On the last load, there was a message on the screen the read Sud what did that mean?
  • Washing Mach... Master
  • 2,180 Answers
To much detergent,sud is for suds.try running the washer with nothing but water,after 5 minutes drain out the water to get the suds out.are you using H.E. detergent and if so it should only be like 1/4 of a cup,any more can damage the machine,the extra detergent can damage the spider gear in the washer.
Posted on Apr 09, 2011
What does "sud" mean on the time remaining display?
You used to much soap producing too many suds. Too many suds interferes with operation of machine. Read your owners manual
Jan 06, 2013 | Kenmore HE4t 3.8 Cu. Ft. Plus Front Load
IT READS SUD
The SUD message relates to overdose of detergent detected during the Wash Cycle.
This may signify a bad pump, an extra heavy load, excessive detergent or excessive suds.
If too much detergent was used, run the washer through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent.
Check the drain hose and make sure it is not plugged or kinked.
Oct 21, 2012 | Whirlpool Duet Sport HT WFW8400TE Washer
Machine read sud
SUD means too much soap was used. Run the washer with a few empty loads and no detergent and the SUD should go away.
Dec 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does SUD mean?
SUD means a detection of suds in the machine. These machines are very sensitive to over sudsing. Try adding just plain water or bleach to break down the suds level. They say to use 1/4 of the detergent you would use in an older machine.
If you see "Sud" or "Sd" with the Rinse status light on, the washer is in the process of removing suds. Let the cycle finish
If you see "Sud" or "Sd" and the Cycle Complete light is on, the washer detected too many suds during the cycle and your load may not be fully rinsed or water may not be fully removed. You may want to select a Rinse/Spin cycle for further rinsing.
Jul 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does it mean when your washer says ''sud''
If the digital display reads "sud" I suspect you may be adding too much detergent especially if this is a front load washer. You only need 2 tablespoons, seriously. Don't put in a cup of detergent into a front load washer as it doesn't require that much and consequently it will "oversuds" which will cause the machine to either "lock down" or go through an extended wash/rinse cycle which defeats the purpose of the front load saving water...good luck
Aug 11, 2009 | Whirlpool Washing Machines
Wash cycle not starting.
THAT NEANS YOUR USING TO MUCH SOAP, ONLY USE HE DETERGENT AN A TEASPOON FULL. THE PUMP IS DETECTING THE SUD AS WATER. RUN UNIT WITH "HOT" WATER A COUPLE OF TIMES . THEN IT SHOULD BE GOOD
May 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
SUD message appears
My manual says that Sud means that you are using too much soap. The washer will say this mid cycle until it gets rid of the extra "suds" and should then resume the cycle. If it doesn't, then you have a different problem.
Apr 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
What does the "sud" message mean?
hello fo2 means if the drain time exceeds 8 minutes the water valves are turned off and f/02 flashes. things to check / check the drain hose for any kinks and blockages check the electrical connection to the pump make sure the pump is running / check the drain pump filter make sure its not block if these do not sort the problem replace the pump. to clear the display press pause and cancel to clear good luck
shaun
Mar 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Spinning and draining does not work, F error or sometimes Sud
Sud means you using to much soap and the f code means soap is locking the drain pump up and wont allow unit to drain and spin.
Nov 22, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
60 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
