Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Whirlpool cabrio top load, has flashing dial and 51? also an F??
    Sergeant:
    Champion:
  • 202 Answers
The F51 error is a RPS (rotary position sensor) board failure where the control board looses contact with the RPS during the machines operation. The RPS uses hall effect sensors to determine the speed and direction of the drive motor, allowing the control board to constantly monitor the motors operation. Because this error is a communication error and not a mechanical error with the motor itself (that would be and F52 error) we can limit our trouble shooting to the three items that make up the RPS circuit, the control board, the wiring harness, and the RPS itself.
Posted on Apr 09, 2011
  • Nathan Van Boven Apr 09, 2011
    Tipping the machine back will reveal the motor directly underneath the tub. The RPS board is mounted on the right side (follow the brown wires) and under the motors rotor disk. An Allen wrench is used to remove the rotor and then the four bolts holding the motor stator to the tub can be removed. Once the motor is out, we can get to the RPS and the wiring harness and do a continuity check on each wire between each end of the harness. If our readings indicate a good harness, we are down to the RPS itself and it would need to be replaced. Of course there is one other thing to do, and that is make sure the connection from the harness to the board is good.
    Many of these boards were manufactured with a clear lacquer being applied to the boards to protect the wire traces, and unfortunately, many of the contacts themselves became covered. This results in a poor connection to the harness connector and provides for an poor intermittent signal to the control board. To repair this unit, I removed the RPS board and using my jewelers file, cleaned the contacts for proper electrical connection. Once everything was reassembled, it ran two complete diagnostic cycles without a hiccup. And now the customer can get some laundry done without restarting the machine.
2 Suggested Answers
SOURCE: Cabrio top load flashing F51
F51 error is a rotor position sensor error.Its a very common error in carbrio washers.heres a website just for this error.Refer for the solution through it.
http://cabriof51error.blogspot.com/2008/01/my-f51-experience-day-7.html
Posted on Dec 15, 2008
When I start the washer the dial flashes and says F1
The "F1" error code on the Whirlpool cabrio is quite common, and generally has to do with the control board. Replacing the control panel may resolve this issue. However, I believe Whirlpool is aware of the F1 issue with the Cabrio, and is fixing some machines for free. Please call 1-800-253-1301 for more details and see if you are eligible for a free repair.
Thank you !!
Aug 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Will not spin code f 51 flash on top
In my opinion you may be using excessive amounts of detergent. This makes the rotary position sensor overheat.
On board intel senses SUDS and built in features work to get rid of it causing the RPS to overheat. Read more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 17, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What is the F51 error code
its the rotor sensor and control bord that need replacing here is a link to help you understat the problem
Jul 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer stops and F 51 flashs
Hello, It is a rotor position sensor code. The control is no longer receiving a signal from the motor. It can be a failed sensor or control, but usually it is a bad connection where the wires plug on to the sensor.
Thanks
Jun 11, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Help
F then 51 flashes when there is a motor rotor position sensor (RPS) failure.
It can also be a defective control board false reporting an error which is common on these models.
Apr 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F-51 code on kenmore elite oasis washer - how to prevent and or fix
Please see the following Whirlpool Cabrio installation and service manual, the Oasis is essentially the same washer.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
The F and 51 code relates to the motor rotor.
"F then 51 flashes when there is a motor rotor position sensor (RPS) failure. See TEST #3."
The "test #3 is a bit complicated but can be completed if you are reasonably comfortable with test equipment.
Oct 20, 2009 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Cabrio washer is giving an F 51 Code
The "F51" error code is common problem with the Cabrio. This is an RPS sensor error. The sensor is mounted along the motor windings under the washer and detects the rotation spin speed. The sensors on these units can go bad, causing the error code, and it has been a frequent problem. I would recommend you contact Whirlpool first (due to the unit only being a year old) and see if there is a recall or upgrade on this part. I believe there is. The repair would then be covered by the manufacturer. If I give you the steps to access and/or replace the sensor at this point, you may be voiding any existing warranty you may still have. Some components carry a longer warranty than your normal one year limited warranty from the manufacturer. Something you may consider.
If you have further questions, please let me know. I hope this helps you in some way.
Jun 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
I have whirlpool cabrio top load flashes f then 51
I had the same problem and Whirlpool will not do a recall on these washers. But FINALLY one day I was so tired of it stopping so often in a few minutes that I called Whirlpool and they said that it was a known problem and will be sending someone to replace the curcuit boards at no charge to me.
So get your manual out and call the Whirlpool people so that they can do the same for you!
Apr 30, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
760 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
