Question about Vacuums
I fill the SE3306C steamer 50 ml, close the safety cap put it on and the light becomes green but no steam will come out ! Is it because I don't close the safety cap right ??
4 Suggested Answers
  • 4088 Answers
SOURCE: Steamer filler cap is sealed
You need a little more leverage--either a strap type tool or a pair of adjustable width pliers that span the width of the cap. Try running hot water over the cap first which may loosen it enough to remove by hand.
Posted on Sep 09, 2009
SOURCE: safety cap on the Euro-Pro dexuxe steam cleaner style SC507H
if it is anything like mine...you push the cap down, give it a full turn & release. keep doing this (maybe 5 or more times, and eventually it will start unscrewing easily without needing to push down
Posted on Feb 28, 2011
  • 500 Answers
SOURCE: i have an enviro steamer
Hi janettrobe836,
I believe your element has gone. You may need to replace it.
Give me the Model and PNC number of your Vacuum and I will provide you with a part number which you can order it on, or even a service manual for likely things you can check.
Regards
JEDEMEYER
Posted on Jul 06, 2011
My compact steamer does not let the steam out when I press the black release button help?
I examined mine. There is literally NO hole in the steam wand for the steam to exit. It's a wonder the thing didn't blow up. Take it back and be glad you still have your face.
Jan 01, 2015 | Top Vacuums
My ez1 Monster Floor Steamer - green light goes off when I lower the handle and stops steaming
It could be calcium deposits in the tank. Clean it with white vinegar. Good luck!
Nov 10, 2012 | Euroflex Ez1 Monster Floor Steamer -...
Hi -- For my White Wing Steam Cleaner: After I plug in the unit, and wait over 10 minutes, the Pressure gauge shows that the pressure at 2 (maybe 2.5, I can't recall as I'm typing today) -- not...
Re: Low pressure on WhiteWing steam cleaner
1. Make sure the safety switch for the hose handle on the right side of the hose handle is turned to the closed position. To do that, push it away form the hose.
2. Make sure the steam release button (next to the on/off button on the control panel on the steamer) is in the Off position.
3. Make sure the safety cap is tightened.
4. Make sure you have enough water in the tank (at least half a bottle of water)
I hope this helps.
Jul 31, 2011 | Vapor WhiteWing Steamer Canister Vacuum
Scuncii Steamer
It is probably clogged with rust or limescale - can happen with steam cleaners. Sadly there's no way around this but to try a limescale remover in distilled water such as Calgon limescale remover. Fill the kettle as normal and give it time to boil up. Then release the steam as you would normally. You may find that the kettle will spurt out deposits of gunk. Sounds like its definately clogged though.
Feb 19, 2009 | Scunci 52067 Handheld Steam Vacuum
Knob
The safety cap (knob) turns counter clockwise to open so you can put water in. Turn clockwise to close after filling.
Aug 03, 2008 | Eureka Enviro Steamer 310 Stick Vacuum
Edmark steam brush
Hi
press small release button on steam supply cotroller lever and pull the lower portion towards you
. now inyour righthand is your water filling tank . open the cap 7fill baout 100ml of water & close the cap put this back to the main unit just by gently pressing towards to the unit
It is done nolw wait for 30 sceconds & start using
Thanks
Aug 03, 2008 | Vacuums
Heats up and produces steam but the release button does not open the flow of steam.
To remedy this, I did the following:
1) Removed screws from: a) Lower area of handle (1 screw), b) Top of steamer, under round rubber flap around fill hole (2 screws), c) Front of steamer where nozzles attach (2 screws)
2) Removed back of handle, top of steamer, front of steamer where nozzles attach
3) Once all parts are removed, you can see a brass button that is pushed by the trigger
4) Using a needle-nose pliers, grasp and rotate the button several times in both directions (you may hear it cranking against the interior spring). Do this until it turns fairly easily with the pliers.
5) Once this is done, you fill find that the brass button can be very slightly depressed with a bit of force. You may also need/want to unfold a large paper clip to push into the nozzle hole to help unsticking the brass button (not sure if that helped in my case, but it was something I tried along the way). When the brass button moves in and out (again, it won't move much), the steam release mechanism is unstuck!
6) Reassemble all parts (everything snaps back neatly into place).
This worked for my unit!
Nov 11, 2007 | Scunci 52067 Handheld Steam Vacuum
Steam shark model sc 505 uk
THE FILL CAP ON MY SC505 IS JAMMED. CAN NOT REMOVE THE CAP. WHAT ARE MY OPTIONS.
Aug 14, 2007 | Euro-Pro Shark SC-505 Handheld Steam...
Vacuums Logo
80 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
