Question about Black & Decker String Trimmer Cordless 12" 18V
The trimmer head on my Black and Decker cordless trimmer/edger seems to fall a few mm and the won't spin unless I push it back up the shaft. This is the second time I've had this happen in a unit after using it fore about 2 years -just beyond the warranty!!
  • 4 Answers
You probably have lost your return spring which will hold the head tight to the trimmer.Check to see if you have lost the spring. I would suggest looking on-line for a exploded view with parts list to see if you have any parts missing including the spring I mentioned first!
Posted on Aug 07, 2008
Why will the trimmer head will not come off?
If you're talking about the line reel, Grip it with water pump pliers and pull. The springs are strong. Just push the new reel back on.
Jun 29, 2014 | Black & Decker String Trimmer Cordless 12"...
Trimmer wrapped around shaft
Deborah there should be a little hole just towards the bottom of the spool head where you could fit a small metal rod in. If you can locate it push something small in like a 2 inch nail and turn the spool head slowly by hand until it locks up. The head should then undo . It will undo anti clockwise.
May 14, 2014 | Black and Decker USA black & decker grass...
Black & Decker battery operated weed eater/edger not working at all.
you probably need to take the base apart ,mine had a loose wire on the motor on the end of the shaft,about ten phillips head screws ,there is one screw on the gaurd,good luck
May 31, 2012 | Black & Decker Grasshog 12 Inch 18 Volt...
Put in replacement spool cutting great as usual went edge the head with spool of line wont turn went back to normal position spool will not spin to cut motor runs spool head not engaging how can I fix
pull the head completely off and make sure that the shaft is not broken, if not then line it back into the head slot and put back together and test it out, Tim
May 29, 2011 | Black & Decker 14" Grass Hog Xp...
CST2000 can't get the battery off when pushing the two release buttons.
Black & Decker didn't make it easy to remove the battery pack. You have to push both buttons in at the same time, while pushing the battery pack forward. It takes a little while to get good at it -- you have to hold onto the trimmer with the same hand that's pushing the buttons in, while pushing the head forward with the other hand.
If you're only taking the head off to charge the battery, you can charge it while it's still attached. The hole for the adapter is on the back of the head, so you can plug it in while it's attached to the trimmer.
Hope that helps!
Jun 17, 2010 | Black & Decker String Trimmer Cordless 12"...
Describe your Black & Decker Grasshog
The push lock on the string feeder Is sticking. Pull it off, clean it out and put it back on.
good luck
Aug 07, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
The motor runs but the base doesn't spin.
The nylon Gear in the head has theeth missing. I need a parts break down and a source for part.
this is for a Grasshog. NST 2018 Trimmer
May 25, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
Head of trimmer/edger doesn't spin
i have the same problem, the plastic timing pulley on the motor assembly is probably melted, remove all the screws down the side of the housing, including the one hidden under the label, and you will find that the belt and the pulley are both chewed up.
Apr 18, 2009 | Black & Decker 14" Grass Hog Xp...
How do I get my Black and Decker 12"bump feed trimmer/edger out of the groom position and into the edge position? My boyfriend misplaced the instructions to our new edger and I can't figure it out.
The handle/shaft is in two parts. By grasping the upper part of the shaft with one hand, and the lower part with the other, you can move the two sections slightly apart, then twist to turn the trimming end 180-degrees.
Sep 15, 2008 | Black & Decker String Trimmer Cordless 12"...
Black & Decker String Trimmer Cordless 12" 18V Logo
280 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
