Question about Car Audio & Video
Hi i have a tevion 2413, im missing the 16 pin 1so harness plug as it never came with one, from where i got it <ebay> would you know if a panasonic 16 iso or sommit like that would fit in a tevion,, thank u
2 Suggested Answers
  • 127 Answers
SOURCE: i have a tevion car
Good news are that the TEvion 2413's connector is a standard ISO connector, so you can buy one at most car parts dealers or at most serious hi-fi stores.
Posted on Mar 06, 2011
Hi I have teviono 42" lcd4203id model and tv is white picture nothing on there the TV powers up light comes on but it doesn't bring picture what the fault would be?thanks
TEVION 42" FLAT SCREEN LCD TV MODEL LCD4203ID
www.ebay.co.uk/.../TEVION-42...TV-MODEL-LCD4203ID-/1213...
eBayTEVION 42" FLAT SCREEN LCD TV MODEL LCD4203ID in Sound & Vision, Televisions ' eBay.Missing: white
main board for tevion lcd4203id 42" lcd tv mhdv4201 ... - eBay
www.ebay.co.uk > ... > Other TV & Home Audio Accs.
eBayMAIN BOARD FOR TEVION LCD4203ID 42" LCD TV MHDV4201-ZC01-01 (B) ... Mouse over image to zoom .... *Please open the back cover of TV then check the part number of screen, it would be on white label at back of screen ... of actual item in yourTV as well as check either if it is compatible with your TV model.
LCD TV Repair made easy # 1 - YouTube
? 7:38
https://www.youtube.com/watch?v=GryA_Zl4EBk
Aug 27, 2009 - Uploaded by Grants Pass TV Repair
I have a 2008 model Sanyo dp42848 42' lcd tv with ccfl lighting. .... bought a Seiki tv and within 1 month ...
LG 42LC2D 42 in. LCD HDTV Fusing unit - Que
Dec 29, 2015 | Televison & Video
My 2004 Ford explorer sport Trac won't start up after short drive
O.K. Bernie you say it cranks & tries to run //// you have plenty of power in the battery not a cable issue but what I needed to know is does it happen then start again and then you drive a little bit and it happens again then you wait 20 minutes and it starts again or are you stuck with a lot of cranking power from the battery but no start and then later it will start again /////// there are a lot of things that could be happening so you must bare with me here I'm not at the vehicle first what is the condition of the ignition wires(do you have regular spark plug wires or a 4.0/4.6 with coil on plug boots)if it's regular wires they may be old and leaking voltage and will cause the no start especially if it has rained or is raining at the time because the +voltage leak is able to jump/arc to the engine - ground instead of firing the plugs ==no start next are the spark plugs new/old in gap if they are (a) out of gap to much air space for the + voltage to make contact with the bottom electrode so when the truck starts and runs it's barely making it but as the engine gets hotter fuel is vaporizing fast and the spark plug is not producing the voltage to cause the fuel combustion explosion that happens in the cylinder for each plug because they are out of gap they'll fire up a cold motor but not a hot one /////stay with me Bernie there's a lot to explain here next/// do you have coil on plug with spark plug boots yes/no //if yes you must take each one out & inspect them for (a) very soft (b) cracks in the boot ////check by flexing the boot back N forth to see the strength of the boot should be stiff if they are very soft there's probably a leak in it even a pin hole will cause problems with leaking voltage also squeeze the ends of the boots multiple times to see if there are cracks in the part where the spark plug fits into it below you will see the wires & boot with the contact for the coil the spring you see if this is your system of coil on plug you must after taking the boots off pull out the spring and look into each coils hole at the contact it will look like a blade that the spring fits over if it is green or has a powdery coating clean it using brake parts cleaner or alcohol & emery boards that the ladies use for there nails trim it down and get that blade contact shiny also check the base of the coil on both sides === plug side from electrical system coil connector/spark plug side for cracks marked below with ^^^/>>/<</// if this kind below check the coil towers>>>>>> for cracks on the coil and the actual wire you plug in
here>>>>>>>2004-ford-explorer-sport-trac-start-up-l1nldsrkw3v30gxnu45wzih3-5-0.jpg the red here ^^^^^^^^^^^^ and the connector you plug in look inside for breaks in the connector
>>>> 2004-ford-explorer-sport-trac-start-up-l1nldsrkw3v30gxnu45wzih3-5-2.jpg <<<< >>>>>>>>>>>>>>>>>>>>>>>>>>>> <<<<<<<<<<<<
2004-ford-explorer-sport-trac-start-up-l1nldsrkw3v30gxnu45wzih3-5-5.jpg ^^^^^^^^^^--------^^^^^^^^^^^^^^^^^^
2004-ford-explorer-sport-trac-start-up-l1nldsrkw3v30gxnu45wzih3-5-9.jpg <<< also cracks in the plug or wet spark plug boots ^^^^
