My baumatic washing machine is less that 9 months old and smells stale. I have tried doing a wash cycle with just washing liquid in and a cycle with bicarb of soda but with no sucees. any ideas? my wasking just smells stale all the time.
    Brigadier General:
  • 6,277 Answers
(try this!)
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor. The bit about checking the motor is near the end ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
John C
Posted on Apr 09, 2011
  • helenmarie_f May 06, 2011
    Thank you for your advice. The filter was found at the front as you suggested but there was very little to clean. The problem persists.
Smell of stale water from Avanti compact washer
It may not be draining very well.
I have a front load washer and run a cycle of a few cups of bleach through mine every couple months.
I also add vinegar to most washes but that's due to my teenage son's athletic wear.
Both those things do the trick.
You shoudl probably check the mechanics as well but the above is a stop gap.
Sep 14, 2012 | Avanti W789SA Top Load Washer
After washing clothes smell stale. We have tried adding more detergent without success and draining the pump on a regular basis. Any ideas?
Check the drain pipe at the rear of the unit, sometimes the position allows the dirty water to re-enter the washing machine and sit there between cycles. Some units have a rigid plastic holder to ensure the pipe is curved at a specific height so the water empties using gravity as well as the pump. (Same process as syphoning liquid, once the liquid is flowing through the pipe, gravity continues to **** the liquid through) You may also need to check the pipework from which the detergent/softener enters the unit as these can sometimes go a little mouldy. Once you have looked at these two problems, run the machine empty on a high temperature cycle to clear away any disturbed grime.
Good luck, hope I was of some assistance
Aug 05, 2011 | Washing Machines
How to get rid of the stale smell from the atf8000 front loader washing machine
first things first we need to purchase a cleaning tablet from local grocery store called affresh tablets in your laundry detergent aisle ,
then clean out filter sump assymbly in bottom corner of washer som washers have an axcess panel in the bottom righ or left hand corber uncrew filter cap and drain in to bucket or a shop vac .
clean debris out of filter and reinstall the filter screw cap in tightly ..
check your console for a clean cycle option in your wash cycles an select put one affresh tablet inside of washer drum and run cycle..
if you dont have a clean cycle thats ok select your hotest water wash cycle or sanitary cycle put one affresh tablet inside washer drum and run cycle ...
after cycle completes always leave waher door cracked open when washer is not in use ,,, reccomend running an affresh cycle once every month or if u notice stagnant water smell the more often you wash with hot water the less chances of smell
Jan 24, 2011 | Washing Machines
Front-load steam washer smells like a stale sponge. How do you repair this? It is only a year old and was very expensive. The dryer works fine. Baking soad, vinegar, none of this helps. Thanks.
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Affresh is recommended by some manufacturers. You run it through a wash cycle with it.
Jul 05, 2010 | Washing Machines
GE Profile washing machine model 66515754000. 9
Try a cleaning detergent/descaler. some liquids do cause problems. Softner is 1, it tends to gel in the pressure chambers in machines. This in turn causes many problems.
Feb 11, 2010 | Washing Machines
My aquarius WML540G washing machine has no obvious fault apart from I am sure there must be an item of clothing trapped in the washer because my clothes smell of when something has been left wet for a long...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Smells coming from inside the drum are usually caused by a build up of soap and scum congealing on the inside of the container, (that is the container rather than the inner drum) and the worst culprit for this build up is liquid washing compounds because they do not have any bleaching agents in them and they form a kind of paste. Put the machine on a service wash, (that is a very hot wash with a good quality washing POWDER and no cloths) allow the machine to complete the cycle. This may need to be repeated once a week or month until you are happy the smell has completely gone. If possibly I would avoid liquid soap in future. But that is just my opinion.
Aug 31, 2009 | Hotpoint Washing Machines
Front loader smells like stale cigarettes during cycle
Make sure that you are using high efficiency (he) detergent. Pour 2 cups of vinegar in the tub and fill the detergent tray with vinegar. Run it on the hottest, longest cycle. You can also use a Front load cleaner such as Afresh, made by Whirpool. I think that Tide makes one too. Vinegar is usually readily available. At the end of washing for the day, leave the door to the washer slightly open so that fresh air can get in and dry it out keeping moldy, milduey smell down. If it mildews, use a rag and bleach water to clean the boot seal. Hope this helps.
Apr 02, 2009 | Kenmore HE2 Plus Front Load Washer
Bad smell on dried dishes after being washed.Stale water smell.
Try Running Goo Gone Through It Although It Smells Like Oranges It Removes Stains As Strong As Sap. Also Try Running The Dry Cycle While Its Empty Two Or Three Times.
Jan 06, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Hi, I have a Baumatic Washing Machine (not sure of the model) and cannot find the filter. The machine gives off an awful smell which I am trying to fix
you should find the filter but that is not what is causing the smell. common causes of smell are:
using liquid detergent - this smells like drains if used for a long period and leaves a horrid sludge in the tub. put on a boil wash with no clothers and use powder detergent
plumbed in under the sink and there is also a waste disposal unit. these pong!
no water barrier between the drain of the washer and the house drains
Jul 10, 2008 | Baumatic Washing Machines
Stale water smell
If the washing machine itself smells bad when you open the door, it could be that it's covered in a horrible grease and gunge inside all the hoses and the tub. This particularly affects older washing machines and is common with washing machines that have only really been used at 40° or where only liquid detergent has been used.
Not using enough soap detergent over a long period of time can cause a build up of grease and therefore bad smells.
Get rid of washing machine smells
You could try to clean the washing machine inside using Soda crystals which dissolve grease. I recommend putting half a packet inside the drum and washing on a boil wash (or follow instructions on the packet) Using this method every month or so, or using ordinary detergent if no soda crystals are available can help prevent smells from your washing machine. If your washing machine is badly affected by grease and slime, it may be very difficult to remove it.
Get rid of washing machine odours using vinegar
White distilled vinegar has an array of uses. For bad washing machine smells, try putting half a cup of white vinegar inside an empty machine and put it on a boil wash. Because the first bit of water goes into the sump hose and is sealed off, I recommend that you wait until the washing machine has been filling for about 30 seconds and then pour the vinegar into the soap drawer to let it wash down into the machine. I've had reports back from people that this does actually work.
Mar 07, 2008 | Hotpoint WMA40 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
