Question about Home
PIPE SHOWER HEAD IS SEIZED - Home
  • gwbreish Apr 09, 2011
    IT IS SEIZED GOING INTO THE WALL THE SHOWER HEAD IS ALREADY OFF
    THE PIPE IS SIEZED GOING INTO THE WALL. IM TRYING TO REPLACE THE PIPE
  • 11,800 Answers
It has been seized by lime deposits. Ideally you should fill the tube from the shower head up to the valve with lime-remover solution, but this is a complex job. It involves removing the faucet and filling the pipe to the shower from the bottom - you would need special equipment for that. Without this equipment all you can do is to cover the shower head in a rag then drench it in lime remover solution. Let it rest for at least an hour the gently but firmly try to move it - jiggle it until the lime scales break . Beware, do not force it beyond its breaking point and don't forget to close the water during the procedure.
Posted on Apr 09, 2011
  • Azrael SRL Apr 09, 2011
    The same advice: wrap around the rag on the part closest to the thread and let the solution infiltrate - the rust and lime will dissolve and allow you to unscrew the pipe.
Shower head broke off
You can get a new extension pipe to replace the broken one. If there's enough left on the old pipe to get a pair of slip joint pliers on try to get it out that way. If not then you'll have to use a pipe extractor tool to get it out. You won't have to take the shower out.
Oct 19, 2017 | Home
PIPE TO SHOWER HEAD IS SEIZED ANY SUGGESTIONS FOR GETTING IT OUT
Good Afternoon, GWBreish:
If the 'seize' is from hard water (white or green deposits on the fixture) a towel or sponge soaked in vinegar or CLR van be tied or velcro bagged onto the fixture for 15 to 30 minutes, then the residue attacked with a scrubber or steel wool pad. If the seize in inside the fixture, you will have unscrew the face plats and paint or swab CLR or vinegar to the meshed parts of the handle.
CHR
Apr 09, 2011 | Moen Posi-Temp Single HandleTub And Shower...
I have an American Standard shower that drips out the shower head. When other faucets are used in the bathroom the water pours. I replaced the cartridge put it still drips.What could be the problem?
Hi kwbaker!
Assuming the cartridge is new and the water drips at both hot and cold settings, I would check your shower head. It is not uncommon for debris to collect in the screening there and clog the spray nozzle.
To check the shower head you'll need to remove it from its piping. Use two tools--I normally use an adjustable wrench and a strap wrench--to hold the wall pipe and simultaneaously turn the shower head counter-clockwise. The cresecent wrench grabs the hex-head of the shower head, while the strap wrench holds the chromed piping without scratching it.
Be sure you don't lose the rubber washer inside the pipe-to-shower head connection!
Once the head is removed, look inside it at the pipe side. You should be able to see into the mechanicals of the shower head--very often I'll see bits of rust or scale. Oftentimes its enough to rinse the pipe side of the head under a sink; in extreme situations it can be easier to replace the entire shower head.
To replace the shower head, use two tools in the same manner in which the head was removed: crescent wrench to turn the shower head, strap wrench to hold supply piping. This time, however, turn the shower head clockwise until it tightens snug.
Hope this helps!
--Joe
Nov 12, 2010 | American Standard One Handle Shower Only...
On new Moen shower faucet, when I turn on faucet, water drips from shower also.
The faucet was installed upside down.
The shower riser pipe in the wall is to short( the distance between the faucet and shower head).
One of the biggest problems is if your shower faucet was installed with Pex pipe to the tub spout. Pex pipe will restrict the flow and force the water back up and out of the shower head.
The tub spout must be piped with at least 1/2 brass pipe nipples and fittings, or 5/8 OD. copper pipe and fittings.
Hope this helps, if you further questions please let us know.
Sep 08, 2010 | Moen 3175 Legend One Handle Shower Faucet...
The pipe leading to the shower head is larger than the new shower head I planned to install. Is there a type of connection that I can buy and what is it called and where can I buy it. I thought it might...
You need your old shower head and the new one, go to the hardware store and tell them you need a pipe adapter with a female side that fits the old one and a male side that fits the new one. They'll be able to pick it out for you.
What you're looking for is commonly called a pipe adapter or "nipple".
Aug 09, 2010 | Water Pik Shower Head
I can't unscrew my old shower head, it's too tight and the whole pipe moves when I try to unscrew the shower head. Any suggestions?
I hope u have been able to unscrew this by now. I faced the same problem and then someone suggested me this. Take a rag and use some vinegar on the rag and cover the tight joint ooverntight. let it rest. what happens is the vinegar (which is actually acetic acid) dissoleves the deposited minerals around the corners. In the morning take the pliers and knock around the joint. then try unscrewing with the wrench, am sure it will work. In my case it came out easily.
hope this helps
thnx
Santosh
Sep 22, 2009 | Home
Leaky shower flawcet
where the leaks coming from?if the leak come inside the shower head the problem is in the valve, if the leak is in the connection of the shower head and pipe check the o-ring or u can put teflon arround the thread of the pipe b4 connecting the head shower
Aug 21, 2009 | Plumbing
Water pressure to main hose has ceased, with water now pouring out of a small outlet pipe at bottom of unit next to fixing for main hose.
Sounds like your outlet at the top has clogged with grit/dirt. Turn the shower off, remover the entire shower head hose from its base (where it screws into the wall or pipe. Turn water back on. If you get a steady flow (as you should) the problem is isolated to the shower head/hose. Detach the shower head from the hose and clean the screen inside, attach hose back on first, try water again, if this flows then your blockage is in the head itself. After removing and cleaning the screen inside the shower head, reattach and run water, this should fix your problem, if not, you may need a new shower head. If the water will not flow to the outlet pipe alone, either your shower switch is broken or you have a serious plumbing problem.
Apr 16, 2009 | Home
Tub shower combo... newly installed but leaks from shower head when turned on
Some shower heads require a rubber washer that would fit in the opening in the shower head. That may be all you need and would be the simplest fix. Check that first.
Sounds like you need some teflon tape available at any hardware store. The teflon tape should be wrapped around the pipe threads with 2 or 3 wraps and then screw the shower head on to the pipe. If the leak is in the wall, remove the shower head pipe from the wall pipe elbow and apply 2 or 3 wraps of teflon tape to the shower head pipe threads and reinstall to the elbow in the wall. You may need a pipe wrench if the pipe is real tight. Good Luck
Nov 30, 2008 | Dishwashers
How to Remove Shower Head
Once you've purchased your new shower head the first step in replacing the head is to make sure your shower faucets are firmly turned off and then remove the old shower head. If you look at the existing shower head, you'll notice flat spots on what's called a pipe nipple at the base of the shower head where the head screws into the goose-neck pipe that sticks out of the wall. * Take an adjustable wrench and tighten the wrench onto the base of the shower head flat spots. * Turning counter-clockwise, loosen and remove the old shower head. * Clean the threads on the goose-neck of any debris such as old pipe compound or Teflon tape.
Aug 27, 2008 | Dynasty Hardware Single Handle Shower Only...
Home Logo
340 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
