Question about Samsung Televison & Video
I am trying to programme a PHILIPS TV REMOTE CONTROL Type SR 3004 to operate a Samsung TV. I had a Sky Remote Control which has malfunctioned. Do I need a Samsung Remote Control ? It is a SKY SYSTEM I HAVE.
  • Samsung Master
  • 11,800 Answers
Here you can find the user manual for your remote
http://www.p4c.philips.com/files/s/srp3004_53/srp3004_53_dfu_eng.pdf
In it the only code for Samsung tv's is 2448 so if after you have programmed this code the tv is not controlled it means that the remote is incompatible with the tv. In that case you should buy a new one - preferably the original one. If you can't find an original one an true universal one like
http://www.logitech.com/en-us/remotes/universal-remotes/devices/6812
will do just fine for all the devices you posses.
Posted on Apr 09, 2011
Sky remote code for model UE40J5100AK
Programming the remote control
To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Press "TV" again then enter the code for the TV listings below (Use the 4 digit codes from the left hand column), the red light will flash twice if a valid code has been entered. Press TV then the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote.
If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes below or continue with this process by continuously pressing "TV" then "Standby" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code.
If you are still unable to control your TV from the remote control see: Programming The Sky Remote or go to Sky's official website where you can see if a particular remote control version number will operate your make of TV, this can be found at:Skyplease remember to use your back button and come back to us.
www.electro-medical.blogspot.com
Samsung brand code 0060
3 digit code for Samsung
065, 584, 037, 245, 476, 398, 516, 292, 318,037
Oct 13, 2015 | Samsung Televison & Video
Need code for sky remote control for samsung model ps51d450 51inch plasma tv
Hello
Sky remote codes for Samsung TV are:
065 584 615 037 245 476 516 292 318 236 398 244 100 118 060 088
646
672
642
Follow the steps below
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
Aug 30, 2011 | Samsung Televison & Video
Sky navigtor tv code tv samsung
4. Input the 4 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
  • If this works try the other TV functions.
  • If these work then the correct code has been selected.
  • It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
Common Sky Remote Codes for your TV
Aiwa 0106
Akai 0098
Akura 0042
Alba 0043
Amstrad 0063
Baird 0117
Bang & Olufsen 0118
Bpl 0115
Beko 0125
Beon 0899
Brionvega 0147
Bush 0157
Crown 0225
Daewoo 0092
Decca 0244
Dual 0257
Ferguson 0293
Fidelity 0294
Finlandia 0296
Finlux 0297
Fisher 0154
Funai 0179
Genexxa 0330
Goldstar 0056
Goodmans 0335
Granada 0340
Grundig 0345
Harwood 0361
Hinari 0365
Hitachi 0145
Itt 0384
JVC 0053
Loewe 0442
Matsui 0477
Memorex 0037
Metz 0491
Minoka 0921
Mitsubishi 0150
Nei 0514
Nikkai 0528
Nokia 0536
Nordmende 0537
Orion 0549
Panasonic 0051
Philips 0081
Pioneer 0166
Protech 0595
Pye 0600
Roadstar 0625
Saba 0645
Saisho 0649
Salora 0651
Samsung 0060
Sanyo 0159
Schneider 0665
Seleco 0672
Sharp 0093
Siemens 0680
Sony 0000
Soundwave 0702
Tandy 0741
Tatung 0049
Techincs 0250
Telefunken 0757
Thomson 0771
Thorn 0772
Thorn-ferguson 0936
Toshiba 0156
Jul 06, 2011 | Televison & Video
What is the sky remote control for Samsung
Hi
Samsung
4 digits: 0060
3 digits: 065, 584, 037, 245, 476, 398, 516, 292, 318,037
Samsung (6000 series)
4 digits: 1340
As you used 0060 and it didnt respond please try to programma with the other 3 didgit codes.
If still you cannot programme it follow the below instruction:
1. To control your TV firstly switch on the TV set, point the Sky remote at the TV,
2. Press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice.
3. Continue with this process by continuously pressing "TV" then "Standby" then "TV" then "Standby" etc until the TV set switches off. This will start using the inbuilt codes to programme the remote.
Thanx
Jul 27, 2010 | Samsung Televison & Video
Remote code for samsung remote
0057, 0087, 0205, 0729, 0793, 0839, 0841, 1087, 3004, 3005, 3008, 3022, 3025, 3026, 3058, 3094, 3127, 3128, 3136, 3137, 3148, 3156, 3172, 3205
Apr 01, 2009 | Samsung AH5901169L Remote Control
Code to programme Sky Remote to operate new TV?
i have the same problem with the codes 0035 0125 0049 everything works except turning the volume up. have you found a solution yet???
Dec 31, 2008 | Televison & Video
SKY remote control programming
Try 065 - works for me on my universal remote.
Aug 24, 2008 | Televison & Video
Sky remote code
You will need to go to Sky's website and order a new remote if this doesn't work.
Press tv on the remote
press and hold Select and red until the remote LED blinks twice
type in 0 0 6 0
press power button on the remote, if the tv goes off press select and it should control all the tv functions.
if the tv does not go off press tv then power buttons on the remote and keep doing this until the tv goes off, then press select once the tv goes off.
Like I said earlier, if this doesn't work you will need to order a new/replacement remote via Sky's website then put the code listed above in.
Jul 18, 2008 | RCA RCR660 Remote Control
How do I get the volume to work on my sky remote control?
I've just done this, guided by SKY but all you really need to do it....
Press Interactive button on remote
Choose option 5
Then choose set remote control, it should give you instructions and the correct cde fo ryou specifc tv
Good luck
x
Dec 18, 2007 | ViewSonic N2060w 20 in. LCD Television
Televison & Video Logo
Henry  Thomas
Henry Thomas
