Question about Photography
I have a Coastar Tripod Model TR-7B one of leg locks keeps slipping.
2 Suggested Answers
  • 24 Answers
SOURCE: I have a Coastar VTR-95RA tripod. Three flip locks cracked
Coastar has been out of business for at least 15 years, I do not know of anyone that has those parts since Coastar used shut down and went away. Unfortunately that tripod is no longer usable, unless you can find another with something else broken aned scavage the parts you need. Be careful to mathc the model numbers exactly as there were several different models starting with VTR-9... and they may not all be interchangeable.
Posted on Feb 10, 2009
How do I get the legs on the he tripod to collapse. They are stuck
If you can indicate the make and model of the tripod in the Comments box, we may be able to help you. Different makes of tripod have different leg joint locking systems.
Jan 20, 2017 | Photography
Is there a "lock" position on on the 3 leg spread of this tripod?
-Providing that the image shown is the tripod you own..., the top leg lock levers on each leg is designed to lock the spreader angle of each leg.
-If this is not holding the leg at the correct angle...., either you are putting more weight on it than it was designed to hold..., or the 'cam' on the various locks has worn.
-A 'stop gap' fix for this problem is to insert a very thin wedge between the lever & the leg tube..., thus providing a greater amount of pressure on the tube, (this would need to be done every time the tripod is set up).
-Replacement parts are not available for this tripod & they were not designed to be user serviceable ...., sorry!!!
Peter
Aug 25, 2014 | Velbon Aef-3 Tripod
Legs Locks Loose
Ross
-It is possible that you are overloading the tripod, thus causing this problem (check specs on tripod model)
HOWEVER IF YOU AREN'T....Giotto uses (2) different leg lock designs..., quick release (normally adjusted by a socket wrench) or rotary (screw locks)!
- If tripod uses screw locks, sometimes foreign material gets into the mechanism and either damages it or prohibits from tightening!!!!!
Note: rotary locks are easy to maintain & if you need parts..., they are user replaceable and usually inexpensive! (contact Giottos distributor in the country you live in)!!!
BUT FIRST!!!! (often problem is caused by dirty lock mechanism)
-carefully unscrew the leg lock (that is slipping) until it separates from the leg higher leg section & carefully pull out the lower tube (at the top of the lower tube will be 'shims' that are part of the lock mechanism).
-Look closely at existing 'shims' do they show signs of cracking, of a build up of dirt, etc. (if damaged they will need to be replaced)
-if shims are undamaged..., use rubbing alcohol & a clean cloth to clean shims and both the tube they sit on and the inside of the tube they slide into.
-once both sides of the tubes and both male & female threads of the locking mechanism are cleaned..., place a light coating of a light oil into the threads (sewing machine oil, bike chain oil, etc)...., do not get oil on the shims!!!!!
-replace locking shims back into position and carefully slide leg tube back into place..., then screw locking collar on (this should not take any force..., if while threading lock collar back on..., it seems tight..., back off collar and check positioning of shims). Repeat procedure!!!
TEST RESULTS!!!
Note: in most cases with rotary locks, problem is purely a maintenance issue, cleaning usually fixes the issue!!!
Peter
Nov 08, 2013 | Giottos (BL1150) Tripod
Allegro tripod legs won't lock
Maybe it could be the clasps not the locks that are broken if you need it functioning right away wedge something in between the clasps, and locks, or the clasps could be over expanded shortten that, and you'd be set.
Feb 22, 2013 | Photography
Manfrotto 3051 Leg Section Slips After Locking - How To Disassemble
www.bogentripodparts.com you may need a new leg lock, you have to loosen it enough and the leg should come out. Send us some pictures at email@spartanphotocenter.com and we will probably be able to set you up with something.
Aug 07, 2012 | Photography
A couple of the lever locks on my Manfrotto 055XB tripod are no longer sufficiently locking the legs so they slip. How do I tighten them?
Use an 8mm, I believe, socket and tighten 1/4 turn the nuts on the lower half of the leg lock. For instance, the top leg lock is connected to the top and middle leg. Tighten the lower 2 nuts (located on the middle leg half of the lock) 1/5 turn. If that does not do it, tighten 1/4 turn again. Be sure not to over-tighten.
Aug 10, 2010 | Manfrotto 055XB Tripod
Hello! I have own for like 15 years a Bogen tripod. Lately I have to tighten the legs screws very hard to keep them in place. How can I solve this? thanks, Luis
Depending upon the model of the tripod, the legs where ithe locks are may be bent, mis-shapen and need to either be replaced or rotated. It all depends upon the model since there are many different styles and some may not be repairable eother due to age or parts availability. Some of the digi series just are expensive enough to repair.
Apr 04, 2010 | Photography
Jan 10, 2009 | Photography
Coastar TR-6BTripod Repair
I have a coastar trypod VTR-65 one of the adjusters to tighten center poll from sliding down. The plastic cap you turn to tighten got broke.I need a replacement anyone know where I can get part for it? I didn't know coaster went out of bisness.
softroll@aol.com
Jun 01, 2008 | Photography
One Leg has loss it's grip.
take it apart, there is a rubber ring like a belt or rubber band, either broken or missing. you will have to find a relacement for that, may have to take apart another leg to have one to compare, course I don't honestly know where you will find that piece. too take it apart just keep spinning the lock counterclockwise until it comes off. good luck.
May 26, 2007 | Velbon Ultra MAXi Tripod
Photography Logo
106 people viewed this question
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
