Question about Craftsman Garden
I have a a 3 year old 32cc craftsman weed eater that runs only with the start lever in the vertical position. As soon as I pull on the throttle it runs for a couple of seconds and dies. I pulled the carburator off of it and it looks pretty clean. I went ahead and sprayed it out with some gumout. I tried adjusting the idle speed but that didnt seem to help. I pulled the plug and it looks ok. I went ahead and replaced the air filter also. Not sure if there is a mixture adjustment or not. There are two black screws in a cavity but I didnt have the proper tool to adjust. The model # is 358.791070. Any ideas?
  • 710 Answers
Hi bstruska,
If the start lever starts only in the vertical position, perhaps there is a loose connection from the switch to the motor. Then when you change the trimmer's position, it could be turning it off.
Did you check the connections?
Just a thought. I hope you find something.
Thanks,
Handie Andie
Posted on Apr 09, 2011
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    Craftsman 32cc gas trimmer won't start.
    Take out the plug and shoot a shot of starting fluid in it replce plug have a can of carb and choke cleaner to help it along until it picks up fuel spray by the air cleaner the carb and choke cleaner
    Jul 21, 2014 | Craftsman Convertible 32cc Gas Line...
    How do i fix a cord not going back in on a craftsman weed eater/blower combo 32cc
    The one way clutch could be broken or jammed. Take off the starter for a closer look.
    May 10, 2014 | Craftsman Garden
    I have a Craftsman 32cc weed trimmer, can't give gas, it stalls
    Usually the diaphram is wore out. It is a relatively inexpensive part. Does it run better with a little choke? If the answer is yes chances are it's the diaphram. Also sometimes the adjustment screws can move. There are two, one for low speed, and one for high. With the engine warmed up make small movements on the screws (some are marked low, and high) in, and out adjust til the engine runs at its optimum.
    Hope this helps!
    May 04, 2010 | Craftsman 25cc Gas Line Trimmer
    Repalce the pull cord a Craftsman Weed eater 32CC
    I have a craftman weed eater model M358.796600 and the pull cord will not retract any more...how do you fix it?
    Drew
    Jul 02, 2009 | Craftsman 25cc Gas Line Trimmer
    Fuel hoses routed wrong on weed eater fuel tank
    http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=358795190&productCategoryId=1503820&brandId=0247&modelName=TRIMMER&diagramPageId=00002&componentDescription=CYLINDER/FAN%20HOUSING/CRANKCASE&documentId=P0303202&backToLink=Return%20to%20Sub%20Components%20list
    Apr 04, 2009 | Garden
    Garden Logo
    64 people viewed this question
    Top Craftsman Garden Experts
    Wade Mobley
    Wade Mobley
    Dean Gruber
    Roland W VanLue
    Roland W VanLue
    Are you a Craftsman Garden Expert? Answer questions, earn points and help others