>>>>>2004-ford-explorer-sport-trac-start-up-l1nldsrkw3v30gxnu45wzih3-5-14.jpg<<<<<<<same thing here and here^^^^^ ^^^^^^^--------------^^^^^^^ once you have done all checks of the ignition components check the coil for voltage with a meter if there are wet boots from oil antifreeze or just water for antifreeze could be cracked head (the worst thing ) but most likely a leaking manifold/thermostat gasket is letting it in ----if its oil you'll find it in the rear cylinders 4/8 or front 1/5 on the 4.6 if it's in others may be rings or valve seals ---- water the splash shields on the fenders are missing and the carwash or heavy rain is letting the water into the spark plug chambers there is much more here to// change the gas filter and see what happens a lot of dirt could have gotten in your tank from a dirty fill up and if the truck starts to run a little longer but it happens again there's a lot of dirt in the tank and the screen on the fuel pump is getting clogged^^^^^ below and when the fuel settles so does the dirt & the truck starts again because the gas can get through now till it gets mixed up again & clogs the screen so let the gas go to almost empty & take out the pump & look at the screen you can clean it but chances are the pump is going to go anyway because the gas is what cools it off as it flows through but repeated cranking with no fuel going through will make it over heat & repeatedly doing this shortens the pump life & on a 12 year old vehicle this came out in 03 for 04 it's probably almost done so if you find this condition drop the tank clean it out with water and quickly wipe the inside down with rags then spray carb/fuel injector cleaner a whole can make sure you spray all the seams we don't want water left behind at all it will rust out the tank and let air dry after wiping with clean rags then pop in a new pump fill with gas & just turn the key to the on position so the pump can build up pressure then crank for starting
^^^^^^^^^^^^^^ that's it so do these things and post back with progress report and we will continue till I get you there as you can see here I've done a lot of work for you and I will continue if the problem persists I'm going out with the wife now & will look for your post hey Stephen it's Bernie LATER MAN!
Mar 22, 2015 | 2004 Ford Explorer Sport Trac
07 chevy suburnan wiring diagram color
Item12 VoltsSecond 12 VoltsStarterSecond StarterIgnitionSecond IgnitionThird IgnitionAccessorySecond AccessoryThird AccessoryKeysenseData BusCan Bus HighCan Bus LowCan Bus SwPower LockPower UnlockLock MotorDriver Unlock MotorPassenger Unlock MotorParking Lights (-)Parking Lights (+)HazardsTurn Signal (Left)Turn Signal (Right)HeadlightAutoLightsReverse LightLeft Front Door TriggerRight Front Door TriggerLeft Rear Door TriggerRight Rear Door TriggerDome SupervisionTrunk/Hatch PinRear Glass PinHood PinTrunk/Hatch ReleaseTrunk Release MotorFuel Door ReleasePower Sliding Door (Left)Power Sliding Door (Right)Factory Alarm ArmFactory Alarm DisarmDisarm No UnlockTrunk Alarm ShuntTachometerWait to StartNeutral SafetyClutch PedalFuel PumpRear DefrosterMirror DefrosterLeft Front Heated SeatRight Front Heated SeatSpeed SenseBrake WireParking BrakeHorn TriggerWipersLeft Front Window (Up/Down)Right Front Window (Up/Down)Left Rear Window (Up/Down)Right Rear Window (Up/Down)Sun Roof (Open/Close)Sun Roof (Limit/Close)Memory Seat 1Memory Seat 2Memory Seat 3Radio 12VRadio GroundRadio IgnitionRadio IlluminationFactory Amp Turn-onPower AntennaLeft Front Speaker (+/-)Right Front Speaker (+/-)Left Rear Speaker (+/-)Right Rear Speaker (+/-)Center Channel (+/-)Subwoofer (+/-)Aux. Audio Input Left (+/-)Aux. Audio Input Right (+/-)RSE Video (+/-)RSE Audio Left (+/-)RSE Audio Right (+/-)Satellite Radio 12 VoltsSatellite Radio GroundSatellite Radio IgnitionSatellite Radio AntennaSatellite Audio Left (+/-)Satellite Audio Right (+/-)HeadunitLeft Front SpeakerLeft Front TweeterRight Front SpeakerRight Front TweeterLeft Rear SpeakerLeft Rear TweeterRight Rear SpeakerRight Rear TweeterCenter ChannelSubwooferLeft Front HeadrestRight Front HeadrestLeft Rear HeadrestRight Rear HeadrestSatellite Radio Tunerspacer.gifspacer.gifWire Colorred/black (60A), red/black (60A)red/white (x4) (15A each)purple (for starter kill only)pink/black (resistor code), white (5V reference)pinkN/AN/Abrown or yellowsame as second starterN/Asame as second starterdk. green (low speed GMLAN)tan/black (high speed GMLAN)tan (high speed GMLAN)dk. green (low speed GMLAN)use Directed interface modulesee power lockgraypurpletanlt. bluebrown (L), brown (R)whitelt. blue/white (F); yellow or yellow/black (R)dk. blue/white (F); dk. green or dk. green/wht (R)whitedk. green (ground to turn off autolights)dk. bluegray/black (ajar), tan (open)black/white or tan/whitelt. blue/blacklt. green/blackgraypink/blacksame as trunk/hatch