Question about Toshiba Televison & Video
Hello i got a toshiba lcd tv (52hl167) and all of a sudden i saw a black vertical line in the center of my screen and now it got worse the half left side plays perfect however the right side of the screen has alot of colorful lines on it and blinks sometimes cant see and picture on the right side...a local technician told me its the t-con board...i bought it and replaced it and same thing but screen is darker now can u help me please
  • redrat5922 Apr 09, 2011
    cant believe that wow my tv is only over 2 years old how *** the screen went faulty already...i heard that a lcd screen is very very expensive not worth replacing should i just buy another tv and what do u recommend thanks
  • 10,594 Answers
I'm afraid it is problem of LCD Panel (screen) and lcd panel will be replaced to solve this issue.
I'm sorry for breaking this news but there is no way to fix lcd panel.
Thanks.
Posted on Apr 09, 2011
  • Shahid Electronics
    Shahid Electronics Apr 09, 2011
    The lines that appear on lcd panel is because timing circuits built in lcd panel are no more responsive/ controlling the lcd pixels and unfortunately it happens in lcd panel.
    Below is an image that shows worst picture result of lcd tv, just an example.
    And yes, you are right, lcd panel costs approx new tv price so buy new tv is even better option and I would recommend to purchase extended warranty as well with new tv.
    Thanks.
I my toshiba regza 40rf35ou vertical lines 1/2 of screen for about 12 minutes then great picture
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Vertical line problems to LCD screens are described with illustrations. Surf the site with patience.
Mar 20, 2014 | Toshiba 52HL167 52 in. LCD HDTV
Upon turning tv on after it's been off for a while i get two lines going from top to bottom of the screen. theres a line on the left side about 2 inches in from the left thats red and about 3 mm wide and...
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
HOPE THIS HELP...
Jun 19, 2010 | Toshiba REGZA 47HL167 TV
My question concerns a Toshiba Regza model 52HL167 which displays a perfectly normal picture on the right half of the screen and a blurred and streaked image on the left half of the screen. The lcd...
This will most likely be down to your screen controller board, Take the back of the tv and look towards the top middle, You will see your screen cable go into a rectangular board this is sometimes covered by a metal plate, remove this and check Ebay or Google for a replacement, there will be a part number on the board
Hope this helps?
Mar 05, 2010 | Toshiba 52HL167 52 in. LCD HDTV
Vertical Lines on Sony Bravia TV.
I'm afraid, its problem of LCD Panel (screen).
LCD Panel replacement is only solution for this problem and will cost you 70% of TV price, please contact nearest Sony service center for LCD Panel replacement.
Dec 13, 2009 | Sony BRAVIA KDL-32S2010 32 in. LCD...
Appears a black line vertically on the screen
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Dec 06, 2009 | Toshiba 32AV502R LCD TV
Vertical red line on Toshiba REGZA 52HL167 tv.
I have this same problem with my 52 inch toshiba regza , The repair shop has said the cost of repair is as much as it is to replace the TV. I am past the one year warranty, but less than 2 year ownership, so Toshiba won't fix the known issue. Solution is don't buy a Toshiba
Oct 30, 2009 | Toshiba 52HL167 52 in. LCD HDTV
Black line
Called ghost lines or banding. I researched on toshiba thread LCD screen bad. I have same problem purchased HL196 4/07 problem appeared 1 year and 9 months ago no extended warranty. If still under warranty call toshiba. LCD screen more expensive then orginal price of TV. Should file class action lawsuit for selling defective screens. Lot of people having same problem. goforth2953
Sep 09, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Vertical lines in my laptop screen
My understanding is that you have 2 laptops with the same problem, if that is the case, you need to replace the lcd. When you have lines on lcd's, that is a sign of a bad lcd.
Jun 10, 2008 | Toshiba G15-AV501 Qosmio Notebook
Shrinking screen.
hi there, you do have a vertical section problem and at the power supply section problem. do some test, check for some cold solder at the power supply section, test some electrolytic capacitor at the vertical section. ty
Jan 01, 2008 | Televison & Video
The LCD would start to fail eventually, there is a fix you can try which has worked for some, but it solely depends if you want to try it out, it might revive your LCD...
http://udpix.free.fr/
Dec 09, 2007 | Toshiba Satellite P30 Notebook
Televison & Video Logo
65 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
