Question about Dryers
Hello, getting an error of F:03 on my WTE86300US Bosch Condensation Dryer. Do you know what the issue is?
  • 2 more comments
  • eposton Sep 08, 2008
    I'm getting the same F03 error as well....can anyone provide any info?
  • geddesbrad Feb 07, 2009
    got the same prob.... now just need to find a site with answers!
  • a87k45kwh522 Mar 09, 2009
    what's the point of this site? read a bunch of questions? bravo, geniuses.
  • rhonda babcock May 28, 2013
    Your pump needs to be replaced. Mine worked if I let down the hose into the bucket and no f03 code, then I pit it back into the drain and got f03 code.called repair man and he said a new pump. so hopefully it will work.
  • 4 Answers
I have owned the same dryer for about a year and just started having this F03 problem. The condensation drain hose is the soft flexible rubber hose coming out of the back of the dryer and it drains into the same drain as a washer. It's easy to pull the hose off its connector at the back of the dryer and just blow hard into it to make sure there's no lint clogging the hose and reconnect it to the dryer. Next open the panel on the left of the dryer and thoroughly rinse (water only, no soap) clean the two parts behind the door (first is plastic and behind that is the condensation filter which probably is loaded with lint). Sometimes the lint in the condensation filter channels (those that run from front to back) can be quite stuck. Use a long pipe cleaner to get in there or a garden hose with a spray nozzle. Shake the excess water out of the condensation filter and dry off the outsides of two parts. Clean all the lint out the compartment where the parts go. There is one more crucial step not mentioned in the manual. Once you remove the condensation filter you will see a small plastic panel on the lower wall of the condensation filter slot. Slide a flat blade screwdriver or a blunt table knife under the panel and gently pop it open. Under the panel is a small chamber that you can't see very well where you will find a slurry of lint/water which is what clogs the condensation outlet. With latex gloves reach in there and clean it out. Use paper towel to get it all out. Blow hard into the dryer through the condensation hose to clear up any last bits. Pop the panel back in place as well as the condensation filter and the plastic part. Take out the lint filter (within the dryer drum compartment) and wash it with soap and water. Use an old toothbrush or something to clean the screens thoroughly. Rinse well and dry it completely. Clean all the lint out of the empty compartment. Put all three parts back into the dryer. Clean all lint off the door. Using paper towel moistened with white vinegar clean the two metal sensors in drum compartment on the front wall and lower left. Run the dryer empty but with heat on for a few minutes to make sure all the water is drained out. Now try drying a load. I think it's a good idea to rinse clean the condensation filter at least once a month since it collects a lot of lint. Hope this works for you.
Posted on Aug 12, 2010
  • 1 more comment
  • maja653 Sep 18, 2010
    awesome advice. just fixed my dryer, yay!!!!
  • bellor01 Dec 19, 2010
    Just an update on my previous suggestions listed above. Eventually F:03 came back and more frequently. The hidden chamber described above had no lint but would fill with water and dryer would give F:03 error. I discovered a small pump that is not documented in any of the user or service manuals. This pump is supposed to empty the chamber via the condensation hose in the back of the dryer. I replaced the pump 2 months ago and the F:03 error has disappeared altogether. If any of you that are technically inclined and wish to replace the pump, it can be purchased from just about any online appliance part store. Search for the pump model number directly (640456) as it will not be found by looking via the dryer model number. I paid around $45 and have seen it as low as $28 on ebay.
  • Rick Bello Jan 25, 2013
    Hopefully the last update on this topic. Several months after replacing the pump the F:03 error returned. I removed the pump once again and looked over things. There was no obvious collection of lint blocking the pump and nothing obviously wrong with the pump. Upon closer inspection I noticed I fine "ring" of gelatinous material around the pump intake. Keep in mind the intake sits just a couple of millimeters above bottom of the hidden chamber. I removed the "ring" and re-installed the pump. The F:03 error was gone again!!! It has since happened a couple more times. Knowing how the pump is situated in its chamber and how to reach the pump and chamber from the front access panel, I am now able to clean out this gelatinous "ring". The easiest tool for this is a wooden coffee stirrer from Starbucks. Simply break it in 2 pieces as it is too long otherwise. Remove the panel behind the condensation filter as above. The pump intake can barely be seen towards the left. Place the wooden coffee stirrer flat on the bottom of the pump chamber. Slide it under the pump intake and sweep it side to side. Remove it and look carefully. You will see some gelatinous material. That stuff is what causes the F:03. Replace all the parts. Hope this works for you. At least if it happens again I won\'t have to take my dryer apart.
Problem above is the exact issue we are having. I havecompleted the 3 steps above and have replaced the pump 3x already. I reallythink this is a flaw in product design. The new pump, hose, etc fixes theproblem for 5-8 months, but the dreaded f:03 comes back with a vengeance. And it'slike clockwork. Used Sears service 3x, the techs are incompetent, I end upputting on a display to them on Bosch appliance repair. Ridiculous. This time I am going to Bosch directly.. Ihave probably spent nearly as much on service appointments than I would have if I chose to replacethe dryer after the first incident occurred nearly 2 years ago. I hope yourexperience turns out better than mine, I don't wish this on anyone. Would have expected this should have prompteda recall, because it's not infrequent.
