Question about LG Washing Machines
Why do you have to use H.E. detergent in front load washers?
  • LG Master
  • 2,699 Answers
Not as much suds as regular detergent and double the strenth,front load washers use less water than top loaders,if you use to much detergent the machine will keep filling and draining to try to get the suds out.also you should only be using 1/4 cup of H.E. detergent or you can damage the spider gear in the washer,you'll know if it breaks you'll hear the tub banging all around loudly when it's in final spin,the spider gear is made out of soft metal and the extra detergent eats at the metal
Posted on Apr 09, 2011
OMy front load LG washer is gushing water from the detergent dispenser!! Repair suggestions???
Some washers are designed to flush the detergent dispenser to eliminate residue after each wash cycle.
Feb 02, 2015 | LG 3.9 cu. ft. Front-Load Washer, Metallic...
Should I put powder detergent in the tray or in the drum in my Asko front load washer?
But the powder in the tray. I have a asko washer myself
You should to able to go on line and download your manual
Go to Asko.com Good Luck
Feb 12, 2013 | Asko W6461 Front Load Washer
What is HE detergents
Special low sud detergent designed for high efeciency HE machines.
Feb 08, 2013 | Maytag NFW7200TW Front Load Washer
Does kenmore recommend liquid or powdered detergent for front load machine
liquid is best as powder is mostly made of a "clay base" in its detergents??? yes i did say clay!
Nov 28, 2010 | Kenmore Elite 45986 Front Load Washer
What detergent do u use for this type of washer
you have to use HE High Efficiency detergent which is a low sudsing detergent, ERA , Tide makes one, do not use regular detergent which will cause too much sudsing and will void your warrenty, you will be suprised on how little detergent is used with a front loading washing machine compared with a top loading machine
Nov 08, 2010 | Kenmore Elite 45986 Front Load Washer
What is the partion insert for the washing powder container for?
Welcome to FixYa.
That is the Liquid detergent partition...P/N 8061633. ( part number )
**This from ASKO...
Because ASKO washers use less water than conventional top-loading washers, you need less detergent and fabric softener. We recommend that you use a low-sudsing powder detergent only, preferably a high-efficiency (HE) detergent designed specifically for front-loading washers.
**(Liquid detergents tend to suds more, which make them more difficult to rinse out.)**
Detergent - The amount of detergent needed varies, depending on the detergent you use. For high-efficiency detergent specifically for front-loading washers, you should use the amounts recommended by the manufacturer.
Also, the amount of detergent needed can vary due to differences in water hardness. (Refer to the Use and Care Guide for more details.) If you choose to use a liquid detergent, start out with a very small amount, such as one or two tablespoons.
Hope that answers your question, let me know please.Thanks for choosing FixYa for your repair solutions today. Let me know if you need further assistance.
Please take a moment and rate the solution provided for you as well as a testimony if you feel it warranted.
Good luck.
Regards,
Macmarkus :)
Oct 22, 2010 | Asko W6021 Front Load Washer
Is there a special detergent for front load washers?
yes there is to stop detergents from getting too bubbly witch would cause too much preassure for a front loader witch could cause damage always use front loading washing detergents
May 14, 2010 | Kenmore 43142 Front Load Washer
Type of detergent in front-loading washers
yes make sure the box of detergent says HE on it. and read the directions on the soap box for load size and amount.
Jun 20, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Washing machine
full of sudsy soap after cycle complete, no water ???sounds as if your using the wrong detergent, youll NEED to use an HE detergent (low sudsing)specifically designed for use with front loading washers
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
"Green" He Detergents Available?
Because all modern detergents work quite well with any application, that challenge would be totally up to you to make that selection.
Solution, detergents that produce low suds are better suited for front-loading washers.
Good luck.
Jul 26, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
67 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