pinpink/blackgray (liftgate), pink (liftglass) (rear handle sw)lt. blue (liftgate)N/AN/AN/Aarms on lock with door openlt. green (driver door key cylinder)Passkey and ignitionN/ANOT pinkN/AN/AN/Adk. green/whitepurpleorange or black (L), orange or black (R)dk. blue (back and cushion)dk. blue (back and cushion)dk. green/white (some models only)lt. blue/white (functions with ignition on only)lt. bluetangraydk. blue - browndk. blue - browndk. blue - browndk. blue - brownbrown - org or lt. blu (function with ign on only)N/Aorangesame as memory seat 1N/Ared/whiteblack(low speed GMLAN)yellow (dimmer)same as power antenna (some models only)whitetan - gray or tan - dk. greenlt. green - dk. green or lt. green/white - org/blkbrown - yellow or brown/white - browndk. blue - lt. blue or dk. blue - tandk. blue - orange (with surround)white - pink (with surround)yellow - (bare wire)white - (bare wire)dk. green - white/blacklt. blue - purplewhite - purplered/whiteblack(low speed GMLAN)(coaxial cable)brown/white - tan/whitedk. green/white - graydouble DIN6.56.55.255.25spacer.gifspacer.gifPolarity++++9.6K ohms+++6.3K ohmsdatadatadatadata5 wire5 wire5 wire-+-++--+----+---+-ac+reverse+ latched--ac+--+AAAA-+2.26Kohms+4.26Kohms+-+++,-+,-+,-+,-+,-+,-+,-+,-+,-+,-+,-+-+,-+,-spacer.gifspacer.gifWire Locationdash fuse box, black 40 pin plug (X1), pins F1 and E3BCM, black plug, pins 1, 2, 3, and 4starter or underhood fuse box, blk 50 pin plug (X2), pin F1 or F5ignition switch or BCM, lt. green plug, pins 2 and 4ignition switch or BCM, lt. green plug, pin 14ignition switch or BCM, lt. green plug, pin 21PASS-Key III+ Module, black 5 pin plug, pin 4data link connector, black 16 pin plug, pin 6data link connector, black 16 pin plug, pin 14data link conn, black 16 pin plug, pin 1 or BCM, lt. blue plug, pin 10driver kick or dash fuse box, black 14 pin plug (X3), pin B4driver window switch, brown 16 pin plug, pin 8driver kick or dash fuse box, black 14 pin plug (X3), pin B1headlight switch or BCM, white plug, pin 8underhood fuse box, black 30 pin plug (X3), pins A7 and F7hazard switch or BCM, lt. green plug, pin 19BCM, brown plug, pins 4 and 1BCM, black plug, pin 5; brown plug, pin 2headlight switch or BCM, white plug, pin 12headlight switch or BCM, white plug, pin 17BCM, white plug, pin 22driver window switch, brown 16 pin plug, pins 13 and 11passenger window switch, brown 16 pin plug, pin 13BCM, pink plug, pin 15BCM, pink plug, pin 14BCM, white plug, pin 5BCM, pink plug, pin 12hood switch or BCM, black plug, pin 17BCM, pink plug, pins 13 and 24passenger kick, harness to reardriver window switch, brown 16 pin plug, pin 4any fuel injectorECM, black 73 pin plug (X1), pin 50driver kick, harness to reardriver and passenger window switch, black 10 pin plug, pin 7driver window switch, gray 14 pin plug, pin 6passenger window switch, gray 14 pin plug, pin 6EBCM, blk 38 pin plug, pin 11 or 32 or radio, brn 16 pin plug, pin 5brake switch or BCM, brown plug, pin 6parking brake switch or BCM, brown plug, pin 16horn switch or BCM, brown plug, pin 18BCM, brown plug, pin 20driver window switch, black 6 pin plug, pins 3 and 1passenger window switch, black 6 pin plug, pins 3 and 1left rear window switch, black 8 pin plug, pins E and Hright rear window switch, black 8 pin plug, pins E and Hsunroof switch, black 8 pin plug, pins 6 and 4driver window switch, gray 14 pin plug, pin 5radio, black 14 pin plug, pin 1radio, black 14 pin plug, pin 8radio, black 14 pin plug, pin 7radio, black 14 pin plug, pin 6radio, black 14 pin plug, pins 2 and 9radio, black 14 pin plug, pins 3 and 10radio, black 16 pin plug, pins 5 and 13radio, black 16 pin plug, pins 6 and 14radio, brown 16 pin plug, pins 3 and 11radio, brown 16 pin plug, pins 4 and 12radio, gray 16 pin plug, pins 1 and 9radio, gray 16 pin plug, pins 2 and 9radio, gray 16 pin plug, pins 7 and 15radio, gray 16 pin plug, pins 3 and 11radio, gray 16 pin plug, pins 4 and 11Digital Radio Receiver, black 16 pin plug, pin 16Digital Radio Receiver, black 16 pin plug, pin 9Digital Radio Receiver, blk 16 pin plug, pins 2, 1Digital Radio Receiver, blk 16 pin plug, pins 3, 4center of dashleft front doorleft front pillarright front doorright front pillarleft rear doorleft rear pillarright rear doorright rear pillartop center of dashunder front of center consoleunder passenger dash, behind glove boxspacer.gifspacer.gifPhotohas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifspacer.gifspacer.gifNotehas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifspacer.gif
Nov 03, 2012 | Cars & Trucks
I need to know which fuse number for lights
Turn Signal (Right) white/tan (F), white/yellow (R) + TIPM, green 16 pin plug, pin 3; green 26 pin plug, pin 4
The TIPM (Totally Integrated Power Module) is in the engine compartment, on the passenger side fender.