Posted on Nov 15, 2011
    Hopefully the last update on this topic. Several months after replacing the pump the F:03 error returned. I removed the pump once again and looked over things. There was no obvious collection of lint blocking the pump and nothing obviously wrong with the pump. Upon closer inspection I noticed I fine "ring" of gelatinous material around the pump intake. Keep in mind the intake sits just a couple of millimeters above bottom of the hidden chamber. I removed the "ring" and re-installed the pump. The F:03 error was gone again!!! It has since happened a couple more times. Knowing how the pump is situated in its chamber and how to reach the pump and chamber from the front access panel, I am now able to clean out this gelatinous "ring". The easiest tool for this is a wooden coffee stirrer from Starbucks. Simply break it in 2 pieces as it is too long otherwise. Remove the panel behind the condensation filter as above. The pump intake can barely be seen towards the left. Place the wooden coffee stirrer flat on the bottom of the pump chamber. Slide it under the pump intake and sweep it side to side. Remove it and look carefully. You will see some gelatinous material. That **** is what causes the F:03. Replace all the parts. Hope this works for you. At least if it happens again I won't have to take my dryer apart.
THis site stinks - where are some answers? The f03 error isn't even in the manual.
Posted on Dec 05, 2009
Bosch condensation dryer when on heated dry clothes come out steaming hot not dry
Sounds like something's blocking the hot damp air being removed from the drier. If you are confident enough, go through the drier vent system looking for a blockage. If not get a good DIY neighbour or appliance engineer. Silly question, is the drum turning?
Jan 05, 2015 | Bosch WTE86300US 24" Axxis Series...
How to fix recurring F09 error in Bosch condensing dryer WTE86300US
How long is the connection including the duct work in the house?
Jul 31, 2014 | Bosch WTE86300US Axxis Electric Dryer
Bosch installation instructions
find this on their web site need the enr no
Jul 16, 2014 | Bosch WTE86300US 24" Axxis Series...
My BOSCH dryer #WTE86300US keeps stopping in mid cycle and gives the signal -0- what does mean that error code?
check fluff filter usually in the door is clear, it can be that it is overheating due to lack of air as the fluff filter is full. also check air escape pipe is clear and not blocked or folded.
I hope this was useful.
Oct 20, 2012 | Dryers
What does E1 mean?
Welcome to FixYa.
Can you possibly double check that model number and reply post. I ask because the "E1" error should only pertain to those models which are condensor (non-vented)... "WTL" dryers.
The error indicates either a blocked drain hose or a failed pump. This from Bosch...
E1 Pump failed
(WTL 5400condensationdryer only) Pump failed.
Check voltage at and wiring to pump.
Turn off dryer, measure pump resistance (110 - 136 ?) and replace faulty pump.
Also - Following items apply only to the WTL (Condensation Electric Dryer) models
Cycle is interrupted and ''E1'' appears in display• Condensate hose is blocked in some way. Turn off dryer and check hose.
I'll watch for your reply and try and help you move forward in any manner I can.
Regards,
Macmarkus :)
Apr 14, 2011 | Bosch Axxis WTA 3510 Electric Dryer
My BOSCH dryer #WTE86300US keeps stopping in mid cycle and gives the signal F3 which says to check condensation outlet and I have cleaned all the parts and cleaned hose but it will still beep after a few...
Sep 22, 2010 | Bosch WTE86300 Electric Dryer
I recently had an ventless Bosch dryer installed (WTE8600US) and I keep receiving this message F:03 which the manual says "check hose for condensation outlet". any advice?
For the F:03 problem on the Bosch Axxis (WTE86300US) do all the things mentioned in Solution #1 above. Sometimes the lint in the condensation filter channels (those that run from front to back)can be quite stuck. Use a pipe cleaner to get in there or a garden hose with a spray nozzle. However there is one more crucial step not mentioned in the manual or in Solution #1. Once you remove the condensation filter you will see a small plastic panel on the lower wall of the condensation filter slot. Slide a flat blade screwdriver and gently pop it open. Under the panel is a small chamber where you will find a slurry of lint/water which is what clogs the condensation outlet. With latex gloves reach in there and clean it out. Blow hard into the dryer through the condensation hose to clear up any last bits. Pop the panel back in place. This should fix your problem.
Dec 13, 2009 | Bosch Dryers
Error Code
open the thing up and locate the service manual. once located it should list what that error means. alternatively call bosch and ask them.
Aug 25, 2009 | Bosch Axxis WTL 5410 Electric Dryer
What size circuit do I need for the bosch axxis 24 ventless dryer
If it is a Bosch WTE86300US. The instruction manual available through the bosch website says 30A 3 or 4 pin
Aug 18, 2009 | Dryers
Dryers Logo
1,812 people viewed this question
Top Dryers Experts
