Recently purchased a C2 Centurion. After maybe 45 minutes run time, it was showing signs of battery weakness. Then it just didn't work at all, so I ordered new batteries. I had noticed that the tailpiece button didn't seem to depress but thought that maybe just the new batteries and a light touch was the answer. It wasn't. I think the tailpiece button is jammed somehow and won't depress all the way. Since the light was backordered a month before I got it, and I just waited a couple weeks for new batteries to show up, I'd certainly like to fix the light myself. I just don't want to do anything to void the warranty.
SOURCE: HRC200 shows current temp
http://12.153.20.74/manuals/119426-01A.pdf
page 24 shows to unlock hold both buttons down
SOURCE: Weak light
If the charge lite comes on when charging it means your transformer is still good. Replace the battery.
If you get no charge light transformer is bad, if this is the case (personally) i would replace the charger & battery for that peace of mind.
GGBMDB
SOURCE: LED Flashlight Battery Drain Problem
This particular flashlight uses a microchip that consumes the power of the batteries, whether in use or not. Loosen the case to where the batteries go in, so there is no contact with polarity. Or just take the batteries out completely and replace them for actual use.
GGBMDB
SOURCE: compaq presario 700 getting very hot, battery poor
Hi
It is proberly not the battery - it is a problem with the drivers that starts up the cooling fan. - symtoms: stops ramdomly - malfunktion of some funktions - and indeed gets hot
go to compaq home page for driver opdate
love
SOURCE: My canon A710IS shows the battery low light after
1. use alkaline batteries or rechargeable NiMH batteries
2. you may need to clean and adjust the springs inside the battery compartment
more details please refer this
Why my camera keeps saying ‘change battery’ even with new batteries?
