Question about Dremel 220 Workstation 2" Drill Depth Rotary Tool
Dremel 220 workstation, I refer to the Extension Tube Assembly, part 2610921736, consisting of two telescoping tubes. The inner tube has three plastic parts at the bottom. These are not illustrated nor referred to in the instructions. What are they for? How/where are they to be assembled? Next question: How do I set and secure the height of the inner tube?
5 Suggested Answers
melnavz
  • 1226 Answers
SOURCE: Dremel 395 Type 2
hello,
try to find it here:
http://www.powertoolspares.com/parts2.php?model_ID=3057
may this help.
melnavz
Posted on Jul 23, 2008
philschneide
  • 448 Answers
SOURCE: Stripped plastic coupler on output shaft of Dremel model 277
I'm guessing, but I think that the Sears tool uses the same flexible coupling. If you go to www.searspartsdirect.com and put in the model 572610031, you can look at the diagram and decide for yourself. I think the part costs $2.57. If it's the right one, I'd order two or three for the future.
Hope this helps.
Posted on Oct 06, 2009
  • 1015 Answers
SOURCE: I need a replacement switch
I must apologize I have searched all parts manuals that I have access to includeing google and all i can find is the 300-N55 is no longer available and switches are obsolete.I also couldn't find any parts to sub for it. Sorry.Hope I can help you in the future. Thanks.
Posted on Nov 08, 2010
REFERENCE M/N: 395 - Type 3 - Dremel does not have the parts listing on their site for some reason. I actually have the original I saved from 1988!
The part number for the Nylon Coupler is:
Illustration Code Number: 5
Description: Flex Coupling
Part Number: 529430970
This is all from Drawing (Form) Number:5296074 10-88
Posted on Nov 29, 2011
Does the 220-01 Dremel workstation fit the 4200 dremel ??
Yes it does. If you have any questions call Dremel hot line. They're sharp.
More details Complete Dremel Workstation 220 Review
Mar 15, 2018 | Dremel Tools & Hardware - Others
How do I attach telescope tube to eq dovetail mount?
You first have to get 2 tube rings. These must be the right size for your scope.
http://www.optcorp.com/orion-116mm-id-orion-telescope-tube-rings-7372.html
They will have hinges and clamp screws and at least one other hole for attaching to a dovetail rail. Then you need a rail, sized appropriately for your scope. They come in several lengths and 2 geometries, Vixen and Losmandy. Almost certainly you will need the first one.
http://www.optcorp.com/aa-vdup11-vdup11-vixen-style-11inch-dovetail-universal-plate.html
There are some scopes with very fat tubes, like Schmidt-Cassegrains, where the rail attaches directly to the tube fittings.
http://www.optcorp.com/celestron-c6-a-xlt-schmidt-cassegrain-optical-tube-assembly-91010.html
Dec 16, 2015 | Optics
Washer spins loudly and seems to free wheel and other times does not drain properly
Check the motor to transmission coupling, probably broken.
Also check the inner basket drive block. The drive block is attached to the top of the spin tube-basket drive assembly under the inner basket. The spanner nut is under the agitator, locking the basket to the spin tube. The drive block has two slots that lock onto the two ears of the spin tube. Replace the damaged drive block, and/or replace the basket drive/brake assembly.
Nov 15, 2013 | Whirlpool LSB6200KQ Top Load Washer
3200 obitor ... assembly
Do you have a manual? If your telescope is a refractor (long narrow tube with a lens at the front and eyepiece focuser at the other end) then maybe the following manual for the Orbitor 1208ss will be helpful.
http://www.manualslib.com/manual/222805/Orbitor-Or1208ss.html?page=4#manual
If your telescope is a reflector - has a mirror at on end and a focuser on the side of the tube at the other end then maybe the following manual for the Orbitor 6000 (Model 9000) will be helpful.
http://www.fixya.com/support/p3037-citiwell_international_orbitor_5500/usermanual-3FA8CDD-pdf
Good Luck,
walt
Sep 09, 2013 | Citiwell International Orbitor 5500...
Replacement rear wheel of quinny buzz
You can buy tyres off ebay at about £9 each. inner tubes are very cheap on there as well. Check out local bike shop as they might be cheaper.
Jul 26, 2010 | Quinny Buzz Three Wheel Stroller
Kenmore dishwasher has stopped draining.
remove the kick panel below the door, place a pan, etc under where the drain hose connects to the drain extension tube, and slide the clamp back some so you can slide the hose off of the extension tube (white plastic tube) and drain any excess fluid into the aforementioned pan, etc., then unscrew the extension tube and check for plugs, or restrictions.
the sump may also be pluged beneath the strainer assembly, and that requires removing the lower spray arm, the water tube that runs up the inside back of the unit, and the upper parts of the assembly below them to access the drain/pump sump area.
last but not least the impeller is jamed and might be able to be freed by removing whatever has lodged within there..
ya never know...
best of luck,
ttfn
Oct 25, 2009 | Kenmore Dishwashers
Where can i buy a spare back wheel or inner tube for a Quinny Buzz 2005?
You can buy a 10 inch inner tube from most cycle shops. This does just fine.
Apr 11, 2009 | Quinny Buzz Three Wheel Stroller
2005 Dodge 1500 code p0404 EGR valve.
The electronic EGR valve and solenoid assembly is attached to the rear of the left cylinder head ,
  1. Remove electrical connector (5) at top of EGR valve solenoid.
  2. Remove tube mounting bolt (1) at intake manifold.
  1. Remove two bolts (4) connecting EGR tube (1) to valve assembly.
  2. Remove gasket located between EGR tube flange and EGR valve assembly.
  3. Remove two EGR valve mounting bolts (5).
  4. Separate valve assembly (3) from engine.
  5. Remove and discard metal gasket located between cylinder head and valve assembly.
INSTALLATION
  1. Clean area at rear of left cylinder head where it joins base of EGR valve.
  2. Clean EGR tube where it joins EGR valve.
  3. Position new gasket between EGR valve and cylinder head.
  4. Position EGR valve to cylinder head. Install and tighten two bolts (5). Refer to Torque Specifications.
  5. Position new gasket between EGR tube flange and EGR valve assembly.
  6. Position EGR tube (1) to side of EGR valve and into intake manifold.
    1. Install EGR tube flange bolt (1) at intake manifold. Tighten bolt. Refer to Torque Specifications.
    2. Connect electrical connector (5) to top of EGR valve solenoid (2).Do a final tightening of two EGR tube bolts (4). Refer to Torque Specifications
Feb 05, 2009 | 2005 Dodge Ram 1500
Can't bring reflector telescope to focus.
Orion UK has a very good reputation so I'm surprised you are having a problem. However, I see they are offering this with a Crayford focuser. Most Crayfords have a lower profile than traditional rack and pinion types and they may have failed to realize this could effect back focus. If the scope is new I'd talk to them. If not, find a 2" long by 2" diameter focuser extension tube.
If it does have a traditional rack and pinion focuser it may be missing the extension tube. Many of this type have a threaded on extension tube which is used for visual work and removed for use with a 35mm camera. The solution's the same.
Dec 30, 2008 | Optics
Dremel 220 Workstation 2" Drill Depth Rotary Tool Logo
115 people viewed this question
Top Dremel Drills Experts
richie46
Tom Chichester
Are you a Dremel Drill Expert? Answer questions, earn points and help others
