Question about PfaFF Creative 7570
On my pfaff 1470 sewing machinethe tention is not holding and a small plastic ring came out when I blew the dust out
    Scholar:
  • 41 Answers
Good Morning,
Unfortunately, if a part came out, it will be necessary to take your machine to an authorized Pfaff technician for repair. Depending on where the small plastic ring was located, new parts may be required and an authorized Pfaff technician will have the easiest access to these.
Hope this helps narrow down what's wrong with your machine and allows you to get it up and running quickly.
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
Posted on Nov 29, 2008
Pfaff 1222 part
Search for:
Pfaff 1222 parts
(may find it on eBay or some online sewing machine vendors)
Foot Control Pedal 90 222040 08 For Pfaff 1212 1221 1222E Sewing Machines...
Aug 01, 2017 | PfaFF Sewing Machines
Pfaff Creative Vision 5. The bobbin thread keeps birdnesting under the plate. I have changed thread, bobbin, dusted and cleaned the machine with canned air.
Just a guess, but do you RAISE the presser foot when threading the upper thread? That will usually stop the bird nesting.
Feb 27, 2017 | PfaFF Sewing Machines
On what number should I put 7570 tention when
Refer to the manual. If you do not have a manual, start at 4 and work your way through the numbers, bit by bit until you get good results.
The bobbin thread should pull the top thread slightly under and to the back.
Machine embroidery bobbin thread is heavier than the standard size machine embroidery top thread and this also helps to pull the top thread to the back.
Mar 07, 2010 | PfaFF Creative 7570
Needle timeing is out
The timing is set at the factory. If the threads are not hooking together, then perhaps try one of three things.
1. remove the thread, and run the machine at full speed for three minutes or more. This warms up the hardware, loosens gelled up oil, and get's all the parts in allignment.
2. (and 3.) Check the thread tentions. On the top thread, it will be a dial with numbers, over a spring and two plates that the thread runs through. On the bottom, it's a tiny screw on the side of the casing that the bobbin sits inside.
If the machine sews loose threads, then tighten these, a bit at at time, and if the machine jams up with a knot of thread at the needle, then loosen these. I believe that if the sewn threads are loose at the top, the bobbin tention neeeds tightening, and if the sewn threads on the bottom are loose, then the top tention dial needs tightening.
Cheers.
Aug 22, 2009 | PfaFF Creative 7570
How do i adjust the tention on my 786 overlocker . i haven't got a manual and the tention is not correct. what should i do
Make sure when you thread the machine that the pressure foot is in the up position and the thread go in between the tension discs. I have seen more problems from this not happening than anything else.
I have been repairing these for 25 years
Jun 28, 2009 | PfaFF Sewing Machines
Presser foot 7 lever on Pfaff 1471
You may not be using the correct presser foot for your machine.
Sewing Machine Feet
You may be using a low shank when your machine needs a high shank.
May 12, 2017 | Kenmore 15218 Mechanical Sewing Machine
Pfaff 2058 Voltage switch
There is a small clear plastic piece blocking the switch that must be removed, then use a small flat screw driver to flip the switch, you can throw away the small piece, it is only needed for shipping.
good luck!
May 25, 2008 | PfaFF Tiptronic 2040
Simplicity Easy Lock Serger 804DSP with Differential Feed Tention problems
Here is the manual! Copy the entire link! http://web.archive.org/web/20060508095821/http://www.simplicitysewing.com/ftp/whitepapers/804.pdf Enjoy!
Apr 22, 2008 | Simplicity Frontier SL390 Mechanical...
Sewing Machines Logo
253 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
