I am trying to locate the memory slots so I can upgrade my memory
    Sergeant:
  • 189 Answers
I'm assuming you're talking about upgrading your RAM. There are 4 slots on most motherboards that hold the RAM chips.
Posted on Apr 09, 2011
  • John Moon
    John Moon Apr 09, 2011
    http://www.techpowerup.com/reviews/ASRoc...
    They look like that. Just push them in until the side clasps lock.
Memory upgrade.. toshiba portege 3500
hi..the one of memory located at the lower or under the one slot memory installed..thanks...^_^
May 13, 2009 | Toshiba Portege 3500 Tablet PC
Acer Travelmate 270 Memory Upgrade
Acer TravelMate 270 upgrades:
The official upgrade slot is located on the bottom of the laptop and is easy to find. Just unscrew the small cover and there it is.
The other slot requires you to unscrew the two screen bracket screws. Once you have done this, between ESC and F1, F4 and F5 and F12 and PrtSc there are small plastic rings. Put a biro nib into these and pull down. They will pop down. You can now remove the plastic cover.
Unscrew the two screws marked "L9" on the bottom of the laptop which are located at the top of the memory cover. Now you can remove the keyboard. Underneath the keyboard is the second RAM slot. The SiS 650 chipset supports a max of 1GB per memory slot and since this laptop has two slots that means 2GB of RAM. I've used Kingston DDR400 PC 3200 SODIMMS.
You can also upgrade the CPU - the fastest CPU available is the Pentium-M 2.6GHz. Nothing faster will work - trust me on this. It must be a Pentium 4 Northwood architecture CPU with a 400MHz FSB. Standard P4 Northwood CPUs with the metal shim won't fit - unless you know a way of removing the shim without destroying the CPU. Best to stick with a Pentium mobile (Pentium 4 M) chip. Look on Ebay for these.
Of course the hard disk can also be upgraded - a 200GB 7200RPM 2.5" drive works a treat. Non SATA of course.
You can add wireless and USB 2.0 using PCMCIA carbus cards. I use a StarTech 54mbps wireless card with the RAlink chipset and a NEC USB 2.0 card with 4 USB ports. Both cards fit in at the same time.
The laptop absolutely flies with these upgrades.
Mar 20, 2009 | Acer TravelMate 273XV PC Notebook
Location of memory slots
Hi.There are a set of instructions that we need to follow for the upgrade process.You can increase the amount of RAM (random access memory) in the notebook with an optional memory module approved by Compaq.The notebook contains 2 memory slots, one of which is accessible for an optional memory module upgrade.Please refer to think link and select the Hardware Upgrade option in the list in the file which will guide you thru picturised views for helping in the memory upgrade.Link is : http://h10032.www1.hp.com/ctg/Manual/c00090108.pdf.
Please let us know whether this help or whether you need more help
Mar 16, 2009 | Compaq Presario R3000 Notebook
I have a toshiba satellite 1900-803 - when I open up the memory compartment on the back I can only find 1 slot which I have alread used to upgrade the memory to 768 MB. Where is the 2nd slot so I can...
Maccstokie,
It is possible that the other memory slot is on the opposing board side, and already occupied by system default memory. It is also possible that the ram is also located by the wireless card port. Open each of the underside compartments and see if there is an additional memory port, Trial and error is the best approach.
Drumwar
Nov 02, 2008 | Toshiba Computers & Internet
Trying to upgrade the memory on my Acer Ferarri 3400 Notebook but can't find the location of the second memory module. The user guide says that there are two memory slots but there is only one under the...
THERES ONE MEMORY LOCATION R U UPGRADING BOTH CHIPS OR JUST ONE, MOST SYSTEM ONLY COME WITH ONE CHIP U HAVE TO ADD ONE IN THE SAME LOCATION TO UPGRADE OR GET THE HIGHEST SINGLE SLOT CHIP U CAN GET UR HANDS ON,I WOULD SAY CALL TIGERDIRECT AND TALK TO SOME OF THERE SELLS ASSOCIATES THAT WILL PROBABLY BE THE BEST SOURCE OF INFORMATION ON HOW THE SYSTEM IS CONFIHURED
Aug 11, 2008 | Computers & Internet
Reg ram upgradation
Each memory slot on the C555NR can support a maximum of 1GB of RAM. There are actually 2 slots, but only one is easily accessible to you. By upgrading both the primary and secondary DIMMs, you could achieve a total of 2GB of memory but you would have to remove the 512mb chip that is already installed and replace it with 1GB (+1GB in the expansion slot as well.)
If you don't plan on taking the computer to a professional to be serviced, you will probably only want to upgrade the memory in the secondary slot located under the memory cover on the underside of the computer. It can handle a 1GB SODIMM.
FYI the memory is:
200 Pin DDR2-533 PC2-4200 SODIMM
Apr 21, 2008 | HP Presario C555nr Notebook
Acer TravelMate 272 Memory
I think in this case the second memory slot is under the keyboard.
Mar 17, 2008 | Acer TravelMate 272XC Notebook
Sony A690 Memory Location
Some Vaio laptops (and some HP's) have a memory slot under the keyboard.
Jan 26, 2008 | Sony VAIO VGN-A690 Notebook
How to upgrade memory
The NEC Versa m500e has 2 memory slots. Each slot can hold DDR PC2700 with a maximum of 512MB per slot.
I'm not sure where the memory is located on the Versa, but normally in the middle on the bottom of the laptop there is a memory slot. on some units the memory is located under the keyboard, so you have to remove this first to change the memory.
Hope this helps
Dec 27, 2007 | NEC Versa FX Notebook
Memory upgrade
First thin you have to remember is if you want to have to memories in parallel...Then the new one should be of the same size and frequency(ex:133Mhz,533Mhz..etc.,)Then folow these steps:
  1. Turn off the computer and remove all power cords from the computer system.
  2. Locate the panel used for access to the memory modules. This is generally located on the bottom of the laptop computer. Refer to your laptop instruction manuals for locating the panel.
  3. Remove any screws that the panel in place and place somewhere safe to prevent losing it.
  4. Remove the panel from the laptop and set aside.
  5. If replacing or upgrading an existing memory module, remove the memory modules by undoing and module clamps and gently lifting the edge of the module to a 45-degree angle and then pulling the module out of the slot.
  6. Align the notch of the memory module with that of the memory slot and gently insert the module into the slot at a 45-degree angle.
  7. Once all the pins are in the slot, gently rotate the module down flat until the clamps lock into the module into place.
  8. Replace the memory access panel onto the laptop computer.
  9. Replace any screws or fasteners that hold the panel in place.
  10. Replace the power cord and power up your computer system.
Oct 13, 2007 | Acer Aspire 3610 Notebook
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