Headlight white/brown -1.2K ohms [2009 = same] headlight switch or instrument cluster, gray 26 pin plug, pin 3
AutoLights same as headlight
Reverse Light white/lt. green + [2009 = same] passenger kick, harness to rear
Left Front Door Trigger purple - [2009 = VIOLET] driver kick or instrument cluster, white plug, pin 3
Right Front Door Trigger purple/white - [2009 = VIOLET/white] pass kick or instrument cluster, white plg, pin 16
Jun 25, 2011 | 2009 Dodge Challenger
I have a tevion car radio cd player model 2413 but dont have the 16 pin harness plug where can i get one thank you
You could contact Tevion support forum here
or go to ebay and type in 16 pin car audio as your search, you may find what you are looking for there. I haven't seen one, is it a standard iso type?
Surely if it is Tevion specific there should have been one with the radio?
Mar 06, 2011 | Car Audio & Video
I have a 1999 pontiac grand am and the reverse lights and brake lights work but i can not get the tail lights to work. I discovered that the reverse light on the bottom of the car is missing the connector...
Pin
Wire Color
Circuit No.
Function
A
BRN
9
Parklamp Feed
B
LT GRN
24
Backup Lamp Feed
C
BLK
750
Ground
Pin
Wire Color
Circuit No.
Function
A
BRN
9
Parklamp Feed
B
LT GRN
24
Backup Lamp Feed
C
BLK
750
Ground
Pin
Wire Color
Circuit No.
Function
A
BRN
9
Parklamp Feed
B
LT GRN
24
Backup Lamp Feed
C
BLK
750
Ground
Find 3 wire connector going to lense in trunk Pin
Wire Color
Circuit No.
Function
A
BRN
9
Parklamp Feed
B
LT GRN
24
Backup Lamp Feed
C
BLK
750
Ground
Pin
Wire Color
Circuit No.
Function
A
BRN
9
Parklamp Feed
B
LT GRN
24
Backup Lamp Feed
C
BLK
750
Ground
brown wire light green wire & black blk is grd moke sure its good, lit grn back up lights,drk Pin
Wire Color
Circuit No.
Function
A
BRN
9
Parklamp Feed
B
LT GRN
24
Backup Lamp Feed
C
BLK
750
Ground
brn tail lights turn parking lights on & with a test light back probe connector no power to brown? ck fuse trace harness to switch wires all good bad switch if you know how to use ohm meter you could use that to ck for shorts on continuity Pin
Wire Color
Circuit No.
Function
A
BRN
9
Parklamp Feed
B
LT GRN
24
Backup Lamp Feed
C
BLK
750
Ground
Aug 30, 2009 | 1999 Pontiac Grand Am GT
Can't see IM Messages on Skype
i cannot read my instant messages that i received. my skype pop up when i received an IM but when i opened the conversation i cannot read what my sender sent me.
Feb 04, 2009 | Skype IM
RADIO INSTALLING
there is a code for color!? ok, wait im searching...
found it! here you go, hope it helps...
Wiring color codes are the identification colors that color the wires in your automobile. For example, if you have a British car the blue, blue and white , and blue and red wires are for the headlights. The red and white wires are for the instrument lights, and the green and white and green and red wires are for the turn lights. The color code simply identifies what that wire does. Could you imagine if all of the wires were the same color. You couldn't identify anything in a harness.
Jun 19, 2008 | 2001 Chevrolet Tahoe
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
