"Z" (Prints End-of-Day Management Reports and Resets Totals) - Prints the "Z" management report at the end-of-the-day and resets totals to zero (except "locked-in" grand total). To print Management Reports, slide the control switch to the "X" or "Z" position as needed, then press the [amt tend/TOTAL] key. Refer to explanation starting on page 37. "X" AND "Z" SALES MANAGEMENT REPORTS __________________________________________________________________ Transaction data is maintained in the memory of the cash register as long as the battery back-up system is in effect. This data can be printed as a report for management review. The Management Report can be printed from either the "X" or the "Z" position on the Control Switch. "X" POSITION REPORT (Refers to a mid-day reading) The "X" position report prints the accumulated information and RETAINS ALL TOTALS IN MEMORY. Use this position to print periodic readings of transaction information at any time through-out the day. (Some users call the X-report a mid-day report). "Z" POSITION REPORT (Refers to an end-of-day or close-out reading) The "Z" position report prints the same information as the "X" report. However, once this report is printed, ALL TRANSACTION TOTALS ARE RESET TO ZERO except the Grand Total. (Some users call the Z-report an end-of-day report). NOTE: To prevent accidental printing of the "Z" report, set the security code as explained in the SECURITY CODE section. Once this code is set, a "Z" report will not print until the security code is entered. If a "Z" report is attempted without entering the security code, the prompt "SEC Code" will appear in the display.
PRINTING THE SALES REPORT IMPORTANT: Once a "Z" reading is taken, it cannot be duplicated, so be sure to have plenty of paper in the register. 1. Set the Control Switch to either the "X" or "Z" position. 2. Press the [amt tend/TOTAL] key. NOTE: If a security code has been assigned, be sure to enter the security code before pressing the [amt tend/TOTAL] key. TO CLEAR THE GRAND TOTAL: 1. Set the Control Switch to the "prg" (Program Mode) position. 2. Type [2], type [0], then press [RA]. After this operation, the grand total resets to zero.
ok try using a ether net cable from pc to router and going in either 192.168.0.1 or 192.168.1.254 or 192.168.1.1 carnt remember them all admin and sky. admin and password. admin and admin.
When inserting the blade, turn the saw upside down to prevent the blade from moving while tightening.
Before inserting a new blade, check the receiver for obstruction or debris that may prevent the blade from properly registering with the tightening screw.
Make sure the blade is fully seated in the receiver before tightening.
The tightening screws that secure blades on any type of reciprocating saws (Jig, Scroll, Sawzall, etc.) are constantly under stress and do wear out. If the problem continues, it may need to be replaced.
hello 1_ can you save your formation in other phone . 2_that code format your phone for Nokia only 3_ *#7780# if you know your security numbers use it. if you don’t know it use 12345 4_ other numbers *#7370# and the security n ...... and look if the problem is solve it because after this . you have like a new mobile
