Question about HP Pavilion dv9000z Notebook
I have a white monitor on my notebook, cooler and harddrive are still working. Maybe someone knows how to fix it and see again picture on monitor?
  • 1,179 Answers
It maybe a loose connection if our laptop uses a graphics card. In which case you would remove some on the covers to expose it and clean the contacts. Then reinstall it.
However the problem may be a bit more serious than that.
Hope its just a bad connection, try plugging a monitor into this laptop. If it works well then it is the laptop screen that is faulty.
damnor01
Posted on Apr 09, 2011
My laptop gets so hot ; and the cooling fan blows out really hot air.
Well I can tell you that in my experience they get real hot too hot in my opinion, however, these days the laptops seem to emit an enormous amount of heat, but it seems to do NO harm, If you are worried get yourself a laptop Cooling Pad, they are cheap, they work, and will keep your unit cooler.
Jul 10, 2010 | Toshiba Satellite P305D-S8828 Notebook PC
Distorted picture on Sampo 42" monitor
This can occur due to many reasons...the simplest of those is...
Damaged monitor signal cable...results in improper signal transmission
Also check if ths is a problem with the monitor or VGA card...Just connect it to another computer...If it works then its VGA card problem otherwise its a monitor problem.If you are good in electronics then the problem is
1)You have the typical convergence failure of the convergence correction IC's which need to be replaced
2)Cpacitors on the CRT are damaged and need to be replaced..
If you are not familiar with electronics pls dont attempt a repair as it is a high voltage device and the risk of electric shock wil be high.Just drop into a service center if this is the case
Oct 12, 2007 | Sampo PME-42S6 42 in. HD-Ready Plasma...
Going to sleep
Problem not in your monitor, but in your videocard, I've got the same. Your videocard overheats and your monitor shut down. You need to check cooler on your videocard. Maybe it full of dust. Sorry for my bad english) hope it helps to someone.
Jul 04, 2010 | Samsung 760BF (White) 17 inch LCD Monitor
Monitor white screen
White screens are caused by one of two things, either we have a bad power supply or a blown fuse on the lcd panel. To check the power supply section you can go to the site: www.ccl-la.com/badcaps.htm U can see pictures of what to look for. If you see any that look like the parts in the pictures replace them.
I hope this has been helpful
Good Luck & Thanks,
Shiv
Aug 17, 2009 | Computers & Internet
Starlogic 19 inch monitor gets unreadable screen
Is this monitor a CRT-type? Chances are your picture tube is malfunctioning. This is a common error among CRT monitors. I advise you to replace the monitor with an LCD, as the power consumption is far less than CRT. Plus, it takes less space.
If you prefer a repair option. have someone "flush" the tube. This may fix the problem.
Mar 15, 2009 | Computers & Internet
The display samsung t240hd monitor randomly/intermitently loses sharpness. Goes from a perfect hd picture to a analog type picture. White space on menu bars in pc modes goes from a crisp solid grey...
Hi im josh in cebu phils. may i help? Friend your problem focusses on to hardware. first try to check your video card clean or change then after try to use the monitor.if it still appears the same. 2nd try to use your monitor in other pc.if still appears. the problem is your monitor. if you knew somebody around that could fix tv or appliances let him see your monitor.there maybe one of the capacitor in the monitor that is damage or burn out.let him change it. so that it will work again in condition. good luck.
Feb 17, 2009 | Computers & Internet
Monitor goes white??
This does sound like the cable, but it could also be the inverter. Here's a step by step to removing the screen.
http://www.screentekinc.com/lcd-removal-instructions_en,compaq,step5.shtml
Jul 26, 2008 | HP Compaq Presario V2000 Notebook
Computer not reading the hard drive
i have formatted the hard drive and put in all three recovery discs and it still won't load windows xp home edition.. i thought that was what the recovery discs were for.. maybe the hard drive is bad i don't know but if someone is having the same problem i could sure use some help here..
May 10, 2008 | Balance CN6555 Notebook
Screen completely white
dont warry,u just replace your lcd.
Apr 27, 2008 | Dell Inspiron E1505 Notebook
Power button stay on for 2 seconds, black screen,no picture
hi there, yes, you do have a broken monitor, bring it to qualified service personel how can repair the monitor. or you can just simply replace it. TY
Nov 29, 2007 | HP vs15 15"LCD Flat Panel Monitor
HP Pavilion dv9000z Notebook Logo
20 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
