code.(a) contact your local your local domestic apliance repair/spares shop....(b) go online to the manufacturers web site...(c) go on line to google enter your fridge details this will provide you with information where to obtain your parts...
the door shelf may be a different issue...if the shelf is part of the door lining then you will need a relpacemant door
regards Sir Galahad
Aug 13, 2009 | Kenmore 91493 Stainless Steel Compact...
Popping sound from the doors when open and close
door cam broke off or got left off durring reassembly usually black plastic 2 parts 1 on door 1 on hinge some models require replacing the hole hinge put some silcone based lube on new ones
Jul 01, 2009 | Kenmore Refrigerators
Removing water despenser on Kenmore 79575196401 fridge
this is an LG made machine, ther eis no simple way off, youll need to pry it off form the edges, no screws hold it, merely plastic tabs and pressure. I hate this dispensor for this reason , but the dozen or so i removed, i havent broken any yet. pry slowly and youll get it
Jan 10, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Crisper Door broken
Repairclinic.com had the parts I needed (crisper drawer lid and the longer drawer lid.
Nov 17, 2008 | LG LRFD25850 French Door Refrigerator
Kenmore Side by Side Refrigerator Logo
44 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
