Question about Hotpoint WMA74 Front Load Washer
Banging on spin grinding when drum turns - Hotpoint WMA74 Front Load Washer
    Brigadier General:
  • 6,277 Answers
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
Good luck,
John C
Posted on Apr 11, 2011
My whirlpool top loader bangs around during final spin
Kindly provide few details :-
1. Make and model of the washer?
2.How old the washer is?
3. Is it banging only at high speed or even on slow speed?
4. Is it only during the final spin or all the time during spin?
5. If you move the drum by hand, is there any noise? Could you turn the drum easily?
Kindly answer all the questions.
Thanks!!
Sep 02, 2010 | Washing Machines
Washer motor turns, drum does not
Please be gentle with me if this is obviously not the problem, but I have made the mistake of running top load washers with the door open (which the washer notices and does not turn the basket. I fixed my problem by loading the washer, adding the detergent while the washing machine was filling and then closing the door. My washer worked fine with the door closed.
Again, please be gentle with me as you rate my helpfulness. OK?
May 21, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Hard bang on spin with my frigidaire gallery frontload washer
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 15, 2010 | Frigidaire GLTF1040A Front Load Washer
Loose drum bangs during spin cycle turn by hand with nothing in drum and still bangs?
your front drum support blocks have failed. remove the tub and, replace or, rebolt them in place so they hold the drum front in place.
Jan 25, 2010 | Frigidaire 14 Cycle Tumble Action Washer
Kenmore 417.44102 is 5 yrs old. The other day, it started making a banging noise on final spin. I can manually turn the stainless tub, but do hear a grinding noise, as if the tub is rubbing against...
sounds like th bracket on the back of the basket has broken. just replaced mine and itwas abit ofa bear. teardown is all from the back and itis almost a complete teardown, remove back panel and top, remove struts on the lower drum assembly, remoive drive belt. the large drum assembly has a bunch of screws tht holdit together(heads aretoward the front of the waser) remove all of the lower screws, removeth springs from the top of the drum ssemblyand remove he srings. take out thescrews fron th top halfof the drum assembly. the back half should now comeout. remove the bolt holding te drive pully onto the drum assembly then th plastic drum assemblycan b removed from thebassket. the back of the basket has a bracket on it I bet itis broken. this is a 200 dolar part, (basket) and replacementis the reversal ofremoval. it is a difficult and somewhat time consuming repair butit was well worth it for me
Nov 24, 2009 | Kenmore 44102 Front Load Washer
Loud banging
Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
Check drum restraint spring(s) are not broken.
Check suspension legs for wear.
Check for loose motor fixings.
Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
Please rate my comments.
Thanks.
Jul 27, 2009 | Hotpoint Aquarius WD63 Front Load...
When turning on the TV, I hear a banging/grinding sound.
If you hear a grinding,whirling,spining or buzzing sound, that sounds to me like the COLOR WHEEL,the reason for that is because your color wheel spins at 5,000 rpms(revolution per minute) and something that modifies the balance of the disc can cause different things,Unfortionatelly the only way to check that the color wheel is working properlyis you need to check it out physically
I did some research and I found the color wheel at DM;http://www.discount-merchant.com/Samsung-Replacement-Color-Wheel-HLS-HLT-Series-p/samsungcolor_wheel_bp96-01579a.htm?CLICK=52978
Please keep us posted.
Jun 14, 2009 | Samsung HL-S5087W DLP TV
Drum Speed - Unstable
The spin bearing or basket drive may be worn. When these components are worn-they prevent the drum from spinning freely, and usually you hear a loud sound during the spin mode.
Sep 03, 2008 | Frigidaire ATF6000ES Front Load Washer
Banging noise
You may have had a foreign object slip under a loose drum baffle. Manually rotate the drum to locate wwhich baffle it is in.
Apr 06, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Tub wobbles terrably in spin mode
Try lifting the inner drum to check if there is any movement between the inner and outer drums, also turn the drum and listen for any grinding or scraping sound from the rear of the drum. Its possible that your bearings have gone out & need to be replaced. The job is far from easy.
Mar 16, 2008 | Kenmore 98702 Stacked Washer/Dryer
Hotpoint WMA74 Front Load Washer Logo
26 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
