Question about LG LDS4821 24 in. Built-in Dishwasher
Dishwasher is not emptying the water at the bottom
  • 76 Answers
Did u check the drain to see if its clogged
Posted on Apr 09, 2011
Our Bosch dishwasher has water filling back in bottom of dishwasher after cycle is complete. You can empty dishwasher and no water will be in the bottom, but several hours later the water has filled the...
Check the drain line underneath the sink.
It should be suspended just below the counter top.
If it is too low,water from the sink will back fill into the dishwasher.
If the drain is OK,then the dishwasher water valve is defective.
Mar 26, 2011 | Bosch SHU3306UC Built-in Dishwasher
Please help me fix my electrolux dishwasher, water is building up at the bottom and its not working
Wendy, sounds like the drain pump or the actuator for it has failed. If you hear the pump motor hum, but it does not empty the water, it may be jammed with some debris. To access all of the mechanical workings, you will need to remove the lower access/kick plate cover, on the bottom of the front of the dishwasher cabinet. You may want to empty most of the water out of the tub by hand, before you attempt to work on it. Also, check the circuit breaker for the dishwasher in your home's circuit breaker panel, to make sure it has tripped. If it has, reset it to see if the dishwasher will start running again. Just make sure it's in the drain water cycle.
Mar 22, 2011 | Grilling
Dishwasher turned on accidently and full of water
Close the dishwasher door and run the drain cycle of the dishwasher only....that should empty the appliance. Note that a little bit of water remaining is normal, but if there is a substantial amount of water left, you will need to check the pump inlet screen and the drain hose or sink for any additional clogging.
Apr 02, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
After drying there is water in filter trap is this normal
IF THE WATER IN PORTABLE DISHWASHER AT THE BOTTOM IS MORE THAN THE DRAIN HOSE FULL OF WATER THEN ASK WARRANTY PEOPLE. WHEN PUMPING WATER UP IT CAN ONLY PUMP SO MUCH WATER OUT OF HOSE BEFORE THE WATER DRAINS BACK INTO DISHWASHER.-- HOPE THIS HELPS
Mar 08, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Maytag series 100 dishwasher not completely emptying after cycle
I am having trouble with water not emptying out of dishwasher completely help
Jan 07, 2010 | Maytag Dishwashers
Water collecting at bottom of dishwasher. screens have been cleaned.
is there water sitting in the bottom of the dishwasher or on the floor? If its sitting in the bottom of the dishwasher, most likely the discharge pump isn't working properly and not emptying all the water out. The pump will usually run for an extended time to pump the water out until it finally times out and you're still left with water in there...
Sep 09, 2009 | Dishwashers
Water and odor collecting in our empty dishwasher after 4-5 days
A small amount of water may be normal.  Clean the filter at the bottom of the tub.  Sprinkle some baking soda inside between washes.
Jun 02, 2009 | Dishwashers
Water in bottom of dishwasher
The emptying valve is probably partially blocked with a piece of debris or bone. It can be cleared manually usually if you can get at it with a pair of needle nose pliers or tweezers.
May 03, 2009 | Jenn-Air 24 in. JDB1100AW Built-in...
Bosch dishwasher S10R1B: Water not pumped out
Normally it is the impeller which is stuck. Take out the dishes and the filters and empty it for water by hand. Yes it is a dirty job. Then at the bottom there is an opening in the steel where the water is collected. Empty this too. At the bottom left there is a torx20 screw that keeps the cover for the impeller. remove the cover and check that the impeller can move. The may be object stuck
You canalso force the safety mechanism in the door with a screwdriver and try to see if the impeller moves when it is supposed to empty water.
My problem is that I did all this but it still does not move. It may be the impeller motor which is broken. To replace that one is not easy.
Jan 31, 2009 | Bosch 23 in. SHU3307UC Built-in Dishwasher
Dishwasher won't empty
sounds like the hose is blocked (usually with broken glass, followed by larger food particles) that runs from the dishwasher to the sink. You may need to remove this piece to check. If that isn't the problem, it's probably electrical.
Jan 26, 2008 | Hotpoint 24 in. FDW60 Free-standing...
LG LDS4821 24 in. Built-in Dishwasher Logo
87 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
