Aiwa 8100 amplifier, low output on left hand channel, need to turn balance control way to left.
    Brigadier General:
  • 8,546 Answers
Aiwa xx8100??? What are the missing letters? Maybe it's a source or preamp problem, eh?
I presume you have proven the channel is dead by trying multiple sources, swapping a different speaker onto it and that the balance control is NOT all the way to one side; headphones don't work either and we're down to proving it's dead before you take it in to a tech, right?
There is the slighest chance that a common control may have developed a high-resistance or 'dead' spot and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
If it still doesn't work you might want to prove if its a low-level signal loss or a high level amp failure. One way would be to run an RCA cable pair from the Tape Out to any other device (even a TV with speakers) you might have that accepts an audio input. If IT can't detect receive the DEAD Channel you
Posted on Apr 09, 2011
I don't know how to use behringer feedback destroyer DSP1124p
Determine where in the mixer's signal path to connect the unit. Your options are:
1. One or two individual microphone channels via the mixer's CHANNEL INSERT in/out jacks.
2. The monitor mix output via the mixer's MONITOR OUT jacks.
3. The main mix output via the mixer's MAIN OUT jacks.
  • 2 Connect a balanced cable with the appropriate connectors from CHANNEL INSERT OUT jacks on the desired mixer channel to INPUT RIGHT or LEFT on the Feedback Destroyer's back panel for individual microphone channels. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to that mixer channel's CHANNEL INSERT IN jack.
  • 3 Connect a balanced cable with the appropriate connectors from the mixer's MONITOR OUT jacks to the INPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel for the monitor signal path. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to the monitor amplifier INPUT jack or amplified monitor speaker INPUT jacks.
  • 4 Connect a balanced cable with the appropriate connectors from the mixer's MAIN OUT jacks to the INPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel for the main mix (FOH) signal path. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to the main amplifier INPUT jack or amplified house speaker INPUT jacks.
  • Oct 17, 2011 | Behringer Audio Players & Recorders
    Left hand channel low output. Need to turn balance control way to left to get correct sound stage. Is problem likely to be in preamp or poweramp sections.
    Name the make and model number first, then we'll get the manual. Then (maybe) a solution.
    Maybe run it by the manufacturer
    Apr 04, 2011 | Audio Players & Recorders
    My Aiwa Colour TV, model No. TV-A2019, has developed audio problems. 1. The audio output from the speaker is high even when volume is set at level one. Audio output is constant for volume level 1 to...
    You just come aroung the sound decoder section of your tv. Decoder problems may cause the fult you pointed out. Since all the controls are electronically controlled, and all are through sound decoder, which converts sound to stereo the problem must be there. Since sound comes from two channels are ok, there is no problem around sound output. Check for some soldering loose contact, wire socket loose cotanct also.
    Oct 14, 2010 | Aiwa F2000 20" TV
    Channels out of balance - remote will only change left channel.
    switch input cables and try this will confirm if the amp has a problem or the input signal
    Jun 19, 2010 | Krell KAV400Xi Amplifier
    One channel dead - Aiwa NSX-D5 (RX-N5K amp)
    When you put your headphones in does it switch off the speakers? If it does it could be a faulty headphone jack.
    Jun 14, 2010 | Audio Players & Recorders
    No sounds from the left speaker even with the balance turned fully to the left. all connection are fine.
    Check the speaker, switch the left and right ones and see if the left speaker still has no sound. If it works the speaker is bad, if it doesnt your left output is bad...
    Dec 06, 2009 | Sony TA-FE370 2-Channel Amplifier
    Where are the amps and how do i by pass them for the stereo
    The amps are located inside the radio. Most in-dash receivers that provide for "pre-amp outputs" also called "low level outputs" do so by providing female RCA type jacks. These are often found at the end of a short (4 - 6 inch) cable and are usually color coded red & white or red & black (some receivers provide a yellow RCA jack for video in / out, too). To use these RCA audio jacks, you need to realize that one jack is for the left channel source and the other is for the right channel source for a stereo signal. You will have to connect a compatible plug and cable of enough length to extend to a remote amplifier's RCA input jacks. The vehicle's speakers would also need to be connected directly to the same amplifier's output terminals. Using the two audio (left and right) RCA jacks will only allow the radio to control balance of the left and right audio, no fader (front and rear) control is possible. To get fader control, you'd have to either have a radio with four RCA low level output jacks (front L & R *and* rear L & R), or use the radio's speaker (or high level output) wires and connect them to the amplifier's speaker (or high level) input terminals.
    All unused receiver wires should be terminated in a wirenut or securely wrapped in electrical tape to prevent accidental contact with grounded metal or other wires behind the dash.
    I hope this helps!
    Nov 11, 2009 | Car Audio & Video
    NAD 302 stereo balance problem
    I would replace the output transistors of the bad channel and any very low ohm resistors associated with them.
    Whilst youre in there replace the electrolytic caps in the power amp section. Caps are cheap and plentiful.
    I dont know what the rest of the circuit looks like but there might be a need to balance the DC offset after replacing transistors.
    matelectronics.com and audiolabga.com carry many good replacement transistors.
    Dec 30, 2008 | Audio Players & Recorders
    Speaker output very high
    You can't control it with the balance control?
    Dec 03, 2017 | AMC Multimedia 3050a 2-Channel Amplifier
    Sound through one channel
    Only the right channel had a sound,the left channel is mute, whatever adjustment you did and whatever balancing you done nothigs happen,even you interchange the speakers. The problem is in the power amp. The STK IC there is busted already, it's better to change it with a new one so the performance become normal again.
    Jun 14, 2008 | NAD C372 Amplifier
    379 people viewed this question
     Grubhead
    Grubhead
