Yes Dear i got the problem. It may occurs for Two Reasons. Just follow the instructions what i will instruct you.
First, Please check your IDE Cable which is connected with your Hard disk. And now check your connector any pin is displace or not. if any pin distort then strait the pin. if Not then you can try by changing the IDE Cable.
Second, The only way is to format your windows drive. that means which drive contains windows, it can be C or D or more on. Please don't partition your hard disk. As a result, Your all data will be lost.
Before Format your Windows you can recover your data which is too much important for you. This is just simple for anyone. Please use XP Live operation system. This the incredible software i have ever found. It just create a temporary boot file whether you can access your all drive. just copy or cut your important files to another disk or removal disk. Finally format your windows .Thanks a lot
HI FRIEND YOUR PROBLEM IS THAT YOU NEED TO FORMAT YOUR NETBOOK AND SET UP THE WINDOWS FROM THE BEGINNING. MOREOVER, YOUR HARD DISK MIGHT HAVE A PROBLEM AND YOU MIGHT NEED TO REPLACE IT AND THEN YOU SHOULD FORMAT YOU NOTEBOOK . I BELIEVE THIS SHOULD WORK
