Question about HHP Dolphin 7450
HHP Dolphin 7450 - Unable to Sync with PC
I've been trying to establish a partnership with active sync v4.5 on windows XP via my com port (COM1) to the 7450. The baud setting is 57600 on the home base station. I have and rs232 straight through cable and have already establish that I can communicate to it using a hyperterminal connection. The sync setting on the 7450 is set to direct57600. Active sync does not recognize the device. Any ideas. The documentation in the manual is self explanatory.
4 Suggested Answers
shaggy067
  • 56 Answers
SOURCE: device no detected in COM1
some pads like that work fine on old computers but with the new update from microsoft things like that pad cant be run on new things like the SP2 on windows see if windows sees that it is a pad. any software for it should work on WIN XP
Posted on Nov 08, 2006
SOURCE: COM Port issue with 4600 and 4800
You tell Pip to put back on the K/B wedge and make programers - u know program it to work [8^) lol
sorry for the false positive
Posted on Sep 17, 2009
SOURCE: I have a HandHeld SCANTEAM
Good morning, I have the same adapter the Scanteam 2070 and I would need thedriver software to see if you could pass me by e-mail or web page point me where I could download.
For any answer let me know by e-mail: cfgsjacksonmora@gmail.com
A greeting.
Posted on Apr 02, 2011
How i connect to pc my HTC S 710 Mobile?
If your PC has Windows XP, you should have ActiveSync installed and running, in order to have a WM smartphone synchronized. Otherwise, if it has Vista or 7, WMDC should be used instead.
If you already happen to have the correct sync program on your PC, and yet, are unable to sync your device, firstly, reboot both your PC and device. If you keep unable to sync, try to remove the partnership between your PC and your device on both of them, and try to connect your device again. If the failure persists, try to uninstall and reinstall ActiveSync (or WMDC), reboot your PC and try again.
Hope you are able to sort your problems out.
Cheers! Carlos
Apr 24, 2010 | HTC S710 Smartphone
Cannot sync, connot create relationship (no active
if u've windows 7,try windows mobile device center.also try using different USB ports 4 partnership.
Mar 16, 2010 | i-mate K-jam Smartphone
Com 1 port
Yes. com1 Should be labled Serial Port on the PC.
Feb 09, 2009 | E-Machines etower 500is PC Desktop
Ipaq 4700 active sync problems
i can try to help you , first are you using xp or vista ? and which version of active sync ? i found that after upgrading to active sync v4.5 my ipaq 4700 refused to sync , i have xp home , so by trial and error i learned several things , i tryed my usb cable in every usb slot i had , only to find some usb ports are more friendly to certain devices , for a lack of better terms , i deleted all partnerships in active sync , found that i needed to make sure active sync is not running on ipaq , go to settings / memory / running programs on the ipaq , stop all running programs , turn the ipaq off , then on the pc made sure firewall not locked , plug usb cable into pc , i leave mine in a port permanently , plug into the ipaq , it automatically turns the ipaq on , then i see 2 icons in pc system subtray start blinking , at that point i know sync is going to work , then active sync icon starts turning , lit up in green , and asks do you want to create a partnership , yes , follow prompts , and thats what has been working for me , now if i was to put the usb cable into a different port , no doubt it would give me grief , and the same thing with my phone and active sync , make sure active sync is not running on the device , sometimes i have to reset the unit , ipaq or phone , make sure unit is turned off them make the connection , give it a try .
Jan 02, 2009 | Computers & Internet
PC/PDA "connected" yet PC won't read PDA
Did you tried installing the ActivSync again, for Windows XP the version is 4.5, for Windows Vista is 6.0, Try installing the AS
Feb 02, 2008 | HP iPAQ H3955 Pocket PC
HP iPAQ 4150 battles Vista -- HELP
The Microsoft Windows Mobile Device Center requires that the first sync be made via the USB sync cable. After the h4150 is plugged into the Vista machine, the WMDC opens and prompts you through setting up a partnership. Then you can set the h4150 to sync via Bluetooth.
ActiveSync works fine with Vista. Ignore that other guys post.
Nov 29, 2007 | HP iPAQ H4150 Pocket PC
Jornada 680 won't sync over network
Hi. Put your desktop ip-address into your network card wins-address field (on your Jornada) Works for me :)
Sep 12, 2005 | HP Jornada 680 Pocket PC
Problems with installing Active Sync on Windows xp.
Do you use companion CD for Active sync installation? Can you please tell me which driver is necessary to have? Is there any error message and what is content of this message? It can also be that Active Sync is already installed! Please check at Add and remove Software in Control panel! Otherwise go to www.microsoft.com and download a current version of active sync
Sep 11, 2005 | Toshiba e400 Pocket PC
Cassiopia EM500 sync issue
First of all ensure that the port selected on the EM-500 for PC connection is the same as your actusl connection - i.e. USB or serial. There were some problems with the EM-500 cradle which would not allow communication to be established between the PDA & the PC/Laptop. Contact Casio for rectification. It is done free of charge.
Sep 06, 2005 | Casio Cassiopeia EM-500 Pocket PC
EM-500 sync problem
There have been issues with the cradle PCB on the EM-500. Casio has redesigned the same added an IC & a few additional componentes. I had similar problems & simply could not connect through the USB port. Worked flawlessly with the accessory serial cable (direct connection - no cradle ). This also was on an XP system. See if you can wangle out a free replacement/fix for yout cradle from Casio.
Sep 05, 2005 | Casio Cassiopeia EM-500 Pocket PC
HHP Dolphin 7450 Logo
353 people viewed this question
Top HHP Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Don A
Don A
Are you a HHP Computer and Internet Expert? Answer questions, earn points and help others
