New air conditioner. compressor wont start less than 1 yr old Amana
  • 40 Answers
First check to see if contactor is pulling in
if so check you have 230 volts across terminals
if yes check the capacitor
if good check compressor windings
you did not indicate whether to condenser
fan is running
Posted on Apr 11, 2011
House wont cool ..tried to reset breaker in fuse box and breaker outside...this unit is only just over a yr old . the fan thing outdoors is not kicking on..
Does this unit have 2 breakers to it? The model you put down is a PTAC and generally just plugs in to the wall so it would have only 1 breaker. If I recall correctly it's got a 5 year warranty on parts so it may be worth it to check with your local HVAC tech and have them do a diagnostic for you. A good place to start would be Amana who can tell you the authorized service company in your area. They'll get the part for free and should roll the diag fee into the repair cost so you'll only pay for labor (if it even needs a part). Their sales and service number is: 1-800-647-2982. Here's a link to your warranty info:
http://www.amana-ptac.com/Home/Warranty/tabid/449/Default.aspx
May 27, 2010 | Amana PTH123B25AJ Heat Pump Air...
I have a Rudd ultra series 16.0 and I cant get the air to blow hot..I have heat on and "hold at 90" but it wont heat..ac is less than 1 yr old
I am curious if the unit is short cycling. If it is, take the face off of your thermostat and turn the anticipator to .4 and when you can have a tech take an amp draw on your furnace. If it is a new furnace and old thermostat, it may not have been checked with the new install
Jan 05, 2010 | Heating & Cooling
3 ton air conditioner {1 yr. old } has rattle
check tightness of grill on outside of condenser,then push on different areas of the unit to see if sound changes or quits,also check all screws etc. & make sure they're all tight,is so it could be fan condenser motor bearings bad fan loose on shaft
Aug 27, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
1 month old air conditioner wont turn on
Return it for a refund or a repalcement if less than 30 days you can get a replacement at the store.
Aug 19, 2009 | Amana PTH074B35AE Heat Pump Air...
Amana Cooling Condensing Unit fan won't kick on
be aware that not repairing this asap that you are causing yourself more problems First I would change out the fan capacitor and see if this could be the problem. Secondly if the capacitor isn,t the problem change out the motor . By continuing to allow the system to cycle like this the compressor will take a dive on you costing more . Good Luck
Dave
Aug 04, 2009 | Amana PTH123B25AJ Heat Pump Air...
Noisy Amana Quiet Zone air conditioner
The compressor sounds like the springs inside are bad. You can live with this are get the compresor eplaced if it is over five years old buy a new unit. Compressor will cost more than a new unit. Russ
Jul 18, 2009 | Amana Quiet Zone 12M12TA Air Conditioner
COMPRESSOR Amana / RCE24C2A Ser #036142440
mfg date are coded into the ser.# useualy fist 4 digits are yr and month of MFG. 0306 would be 2003 june ect. if in doubt call amanna dealer and ask them. Steve
Jul 12, 2009 | Heating & Cooling
1 yr old 15,000 btu Coleman fan blows compressor not working
The power supply or compressor coil may be faulty. There could be shorted wire, open circuit, bad relay.
Jun 18, 2009 | Dometic Rooftop RV Air Conditioner
Ptac
You need a new control board. The relays go out on these. If your unit is less than a year old then you should still be under warranty. Unless you did not send in the warranty card, then the company only warrants the unit for 1 year after the mfg. date. You will need to provide the serial and part number to find out from Amana. The new control boards are much better by the way, and worse come to worse, they are only $130. Please let me know if this has helped in any way.
Dec 27, 2008 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
37 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
