Question about Poulan Pro PP4620AVX 46cc Gas Chainsaw With 20" Bar
Where is the ides screw/\? I don't see it - Poulan Pro PP4620AVX 46cc Gas Chainsaw With 20" Bar
  • Poulan Master
  • 2,239 Answers
On the left hand side of the saw, just above the L and H adjustment screws.
Posted on Apr 10, 2011
I have a dvd Rom sata connected and an ide connected but the ide won't read. i brought a new ide (same brand LG) i plug it in and the pc won't load up. it says insert disk. i plug the old one in...
You need to check that you don't have the same identifier for 2 IDE drives. you can only have one "Master" and one "Slave" on each IDE channel. If you have 2 of one the computer won't know what it is supposed to be doing with the drive.
Apr 18, 2012 | MSI Computers & Internet
How to hook to computer
Hello
I am assuming it's an internal drive for a PC and not a Laptop.
Here is a nice illustrated guide to install an older IDE version:
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=lpg40238&lc=en
For Sata you don't need to configure any jumpers just connect the Sata cable to the spare port on the motherboard and the other end to the drive also don't forget to connect the power cable too.
you cannot connect IDE cable to Sata and vice versa.
Hope this helps.
Feb 27, 2012 | EZ Dupe Computers & Internet
My Tiny 755C10 laptop has 44 pins slot and standard ide hdd has 47 pins. what can I do to fix it?
Standard IDE (PATA) HDD connection is 44 pins for a laptop.
(40-pins for a desktop IDE harddrive. Only 39 are used, though. One pin is removed)
http://www.av8n.com/computer/htm/disk-pinout.htm
What manufacturer, and model of HDD, do you have that has 47 pins?
(48 with one pin removed?)
http://pinouts.ru/HD/Ata44Internal_pinout.shtml
SO, the question is,....what is that 47-pin Harddrive?
Post back in a Comment.
Regards,
joecoolvette
Jan 28, 2012 | Computers & Internet
How to download c++
What you want is called an integrated development environment or IDE. An IDE will give you the C++ language compiler and a graphic interface for writing your code, compiling and running your programs, and figuring out problems when things don't work (bug-hunting). Some commercial products are out there, but there are several IDEs available for free.
I use DevC++ 4. They have a new version 5 available in beta if you want to try it. The don't list Vista and Windows 7 as supported so it may not work on those systems. (I still have XP.) A couple more IDEs you can check out are CodeLite and NetBeans. Both of those say they'll work with Windows 7.
Set yourself up with one of these and you'll be coding in no time. Time for coffee! Good luck and thanks for using Fixya!
Jul 01, 2011 | Computers & Internet
I replaced the power supply but not sure I have all the connections correct. Don't want to plug it in until I get it correct, is there a diagram of where the plugs go?
this will depend on HARD DRIVE whether ide the ide will have 40 pins or sata the sata will have 8 copper slat type also PSU power supply unit ide or sata power connecters these days they usually supply both next MOTHERBOARD if has ide and sata plugs the ide will be a flat ribbon type with 40 pin plug ends the sata will be 8 copper slat type usually a bit thicker
hope this helps
Jun 09, 2011 | Computers & Internet
Looking for sparkplug gap and the settings for fast ide and slow ide screws
Hi, sparkplug should be .8mm or 30 thou. Low one and a quarter, high one. Then adjust idle screw to suit. Hope this helps, regards Phil.
May 04, 2011 | Black & Decker Garden
My intel dh55pj mother board dont have a ide port, how can i connect my old ide hardrive in it?
if you insist on using the old hard drive you can buy pci IDE card which give you two IDE ports , but in my opinion i see the better to sell your old hard disk and buy another new on it will be better than the old and faster
if you see that is helpful please don't forget to vote me
best regards
Apr 23, 2011 | Computers & Internet
Wish to change the HD for HP D5100 SFF
For Changing the HD do the following
1. Take the Backup of all the required file from the HDD to DVD or tapes
2. Shut down the system
3. Remove the power cables first
4. Remove the side cover of the CPU
5. Carefully remove the HDD Power connector and IDE Cable or Sata Cable
6. Un Screw the HDD Screws
7. Remove the HDD Carefully
8. Place the New HDD and Screw it carefully.
9. Plug the Power Connector of the HDD and IDE Cable or Sata Cable
10. Plug the Power cable and check that the HDD Is detected.
11. If detected install the O/S as required by you
12. If not detected check the HDD Power connector and IDE Cable or Sata Cable
Let me know that i Fixya! the problem
Thanking you.
Nov 27, 2010 | HP Compaq dc5100 PC Desktop
Ide slot not working
sounds like you have a bad controller. You should have a primary ide controller that is noramaly used by the hard drive, then a secondary used by the optical drive. Try putting the DVD drive on the some ide cable as the hard drive.
Mar 23, 2009 | Intel D946GZIS Motherboard
SCSI and IDE HDs, can they work together?
This next solution is viable in win 98, and I don?t see any reason why it shouldn?t work for you too. If you know of anything I?m missing you should consult someone else. The solution is slightly complex, so I hope I can explain it properly: 1. Create a startup disk so you can format and install windows. 2. Set the new HD as master and connect it to Primary IDE. 3. Disconnect the SCSI and remove it. 4. Restart the computer with the disk you created (with the new HD connected). 5. Go to the Bios settings in order to make sure that the computer does recognize the new HD as the primary drive in the first IDE. 6. Now, FDisk the new HD, set the partitions, restart and format it. Install the OS and make sure it is working properly. 7. Insert the SCSI and restart again. 8. At this stage the computer would reboot into the IDE and see the SCSI/ You may have to change something in the OS settings for that, but I don?t know where. Good luck.
Feb 22, 2006 | Adaptec SCSI 29160 POWERDOMAIN MAC KIT...
Poulan Pro PP4620AVX 46cc Gas Chainsaw With 20" Bar Logo
65 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
