Model Number: HCD-BX70DBI No sound through speakers or headphones, tried a speaker that I know works and still no sound at all.
  • 150 Answers
SOURCE: Right speaker channel low, both front and and back, even the headphones
There might be a levels adjustment in the setup menu for distance or something, might check that before opening unit up.
Posted on Jul 08, 2007
  • 5 Answers
SOURCE: The speakers don't work
Ok There is another chance to work your speakers ,
  If you have your mother board CD , get play that  and  reinstall the sound system .
  I hope it will work ,      please do reply
Posted on Dec 22, 2007
  • 4234 Answers
SOURCE: No sound to speakers with power on
I can not help much without the make and model as these units vary quite a bit. Please update this with that info. Also, do you hear a click when you turn on the set? You should here one followed a few seconds later by another. Please update this and I'll get you some possibilites and some things to try.
Thanks,
Dan
Posted on Jun 06, 2008
mikeymiddles
  • 58 Answers
SOURCE: i have a yamaha rxv663
Sorry,Buy a better receiver.  The main outputs are cut off by the headphone jack at the pre-amp stage of this amp.  So when the headphone jack is bridged or engaged the signal is sent to the headphone amp and does not pass on to the main power amp. In an effort to simplify and save money on expensive distributive op-amps and knobs, the designer of your amp only installed one volume control and one set of op-amps on this receiver.  If both outputs were meant to work independently there would be a separate volume control for the headphone jack.  This feature is designed to allow a user to work in the room silently with only headphones on.   It is found on consumer equipment.  Stepping up to a "pro-sumer" or  professional or DJ amp will allow the use of all outputs simultaneously.     A rule of thumb with most electronics is often "You get what you pay for." Meaning: Less expensive, consumer models will almost always have less quality and more frustrating features than more expensive, professional models.
Posted on Dec 11, 2008
wireless speakers will usually hook to speaker outputs as well as headphone jacks. hook the wireless speakers up to speakers "b".
Posted on Dec 17, 2008
I have a ypg535 and headphones work but no sound from keyboard. I did unplug the headphones.
If you have sound through the headphones but not the internal speakers then assuming there is nothing stuck in the socket, headphone adaptor, broken plug etc then it would point to the amplifier section of the keyboard having failed. Sound via the hip socket is normally from the pre amp stage. Is there any slight hissing from speakers? If so this reinforces amplifier theory as the speakers are obviously connected.
please state model number of the keyboard and answers to the above .
regards
dan
Jul 20, 2017 | The Music
Sony hcd-ec99i i have no sound from the speakers at all. I am not getting the protect message. please help
Check the simple stuff first
Is it muted?
Is the source selected sending signal (radio staion broadcasting, cd playing, ipod all the way ect)
Try doing some basic troubleshooting like,
see if all sources available yield the same result (TV, Radio, CD, Ipod, Aux jack)
When you turn the volume all the way up, do you hear an audible hiss from the speakers?(or use a test tone) If so, your amp is working and the problem is, your unit is not sending any signal to it.
If possible hook up your speakers to another system to rule them out, however I doubt that is your problem.
Here is sony's recommendation and a review video
Let me know what you get
SONY eSupport How to troubleshoot if there is no sound or intermittent...
Feb 03, 2014 | Audio Players & Recorders
Sony hcd vx55
Hello. I downloaded the manual for the Sony system with the model number MHC-VX55. It seems that the part you are asking about is not a speaker system, but a preamplifie/power amplifier with integrated inputs from CD/Video, tape and tuner. The speakers that connect to the HCD-VX55 are a three way passive design with a nominal impedance of 6 ohms and model number SS-VX55. To answer your question I will assume that you meant you would like to connect the MHC-VX55 system to your computer for playing back audio tracks from your computer. Yes, you can do this. Your Sony system is equipped with an input labelled MD/Video (audio) With a sensitivity of 450 mV, this will (not ideally) the output from your computer headphone jack (if a laptop) or, even better you may have a desktop with an audio output at line level. You will need a simple audio connector with a 3.5 mm stereo plug on each end (very common and readily available for a few dollars. Be careful when setting up that you have your source turned down low and the input on your Sony machine about half way. You will find the sweet settings so that you get good sound without distortion. If you get distortion your source level is too high. Hope this helps. Cheers, Don.
Dec 13, 2013 | Audio Players & Recorders
I have aproblem with my speakers ( DVD player HCD-DZ720). The front panel shows HP (Head Phone) I checked and the sound comes from Head Phones but not speakers. How can I set the audio to output from...
try to clean the the headphone socket. becous this is preventing the output of the speaker to go out meybe it has jamed the switcher inside the socket
Apr 21, 2013 | Audio Players & Recorders
Logitech speakers Z506 no sound after unplugging headphones
all i know is try to powercycle if that doesnt work plug headphones in and take back out it kight just work
Feb 18, 2013 | Logitech Z506 Surround Sound Speakers
No sound from headphones. Speakers work. Win7
Please clarify, Where is the Headphones connected? Front or back? if you tried it on the Front port without success, Plug in the speaker jack to the port where you did connect the Headphone and verify it's working or not. You can also try the headphone on the port where the speaker is connected.
Awaiting.
Nov 03, 2010 | HP Pavilion m7480n (882780389410) PC...
I have no sound
Try different speakers which you know are working if possible.
If the good speakers are also not working, then your Logitech speakers may be ok. Try plugging them into a different device such as iPod headphone jack, stereo headphone jack, etc.
Let me know how you go.
Hope this helps, Benji
Sep 26, 2010 | Logitech X-240 Computer Speakers
Sound is working but internal speaker is not working
Connecting headphones to the system will disabled the internal speakers until the headphone jack is disconnected, at which such time the internal speakers should function again.
If you disconnect the headphones and the internal speakers are not re-activated, then there may be damaged to the microswitch in the jack. (Try rebooting after the headphones are disconnected too)
Mar 01, 2009 | Dell Latitude D410 Notebook
Because of Gigaware headphones, my speakers dont work
it sounds like the headphones shorted out the usb on your system, you might try some speakers that are not usb and see what you come up with,,,also check and make sur your sound isnt muted on the master control for the volume
Feb 26, 2009 | Audio Players & Recorders
Sound still appear at speaker even when headphone was installed
Hello Again,
When you Plug in HeadPhones into the Laptop the Sound Playing should automatically Bi-Pass the Speakers and go Straight to the Headphones
-Unless there is a Faulty Input for the Speaker/ Headphone, Try Pushing in the Headphones More to see if the Speakers Turn Off
Hope this Works --P3NGYJ03
Jan 23, 2009 | Audio Players & Recorders
340 people viewed this question
 Grubhead
Grubhead
