Question about Poulan 30cc 2cycle Backpack Blower
What is the proper spark plug for a Poulan Pro PPBP 30/30cc Blower Model BL30711971
2 Suggested Answers
bulldogchief
  • 388 Answers
SOURCE: what type spark plug for the Poulan Pro PBV 200 LE
RCJ6Y is the plug number, you can get them at any home improvement store for about $3
Posted on Sep 11, 2009
How to clean carburetor poulan pro ppbp 30/30
buy a new one on ebay for 20.00,save time and hassle,replace lines too
Jun 24, 2015 | Poulan Garden
My poulan-pro leaf blower
Does it start if you spray starting fluid into the air cleaner? Try it and let me know.
Oct 30, 2008 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
What spark plug does a poulan bvm200vs blower uses
Go to manualslib.com put in your model number and you can pull up a manual on your model and in spec. sheet it will show you the plug number. Hope this helps.
Jun 11, 2014 | Poulan Pro Gas BlowerVacuum ()
Can't start poulan ppbp 30 cc gas blower
At all? Check the plug to see if it's wet. If so you are getting fuel so problem is spark. Get a new plug and gap properly. What else have you tried?
May 06, 2012 | Poulan Garden
Proper spark plug gap for poulan chain saws
I believe the proper spark plug gap for poulan chainsaws is .025-inch. That goes for all units.
Aug 22, 2010 | Poulan Pro Chain Saw 46cc 20"
What type spark plug for the Poulan Pro PBV 200 LE
Sep 05, 2009 | Poulan Garden
My Poulan Pro 200 model #200pbv200le will not start.Replaced the carb, fuel, fuel filter,plug. When I pull the cord sometimes I see a spark, sometimes- most of the time I don't see a spark.Replaced fuel
Check your compression...if it reads anything less than 100psi you need to tear it down and replace the piston ring. Looking for the spark is unreliable, get an in-line spark checker and check for spark. Loss of compression due to a stuck piston ring is very common in the pbv200 series.
Aug 31, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan bvm pro 200 gas blower not getting gas
As a service center for Poulan products the usual problems for not starting I see is compression or the cylinder has come loose from the crankcase. Compression needs to be 115 psi minimum. If you remove the plastic muffler cover you can see the cylinder-crankcase joint. Wiggle the spark plug to look for any movement at that joint. If there is any movement the cylinder screws are loose.
Poulan has an excellent 2 year warranty and any service center should be happy to repair it under warranty for any problem.
Sep 22, 2008 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan 30cc 2cycle Backpack Blower Logo
447 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
