Question about Homelite Mighty Lite Lawn Trimmer
My MightyLite 26cc trimmer won't start. It has fuel and a brand new spark plug. It's only 1 year old and I've always had problems starting it and keeping it running. Any ideas?
    President:
  • Homelite Master
  • 1,545 Answers
The possible reason it has always been hard to start is the way the settings on the carburetor were initially made at the manufacturer. Elevation and climate affect these sensitive carburetors but the lower grade manufacturers use a "default" setting on the carburetors. I would say a small carburetor adjustment and mild cleaning (if it has sat unused any length of time) will help the starting issue. Try adding a 1/2 ounce to 1 ounce amount of fuel system cleaner into your 2 stroke fuel can. I recommend Chem Tool Berryman B-12. It has the necessary ingredients to help clean built up gum and varnish in the carb and in the engine. The recommended rate is 1 ounce per gallon of gas, so use about 1/2 ounce in a gallon or 1/4 ounce in a half gallon.
As far as adjusting the L and H mixture screws on the carburetor, first you have to be able to get ahold of them. They are made so you can't. I use a small automotive type plastic wire connector tapped down onto the head of the screw so I can then turn it. I know the heads aren't slotted, or are splined or are D-shaped. I suggest resetting the carburetor adjusting screws to alleviate a hard start issue and a mild cleaning of the carb (through it's own fuel system) to aid in cleaning it up. Here is the manufacturer's suggested methods for setting the mixture screws on your carb.
http://www.zamacarb.com/tipspage.html
Posted on Apr 09, 2011
I have a gas powered trimmer .Model ut21566/serial no. atki713420. Dated 6-20-07. 26cc. 7hcps0264aj.Used brand new 6 times. Will not stay running . I checked fuel mix ok. I purchased at home depot.If you...
Clean your carb and give it fresh fuel. Thats if you are getting spark. Can you give me a note so I can give it to my teacher so I can get back into school.
Aug 20, 2010 | Homelite Factory Reconditioned 26cc...
Homelite 21" hedge trimmer. Won't start. Has spark, compression, fuel (used a little starter fluid), checker spark arrestor and muffler (clear). I haven't torn it down to check the Woodruff key but it ran...
Abell, put a little drop of petrol in the plug hole, replace plug and give it a pull. If it fires up for a moment, it is a fuel starvation problem. Check the carb, clean and make sure the nedel valve in the bottom of the carb is not sticking. Good luck!
Aug 06, 2010 | Homelite Factory Reconditioned 26cc...
No spark on UTO 8580 A back pak blower
You could have a bad spark plug or ignition module.
I would find your receipt and find a warranty service center. Reconditioned unit only have a one year warranty on them. If it is in this time frame they will fix it for free.
Dec 18, 2009 | Homelite Factory Reconditioned 26cc...
Homelite trimmer zr40502
Do you have fresh gas? If so is the mix right? If you can get to the carb easy spray some carb and choke cleaner in it. Check the gap on the new spark plug. The gap should be located somewhere in the manual. The big problem is making sure that the mix is right. To much oil in gas will foul plug smoke like crazy and foul the plug and hard to start. Not enough oil and you can seize it up.
Good luck let me know if this helps.
roundo4
Aug 16, 2009 | Homelite ZR40502 Factory-Reconditioned...
Mightylite 26cc Edger
You need to disassemble the carburetor and spray with carb. cleaner. Use a Den Tek Brush,
(http://www.dentek.com/shop.php?target=products&product_id=7), to clean the small portals in the carb. Make sure to clean the small screen in the carb. as well. Reassemble and start.
If you need further assistance, just let me know.
Jim
Jun 07, 2009 | Homelite Mighty Lite Lawn Trimmer
Engine runs but blade doesnot
The clutch is not engaging or the linkage to the eccentric that moves the blade is not connected.
May 26, 2009 | Homelite Factory Reconditioned 26cc...
Homelite MightyLite 26cc Edger won't start
You have to make sure the case of the plug is making good connection against the metal on motor. Use file or sandpaper to get good connection on the plug and the motor.
Mar 30, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
434 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
