Question about Sony KP-57HW40 57" Rear Projection Television
Red bowed lines
You mentioned that you used the posted solution to fix the bowed lines on your sony tv, can you tell me where you found this solution or provide a link so that I can try to fix it myself?
Thanks!
  • knkk1969 Aug 17, 2008
    can see red bowed lines when screen is dark.
  • chevy0353 Dec 01, 2008
    My sony KP-57HW40 rear projection screen has several faint red arches across the whole screen, mostly noticed when the screen is dark.Occaisionaly out of nowhere my screen will flash a brite burst of red and automaticaly shut off,on rare occasions it will do the same with a blue flash.
  • Sony Master
  • 3,459 Answers
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Posted on Jun 06, 2010
Picture is distorted......bowes inward. Colour is
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 21, 2011 | Sony KP-57WS500 57" Rear Projection...
I have a sony center of tv is clear but top left corner has a redish bow and very bottom is bowed
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 10, 2011 | Sony KP-57WS500 57" Rear Projection...
Sony KP-53V75 picture problem
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem as shown below. Doing so will only make things worse.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Mar 12, 2009 | Sony KP-53V75 53" Rear Projection...
Sony Tv
Replace STKs both of them STK392-560
Sep 13, 2008 | Sony KP-51WS510 51" Rear Projection...
Red bow on top and bottom of 61dx01b
  • Screen looks 3D
May 21, 2008 | Samsung PCL5415RB 54" Rear Projection...
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Feb 20, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Sony -kp65wv600
I got this TV for FREE from a guy posting it on craigslist because he saw "BLUE SWIRL LINES" also knows as "Retrace Line" on the screen and he went to several repair people and got high repair costs so he was giving it away for free, but i found a guide that tells you how to adjust the tv to make the blue or green or red lines go away, aparantly the line show up because the voltage on the color ray gun tubes that get out of adjustment. Here is the Link to the REPAIR GUIDE. http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Jan 11, 2008 | Sony KP-57WS500 57" Rear Projection...
KDF 42 Sony Wega
Nov 08, 2007 | Sony KP-57WS500 57" Rear Projection...
65' MITSUBISHI Projection TV - Picture bows - looks 3D
convergance amps need replacing. check with a local repair shop for pricing. dont be shock it may cost ($350.00)
Oct 17, 2007 | Samsung HCN5527W 55" Rear Projection...
Too much red unable to adj it out
This problem is apparently occurs in 2 cases 1)Exposure of the screen to stron magnetic fields This can be solved by degaussing(if this feature is there in your tv)Otherwise u can drop into a seervice center and it will be fixed in a jiffy. 2)Due to the presence of a dry solder(Loose contact) If you think you can try opening your tv and attempt to spot it. Otherwise just drop into the nearest service center..U can locate by clicking on the link below http://www.sony.net/SonyInfo/Support/
Oct 08, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57HW40 57" Rear Projection Television Logo
55 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
