Trying to program my AVOL ALT2623N tv to DISH Network. How do I do this?
trintek
  • 111 Answers
SOURCE: Dish Remote
your dish network remote does not have codes for an olevia tv, the best you can do is use the powerscan mode. here are the steps.
1)Turn ON the electronic device you want to program the remote to control.
2)Press the Mode button on the remote until the appropriate mode light is flashing.
3)Press the Address button. The mode light will start flashing slowly.
4)Press the Power button. The mode light will stop flashing and stay lit.
5)Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
6)When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
7)Press the Address button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
8)Turn the device back ON by pressing the Power button.
9)Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
10)If the other buttons work, follow the current settings procedure below to determine the current remote settings.
11)If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
12)The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
current settings:
1)Press the Mode button on the remote until the appropriate mode light is flashing.
2)Rapidly press the Address button twice.
For the SAT mode, the mode light will flash the number of time that matches the receiver address.
3)For the TV, VCR, and AUX modes, the mode light will flash the number of times to indicate each digit of the current code. There will be a pause between the flash sequences for the digits. A quick flash indicates zero.
4)Write all of the codes you programmed on to the sticker that came with your satellite receiver and apply the sticker to the inside of the remote battery cover.
hope this helps,
trin
Posted on Nov 16, 2007
  • 374 Answers
SOURCE: need codes for a phillips magnavox for dish network controller
Follow this link and got to the remote section. Once there shoose the type of remote you have and select remote codes to get the ones for that particular remote that may operate the piece of equipment desired. I hope this is of assistance to yoiu and thanks for using Fix Ya. Please let me know if I can be of further assistance.
Jim
Posted on Nov 11, 2008
ward_knutson
  • 64 Answers
SOURCE: dish network remote with a element tv
Since you dont have a popular brand set you should try using the scan method. Here is a link with a video to help program your dishnetwork remote to work with your set. http://www.disheez.com/videos/dish-network-video/programming-dish-network-remote/
Posted on Nov 25, 2008
  • 374 Answers
SOURCE: need Sanyo TV code numbers
These are the codes for Sanyo TV'S for this remote. The newer TV codes are at the end so work in reverse order when inputting these codes. Thanks for using Fix Ya.
542, 589, 590, 591, 592, 609
Posted on May 25, 2009
  • 374 Answers
SOURCE: need sharp tv codes
The codes for a Sharp are 526, 585, 591, 605, 606, 607, 608, 628, 629. Thanks for using Fix Ya.
Posted on Aug 15, 2009
Programming my avol tv to my dish controller.
Shouldn't need to. With the control box plugged into the tv you should have the tv set to a channel like 3 or 4 and use the remote that comes from your provider.
Jan 30, 2013 | Televison & Video
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Jan 09, 2012 | Sanyo 42 in. LCD TV
I have an AVol TV and need the Dish Network remote control codes
Hi, my name is Cheri Torres and I am with DISH Network Customer Service. I tried looking up all of our possible remote codes and I was not able to locate any codes for an AVol TV. Instead of using codes to address your DISH remote to your TV you will need to try a power scan. A power scan will normally find the code that works best for your TV for you. I will list here for you the instructions for performing a power scan. I hope you find this information useful. :)
Instructions for performing a power scan
  1. Turn the Television On.
  2. Press and hold the TV mode button until all mode lights light up red.
  3. Press and release the big red power button once.
  4. Press and release the channel Up Arrow on the remote until the television turns off.
  5. After the television turns off, press and release the pound(#) button once.
  6. Test functionality with the TV.
  7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Sep 09, 2011 | DISH Network IR Remote Control
Need codes for dish network trying to program dish to my rca remote
Hello, my name is Becki, with DISH Network. Here are some steps to program that remote to your TV.
1. Hold down the clear TV button until all lights light up at the top of the remote
2. Punch in a 3 digit code (provided below)
3. Press the # (POUND) button
4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
641
805
831
Becki Barned
May 15, 2011 | RCA L26HD41 LCD TV
IM TRYING TO PROGRAM MY RCA TV REMOTE TO DISH NETWORK. PRODUCT INFO. MODEL # L40FHD41YX9 SERIAL # J516C40DI SERIES # F2 PLEASE CONTACT ME WITH SOLUTIONS TO THE PROBLEM
Hi amielynn221, my name is Mike Houston of DISH Network and I see youwant to program the RCA remote to the DISH Network receiver. We do have thecodes to program our DISH remote to the RCA TV we do not have the codes toprogram the RCA remote to DISH Network receivers, I will send a link to helpwith these steps. http://remotefinder.rca.com/default.aspx?site=rca
Apr 19, 2011 | RCA RCRN04GR Remote Control
How do I switch from tv watching to listening to the included music channels on my motorola universal remote
gomabra
Would you elaborate further on what you are trying to do? Are you trying to program your universal remote to your DISH Network receiver or something else? I have provided a link with instructions on how to program the universal remote. Since it is not a DISH remote, we can't guarantee the function of that remote. I hope this helps.
http://www.ehow.com/how_5006714_program-motorola-universal-remote.html
Ray Calo
DISH Network
Feb 17, 2011 | DISH Network IR Remote Control
How do i program my remote
ablesmichell
What are you trying to program your remote to? I have provided a link to the steps for programming the remote to your TV or receiver. If you are trying to program to another device, please respond to this site. If you are trying to program to your TV, I have also provide a link with the different codes for each type of TV. I hope this helps.
Remote instructions: http://www.dishnetwork.com/SupportSection/remote-setup
Remote codes:
http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml
Ray Calo
DISH Network
Nov 24, 2010 | DISH Network IR Remote Control
I would like to control my dish network receiver 3100 with my samsung remote
trifonas_ger
If you are trying to use your Samsung TV remote, it will not work with our DISH receiver. Some universal remotes can be programmed to the receiver but you may not get full functionality with the universal remote. Our remotes are designed to allow for functionality for the TV if programmed to the DISH remote (volume, on/off). I hope this helps.
Ray Calo
DISH Network
May 07, 2010 | DISH Network 32 Ir 137180 Remote 5900 3100...
Programing Dish Network Remote to control a Vizio Tv.
Try 627 for Vizio TVs - that should work on the Dish remote.
Dec 22, 2008 | DISH Network IR Remote Control
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
