Question about Toshiba 55H70 55" Rear Projection Television
The image jumps and there are squiggly lines up top
  • Toshiba Master
  • 3,459 Answers
This sounds like a hypermodule problem. Check the site www.TvRepairKits.com for a kit to fix it.
Posted on Apr 18, 2011
Squiggly lines
Check and replace all the filter capacitors at its main power regulator section circuit.
May 22, 2013 | Televison & Video
The tv has red images, I cannot get the red convergence line vertically to straighten, it is squiggly, the horizontal is straight, and the blue and green lines are both okay
the 43h71 has a pair of convergence ics that commonly go bad and cause this problem. replace original stk392-110 with stk392-120. the upgrades have a collector rated at 4 amps vs the 110's 3 amps and should be more reliable.
also know that they hyperboard in this set can cause squiggly lines throughout but will not affect the convergence.
Jul 06, 2010 | Toshiba 43H71 43" Rear Projection...
It started out with alot of different colored squiggly lines it would clear up after about ten minutes but it just shut off yesterday the red button on the front still flashes though
Especially Projection TVs will shut down to protect the projection tubes because loss of proper scan can burn an image into the phosphors in the tube itself. The squiggly lines most likely are a symptom of a failure in the Horizontal output section (the part that scans the picture from left to right), there is also a possibility of the Vertical output section (the part that scans the picture from top to bottom causing the problem. This will require replacing a circuit board or repairing the one in the set at a component level. This is best left to a qualified Technician to do the work.
May 29, 2010 | Sony KP-61HS30 TV
Small Rectangles or squiggly lines on screen
bad RAM on graphics card. replaces graphics card
May 14, 2010 | BenQ G2110W 21" Monitor
Green squiggly line distorting picture on TV
Ur Convergence is dead.Parts and labors,about $300 dollars.
Jan 07, 2010 | Televison & Video
Tv image turns green squiggly lines
Hi
This symptoms is made by defective shorted Green Cathode gun, or shorted in the CRT Board. this need to check the CRT Board.
Thanks!
Dec 05, 2008 | Televison & Video
Squiggly Lines at Power On
Generally speaking, this type of symptom is caused by AC hum leaking throught the power supply. This can be due to a bad filter cap. Since this clears up after a while, I'd start by looking for poor solder connections in the power supply area. If you can, check the caps in that area as well. I'll research this a bit and try to get you more details.
Dan
Nov 06, 2008 | Toshiba 42H82 42" Rear Projection...
The blinking light
Hi, The problem your having with the two circles and the squiggly line mean you have a paper jam. Hope this helps!!!!
Dec 05, 2007 | HP LaserJet P2015dn Printer
Faint squiggly lines top to bottom
· Samsung parts for convergance problem
· http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Sep 20, 2007 | Samsung HCN4226W 42" Rear Projection...
Toshiba 55H70 55" Rear Projection Television Logo
19 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
