Question about ASUS Cell Phones
My nephew threw his moms garmin aside a10 and it broke the little gold contact that touches the battery cover, and now I get message " please replace battery cover and restart phone to complete set up for the first time. Now, the problem is that I have put the cover on but still get the message (gold tab is still broken I don't have money to get it fixed and I dont know how to fix it myself). Also the phone is not new and had already been set up. Much thanks in advance for any help
Jeap
  • 114 Answers
SOURCE: no startup on lens cover opening
well the problem it´s on the switch that turns on the camera that is located under the lens cover.... this swith is glued to the front cover and lots of times gets unglued, u need to remove the lens cover by removing 2 screws on the bottom part of the lens cover, after that just pull the switch slowly and glue it. don´t use 3 seconds glue use a more viscose one. good luck
Posted on Feb 24, 2007
SOURCE: broken garmin screen
Like original poster, I've got a dent on my Garmin C320 screen - could see everything, but touch feature stopped working.
Just finished swapping the screen with the one from my old Dell Axim X3 PDA. Now GPS works again! It seems that older units were using industry-standard LCD that could be easily replaced. Not sure about newer Nuvi systems...
Posted on May 18, 2008
SOURCE: Phone memory protected
Under Menu>Contacts>Settings.... Under memory in use, change it to phone and SIM. It will probably ask for a security code which should be in your book, if you haven't changed it, its something like 0000 or 12345 or similar. then you should be able to copy all to the simcard.
Good Luck esm_taher@yahoo.com
Posted on Sep 09, 2008
  • 7 Answers
SOURCE: my sidekick LX data got deleted please help!
press and hold "menu" "0" and "@". it will soft reset your phone
Posted on Jan 16, 2009
SOURCE: MY ipod touch broke because i threw it at the wall
UUMMMMMMM WhatTheFrick YOU GO BUY A NEW ONE (Or get a schematic and the pieces)
Posted on Mar 09, 2009
Err 01....communication between lens and camera is faulty.Please clean the lens contact...this is the error message...please say a solution..
The contacts are the little gold coloured metal squares that touch between your lens and the body. Clean them with isopropyl alcohol (moistened glasses wipes work well) and see how you go.
Jun 10, 2013 | Canon EOS 1100D / Rebel T3 Digital Camera
Nuvi 50lm can't find maps
There are two different things to try.
1. Do a hard reset, that should restore the software and maps to their base condition.
2. Run Garmin Express and apply any updates it shows.
http://www.resettoo.com/hard-reset-garmin-nuvi-50lm
Aug 22, 2017 | Garmin Nuvi 50Lm - Gps Receiver
My Casio Protrek PRG 120 triple sensor show an "open" message and I am no longer able to program the functions and including the alarm. Please tell me what I should do.
it's because the contact that sense whether the watch is opened or not is misaligned.
Just open the watch caseback, re-allign the gold contact on the case-back, and make sure it touches the spring in the other side of the watch.
Aug 29, 2011 | Casio Protrek Triple Sensor Tough Solar...
Where dose one find the owners manual for the garmin A10
You can find a pdf version of the garmin nuvifone a10 owners manual here.
May 13, 2011 | Cell Phones
One day my nuvi 245 continues to show "press dot". So I keep pressing dot only for somewhile because after just 1 second from "turning on" touch screen does not work. That means even...
Your touch sensitive screen may have failed. The touch sensitive screen is a thin transparent film that is secured over the front of the display screen.
When it fails, you can no longer select or input anything into the GPS via screen. This of course renders the GPS pretty much useless. Garmin will exchange your defective GPS with a factory refurbished unit with the latest maps and provide a 90 warranty for many GPS units. The Nuvi 250 service cost is $69. I could not find your Nuvi245 model listed so you might want to contact Garmin directly to see what the replacement cost will be.
I hope this helps & good luck. Please rate my reply. Thank you.
Apr 09, 2011 | GPS
Printer problem. suddenly it doesn't like the "cartridge on the right." says "the cartridge on the right is not intended for this printer." There's nothing wrong with the cartridge;...
Try taking the cartridge out and without touching the gold connector pins on the back, clean them with a Q-tip and rubbing alcohol. Do the same with the connector pins in the printer. Some times dirt, ink, etc. gets on the pins and does not make good contact. Thus, an error message and perhaps no printing.
Nov 30, 2010 | HP Office Equipment & Supplies
Back cover where that contains the batteries broke
Contact garmin at garmin.com, this is not an accessory, that you can buy anywhere, so send them an e-mail and see what they say.
Mar 31, 2009 | Garmin Rino 110 (14 Channels) 2-Way Radio
Unlock c510
Take the unit to where your nephew was playing with it, and it will automatically unlock. Otherwise, you'll need to send it in to Garmin with the receipt from an authorized dealer.
Sep 06, 2008 | Garmin StreetPilot c550 GPS Receiver
Nikon D50 blinking "Err" message
Make sure the lens is mounted fully (give it a little twist to see if the error clears). Also, check the gold contacts inside the body, where the body touches the gold "points" on the lens, to make sure they are clean. A pencil eraser is a good cleaning device for these contacts. I hope this solves it for you.
May 31, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
Cell Phones Logo
Top ASUS Cell Phones Experts
Computer Repairing
Computer Repairing
Kolbrun...
270rexton
270rexton
Are you an ASUS Cell Phone Expert? Answer questions, earn points and help others
