Question about Pentax Optio M10 Digital Camera
Is the Pentax Optio M10 compatible with a 4GB SDHC memory card?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Pentax Master
  • 102,366 Answers
No. The M10 works with SD cards, which are limited to 2GB in size.
Posted on Jun 28, 2011
SDHC 16 GB memory card compatible with Pentax Optio 450
No, you cannot use SDHC cards with the 450. You can only use MMC and SD cards, 2GB and smaller.
Aug 01, 2012 | Pentax Optio 450 Digital Camera
SD CARD is writer protacted 4GB L20
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
If that doesn't do it, try a different card.
Oct 19, 2011 | Pentax Optio M10 Digital Camera
I just put a new 4GB SD card into my Pentax Optio S4i camera. When I power it up I get the message "memory card error" Tried another card and got the same error message. Any...
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Jul 02, 2011 | Pentax Optio S4i Digital Camera
I have a pentax Optio E10 camera and put a 4gb sdhc memory card in but it doesnt respond when I switch it on - does this mean it is not compatible or is there a way of sorting the problem
The manual specifies SD cards up to 1GB. Cards bigger than 2GB are actually SDHC (SD High Capacity) cards and will not work in SD devices. 2GB cards may work; try at your risk.
Mar 11, 2010 | Pentax Optio E10 Digital Camera
Inserting either a 4Gb or 8Gb SD card results in a "Memory Card Error".
The S4 accepts SD and MMC cards. SD cards max out at 2Gb. The 4Gb and 8Gb cards are actually SDHC (Secure Digital High Capacity) cards, not SD cards, and thus will not work in devices designed for SD cards. Compatibility goes only one way--SD cards will work in SDHC devices but not the other way around.
Dec 27, 2009 | Pentax Optio S4 Digital Camera
Pentax Optio MX4 won't read my new SDHC 4gb
Does the camera work with any other card? Was the card formatted in the camera? Some cards from some manufacturers just don't work in some cameras.
Sep 12, 2009 | Pentax Optio MX4 Digital Camera
Optio E10: memory card error
if the cards work ok on something else then there's a issue within camera it could be the actual sd connector within the camera ? doess the camera support that size ? Optio E10 supports upto 1GB SD Card http://www.pentaxcanada.ca/pdf/o_manuals/om_OPTIOE10_e.pdf it might not work with the high speed sd cards ? Regards
Jun 15, 2009 | Pentax Optio E10 Digital Camera
Sdhc memorty card in a pentax optio e10 camera
The E10 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to use SD cards 2GB and smaller.
Dec 10, 2008 | Pentax Optio E10 Digital Camera
4gb Memory card error
In order to use 4gb memory your camera has to be approve for SDHC use.
If it isn't the most memory you can put into your camera is 2 gb
Jun 14, 2008 | Pentax Optio S50 Digital Camera
Pentax Optio M10 Digital Camera Logo
148 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
