Question about Eizo Computers & Internet
I have hooked my mac book pro (13 inch) up to it correctly with the DVI-DVI-MDP connection and the monitor (coloredge cg210) will turn on only to say Signal 1, Signal 2 and a bunch of zeros. It then goes dormit. The problem doesnt seem to be the moniter because I plugged it into my dads computer fine. My computer, however, doesnt seem to even detect the monitor. i'll go into system prefrences and displays but no displays pop up, it says that none are connected. Help!
SOURCE: I turn my monitor on and it displays BENQ and then goes to -No Signal Detected- Power light changes to
Posted on Oct 04, 2007
  • 300 Answers
SOURCE: "No signal detected" when LCD connected with DVI-D Cable
Thank you for providing your configuration details.
You have failed to specify wheather or not your LCD Display is under Warrenty.
Perhaps these simple trouble shooting procedures will get the job done.
1. use the DVI to VGA adaptor that came with your card
Plug in a regular CRT monitor to the Primary Display Output Port using the DVI to VGA adaptor
( either port can be designated as the primary by you )
I like to use the Port nearest to the motherboard as the Primary
2. plug in the your LCD monitor on Secondary Display port using your DVI cable
At this point you should be able to see your desktop on the Primary CRT Display
3. Go to the display properties and use the Nvidia Dual Display Setup Wizard
set both desktops to CLONED at a resolution of 1024x768 and set the refresh to 60Hz
which is default for most LCD displays , some have higher refresh rates , consult your user manuel
If the display resolution and refresh are set incorrectly for your CRT or LCD you will see
Signal Out of Range ( if the display has the ability to display that error message )
At this stage both displays should be showing a Windows Desktop
If you now see your desktop on both displays , you can now put the LCD on the Primary Port
No Signal Detected ( this means the display device is not receiving a signal )
If your LCD display is still displaying the error message
"No Signal Detected" after performing the trouble shooting proceedures
You may need to read the user manuel about how to enable DVI signal input.
If you are certan you have done everything correctly but still see only "No Signal Detected"
Your LCD Display may need replacement
Loch Hime :-)
Posted on Sep 14, 2008
SOURCE: TV won't recognize signal from a DVI to HDMI input adapter
I had a similar problem with a Mac Mini.  The problem was caused by a mix-matched resolution (the Mac tries to use 75Hz refresh rate, TV expects 60Hz).  The best solution I found was to remote into the Mac (I used and change the resolution on the Mac from a remote computer until the image appears on screen.
Process: 1) Connect Mac to a normal monitor and install the LogMeIn server (or other VNC type application) 2) Connect the Mac to the TV 3) Connect to LogMeIn from another computer (preferrably one where you can see the TV) 4) Go to Applications / System Preferences / Display 5) Change the resolution to your TVs native resolution, and change the refresh rate to 60Hz
Posted on Apr 29, 2009
SOURCE: No display on SyncMaster 710N
I used 2 resistor of 100 ohms (1/8W) to make one of 50 ohms. Like others instruction, just put the 50 ohms resistor between pins 5 and 6 of this chip and the problem is solved.
Posted on Aug 26, 2010
SOURCE: No signal input wen connected to the VGA port of
where is eizo monitor T 560 i -T fuse location
Posted on Jul 03, 2011
My computer monitor wont start up
try pulling out the power plug to the monitor and then plug back in and turn on monitor.
I am assuming you plugged the DVI cable back in to the correct port on the monitor and Mac Pro.
May 03, 2016 | Computers & Internet
I'm trying to hook up my Westinghouse L2410NM 24 inch monitor to my MacBook Pro. I'm using the DVI adaptor for my mac to connect to the monitor via an DVI-HDMI cable. My mac seems to detect the L2410NM,...
You need to change the refresh rate, some monitors operate on 60 Hertz, and others on 70 or 72 Hertz, try changing the refresh next to the resolution choices.
Nov 13, 2010 | Apple MacBook Pro Notebook
How do i hook my samsung spl300 projector to my mac book pro
You can connect your Projector with the Mac Book Pro; However the problem is, mac comes with a DVI connector and your projector uses a VGA one.
You need to buy a DVI to VGA adapter from Apple if you don't have one already. You can buy it from the local apple stores or an online apple store.
There are two types of DVI-VGA adapters available (Please check the below images and see which one fits your Mac and go for it). Apple DVI to VGA Display Adapter
Apple Mini DVI to VGA Adapter Once you decided which one you need, go to an apple store or online apple shop and buy one.
Hope This regardsNextDoorNerd
Jul 30, 2010 | Samsung Mac Notebook
Dvd on Mac to show through projector
Yes if you are using Mac Book or Mac Book Pro then to connect a VGA projector you need MINI DVI to VGA or MINI DISPLAy to VGA or DVI to VGA.It will solve your issue
Apr 08, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
How can I hook up MacBook Pro with Optoma 1690 Projector? Am I supposed to hit a certain function key to get Projector to see MacBook
You may need a certain connection (MiniDisplay Port to DVI, or MiniDisplay Port to VGA). If you're connecting to an HDMI-compatible projector, you'll need an adapter. You'll also need an adapter if connecting your MDP (MiniDisplay Port) to a DVI or VGA port. Here are some helpful links:
#1 MDP Adapter Video (YouTube)
#2 MDP to HDMI Adapter (RadioShack)
#3 MDP to VGA Adapter (Apple Store)
#4 MDP to DVI Adapter (Apple Store)
Mar 12, 2010 | Apple MacBook Pro Notebook
I want to connect my mac book pro to a series 4, 32" LCD Samsung?
You need a monitor cable that allows to you connect via component or HDMI/DVI
Those samsungs usually come with HDMI and you can buy a dongle for about 20-30 bucks that has the monitor plug for your mac on one end, and an HDMI out on the other. Usually it's only video though and not sound.
Feb 01, 2010 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
Bought and HDMI to DVI Cable, Not Fully Functioning
Your setup is probably in "extended" mode - if you move the mouse back in forth, when it leaves the Mac Pro screen you should see it on the external plasma monitor. You can switch to "mirror" mode if you want to see the same thing on both screens. Or put the computer into "sleep" mode, close the lid, connect an external keyboard and the plasma display and wake it up by pressing keys on the keyboard. Then you should see the desktop on the monitor.
Dec 23, 2009 | Televison & Video
I have a mac book and want to make my t.v. a monitor
It's not that awesome - it's a doddle. Just buy the correct video adaptor from Apple for your Macbookd and the appropriate cable for you TV.
Nov 10, 2009 | Apple MacBook Pro Laptop Computer with...
I can't get my mac to communicate with my sony bravia
Try going into system preferences, then into displays, and see if you can select another monitor to show up by selecting detect displays.
Apr 15, 2009 | Computers & Internet
How can i watch a dvd from my mac book pro through an hd tv ,
Open up System Preferences in the Apple menu, then go to "Display".
Make sure the monitor is connected, and click the "arrangement" tab. Check "mirror displays" OR drag the menu bar (white bar at the top of one of the monitor representations) from your laptop screen image to the desktop screen image.
Nov 22, 2008 | Apple MacBook Pro Laptop Computer with...
Computers & Internet Logo
Top Eizo Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
Jerry Umali
Raj Patel
Are you an Eizo Computer and Internet Expert? Answer questions, earn points and help others
