Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool Washer Model LSL9244EQO
I have a whirlpool Ultimate Care Heavy Duty Super Capacity Plus washing machine, model LSL9244EQO. The water was trickling in when I would first turn the machine on, but now it has stopped pouring into the machine all together. Can you help me solve this problem?
Water runs out the soap despencer
Posted on Apr 23, 2011
On a whirlpool cabrio drum at spin cycle knocks and wobles then shuts down a UL code comes up even when there is a light load and its even distributed
Posted on Mar 15, 2011
    Genius:
  • 1,028 Answers
Shut off water remove rear hoses pull screen from inside opening and clean ..BE SURE TO REINSTALL SCREENS..if still slow or stopped altogether replace fill valve..remove rear screws in console lift and roll console back unplug lid switch pop the clips on each corner up and off cabinet will lift off valve is top right side
Posted on Aug 07, 2008
My whirlpool ultimate Care II Heavy Duty Super Capacity Plus washer Very slightly agitates and don't spin dry
The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
Mar 21, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a whirlpool ultimate care heavy duty super capacity plus imperial 9 cycle washer and after bringing it home from my moms house in -20 weather after installation it leaks from bottom. What do i do
Hello mcc... It is possible with temperatures that low to have a water filled component freeze and crack. In order to determine if that is the case, go to searspartsdirect.com and enter your model number.
This will provide you with free schematics of all of the components of your machine. This way you will know what you are looking at when you pull the machine out from the wall, and inspect it. Joe
Thanks for choosing Fixya!
Jan 13, 2011 | Whirlpool Washing Machines
Find serial and model number
Normally on top load machines open the lid and look toward the back hinge area inside the lid. It is usually on the back there. It may also be posted on a white sticker on the back of the machine.
Apr 30, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Ultimate care supreme leaks underneath
First check the hoses to the machine. If they leak the water follows the hoses and drips on floor. Also check the hose connection at the washer. They will leak inside. Next it may well be a water pump going out or the plastic hose that is under pressure when operating. The pump is in the middle of machine underneth - Sorry - Good luck
Oct 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Old Washer won't spin or agitate
You found a belt? Most w/p washer do not have a belt they are direct drive. take off the pump and motor to replace the motor coupling, 2 plastic pieces w/ a rubber in between
Feb 15, 2009 | Whirlpool Washing Machines
Won't spin or agitate
coupling.between motor and gearcase.
Nov 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Heavy Duty Super Capacity Plus not spinning
HI thanks for the question . On your model thers is no belt it is a direct drive.IF the washer stoped pumping the water out in pump out then your problem is with the lid switch. The lid switch is located under the top Thanks for your question hope this helps you ,THE appliance doc
Sep 10, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator
if its a 2 piece agitator.. the gears in top of agitator is stripped out.. change gears be like new....spin top countor clockwise if it dont grap.. gears bad
Sep 28, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
856 people viewed this question
Dan Webster
Dan Webster
Sal De
