Question about Ryobi Cultivator
Where can i get the gears in the ryobi 220029004 assembly
I have a Ryobi mitre saw EMS 1442L that has a stripped output assembly gear. According the parts listing this part is no longer available. Does any other model part fit this?
it may be worth investigating if later driven and pinion gears will fit the shafts of your unit
It is a way that ryobi has of making older unit obselete
if you research the gears by shaft size , number of teeth diameters thickness etc you may get something but look for matching gears and not just the stripped gear
you may get gears from another manufacturer/model to suit
Dec 13, 2017 | Ryobi Saws
Where can i buy a new complete line trimmer assembly for a Ryobi grass scorpion RTC2500 trimmer?
Hi Gary,
You may already have found what you are looking for but if not, here's a site that will help:
http://www.ereplacementparts.com/ryobi-trimmer-parts-c-7931_15633.html
Good Luck!
Jim
Feb 09, 2016 | Ryobi Garden
How to assemble a ryobi petrol pole pruner
Not knowing what model number you have, I have attached a link to the Ryobi RY43160. This is the manual for this specific product.
http://manuals.ryobitools.com/system/files/6679/original/RY43160_750_trilingual_01.pdf?2011
It does give you an exploded view of assembly on page 11. I hope this may be of some help to you.
In the event this does not help, you can always call the Ryobi help line at 1-800-860-4050 or try www.ryobitools.com
Oct 18, 2014 | Ryobi Garden
Ryobi reciprocating saw motor rund but blade doesnt
A Ryobi might not have that nut. They are likley a ring gear drive which is different. I'd open it up and look at the gears. Make sure no teeth are missing and that none are worn down. If they're worn they would probably look rounded. If the gears are bad the saw is more than likely not worth repair. Ryobi saws are not very expensive compared to the cost of repair parts.
Mar 10, 2014 | Ryobi Rj165v Reciprocating Saws
Clutch adjustment on ryobi reciprocating saw # rj160v
The Ryobi RJ160V does not have a clutch, it has a direct drive system: the armature has a gear pressed on the end of it that turns a bevel gear with an off-set pin on it. This pin fits into a slot on the end of the saw bar assembly which is what you attach the blade to. If you have slipping it could be stripped armature gear teeth or bevel gear teeth or both or the pin on the bevel gear is broke off.
Feb 21, 2012 | Ryobi Saws
How do I remove the clutch rotor assembly on a ryobi 720r?
I have the same model, I inserted a large screwdriver on the inside to stop the rotor assembly from spinning, then I used a pipe wrench (but channel lock pliers would probably work better) and then w/o much effort, I easily turned the wrench counter clockwise to loosen.
May 01, 2010 | Ryobi Garden
Ryobi 40cc chain saw, pull cord won't turn engine
If it has ball bearings in the rachet mechanism they may be sticking and need cleaning so they move freely.!
Aug 14, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Compound Mitre Saw Motor turning, spindle isnt.
I have went to 3 different sites and cannot find the model number listed on them, I did look at a Ryobi saw and they indicate it is an assembly. but before I did that I would try and removing the gear from the spindle. It is possible that when it spun it put a burr in the parts and you would have to use a little extra effort to remove them I would suggest going to a repair shop and having them press them apart and see what you canfind that way. Sorry I couldn't find more for you
Jul 30, 2009 | Ryobi Saws
Ryobi Cultivator Logo
52 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
