Question about Gateway (5502572) DVD±RW Burner
Wont come ,seems to have disappeared - Gateway (5502572) DVD±RW Burner
  • Gateway Master
  • 27,725 Answers
Make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Apr 09, 2011
My 1999 cavalier ran hot coolent seemed to disappear now it wont start
quick easy check is to pull the plugs.
the clean one would be where the problem exists.
usually the head gasket gives out first to prevent damage to the head.
on occasion the head becomes damaged.
if all plugs are the same then the problem is in the heater system.
check all hoses and see if you can smell coolant or see any wet spots.
the no start situation could be lack of compression.
or try taking 1 plug out and watch for any spark. this has to be done in the dark or you could miss the spark.
the spark pack is next if no spark then test by swapping with a known good one.
Feb 27, 2013 | 1999 Chevrolet Cavalier
Harmontec 210 dvd/tv When you turn it on it has a red paddle lock in the bottom right corner and it responds to nothing but on/off. The lady says she just bumped the remote a little and it went right into...
If the remote has a "Music" button press and hold this until the lock disappears. If the remote does not, press the "Display" button until the lock disappears. This seems to work with almost all of them with this problem.
Jul 27, 2011 | Televison & Video
My boosh dishwasher is stuck in rinse and wont drain, but when i press cancel on the washer the water drains.... whats causing this????
There is a chronic problem with Bosch dishwashers where the heater relay is soldered to the printed circuit board becomes loose (actually it seems like the solder just disappears from the connection).
You may also note that the timer seems to get stuck and will not advance.
Remove the top front panel, the circuit board is on the right side as you face the dishwasher. You need to re-solder the heater relay terminal.
May 26, 2011 | Bosch 23 in. SHU303 Built-in Dishwasher
All the things i download wont show up. once its done downloading it just disappears like it was never downloaded
Seems you ticked/checked the box close after downloading is finish. Please unchecked the box. And let us know.
Thanks for joining us.
Good Luck
Jan 10, 2010 | Computers & Internet
The channel number wont disappear.
Most TVs have a "display" button on the remote that controls the on-screen display. Keep pressing it and the display should finally go away. Depending on the brand and model, the screen may cycle through a number of different displays first, but should finally clear.
May 03, 2009 | Televison & Video
The loading 'logo' wont disappear. pls help.
Press and hold the power button. After a few seconds, the MAcBook will shut down.
Regards,
Cybernanga
May 02, 2009 | Apple MacBook Air
ASUS P5PE-VM Sometimes no video display but audio goes on
may be power save mode enabled, disable that and check it
Mar 31, 2009 | ASUS P5PE-VM Motherboard
Wirless not working
I"m almost sure that I answered this one already..
Mar 11, 2008 | HP Compaq nc6320 Notebook
Locked keys
Hi. I have a different Jwin model radio to yours, but they might have this in common: is there a 'hold' button on yours? If so, this is used to 'lock' all the buttons so that you don't switch it on/ change stations etc accidentally. Look for a 'key' symbol on your display, and press AND HOLD the 'hold' key until the symbol disappears. Pressing the 'hold' button briefly will make the symbol re-appear, and lock the keys again.
May 18, 2007 | Jwin JX-M20 AM/FM Radio
Gateway (5502572) DVD±RW Burner Logo
32 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
