Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool TAWX700PQZ Hello, Top load whirlpool washer was full for washing. Noticed flood in the area. Leakage seemed like from bottom. My husband attempted to fix but he could not open it. He left the machine for 2 days side wise on the floor. Can it cause damage?
  • 2 more comments
  • Anonymous Aug 21, 2008
    my washing machine filled up but will not spin.
  • ddragnslyr Aug 24, 2008
    can someone help cant get back off to try n fix water leak can someone please help me as soon as they can i need to get me wash done before school starts.
  • muycabron Sep 07, 2008
    soapy water leaks from the bottom of washer. how can i fix this problem by my self.
  • colex97 Oct 09, 2008
    I have a whirlpool top load sumthin erother, anywho its washing fine but the last two loads ive done there has been water leaking on the floor from it!! I thought maybe the drainage pipe was clogged, but its bone dry!
    Sergeant:
    Champion:
  • 324 Answers
Does anyone still have problems?
Posted on Nov 05, 2008
Kenmore Washer only leaking from one area
Ive never worked on a Kenmore but it may just be the overflow outlet. All washing machines have an overflow which will dump water out from the top of the tub if it overfills but sometimes on high fill water level, clothes can splash around and cause a "wave" of water to splash out over the overflow outlet. Check to see if the leak only occurs when you have selected high level fill.
Nov 23, 2017 | Kenmore Energy Star 44092 Front Load...
Washer does not rinse & spindry after getting submerged in water.
everything needs to be checked from the timer control button to the motor, im guessing it agitated through the wash cycle but wont spin now right? your flood could have damaged any number of items... run through ( with the machine unpluged ) and test the components for continuity and/or resistance.
Oct 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator moving just a little.
If it is a Whirlpool or Kenmore make washer you probably stripped the "dog ears" in the agitator. They give you the duel agitation that makes your clothes cycle from top to bottom of the machine. Should only rin you around $8.00 or so. Hope that helps.
Jan 24, 2009 | GE WBSR3140DW Top Load Washer
Fabric Softener dispenser
thats quite normal, espessially if you do not use the fabric softener, the compartment empties through an overflow siphon action, so if there eis nothing in the compartment the area is flooded but cannot cause siphon action, not an issue at all
Nov 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool calypso washing machine
fl is short for flood..possible something has pump impeller blocked ..if you hear a slight hum that is most likely what it is although on 1st generation the pump had a splined shaft that was bad about stripping only solution there was complete change out update version has a pump with 4 screws in bottom they can be removed to clean impeller area remove as much water as possible.. shop vac helps.. lean washer back and remove bottom to acess pump
Jul 31, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Sometimes leaks from the bottom
ckd door seal closley for tears or distortion..try removing bottom panel for a few loads this may help in locating source
May 21, 2008 | Whirlpool GHW9300 Duet Washer
Water coming out of bottom, not the drain hose
take front panel off with a putty knife slide knife across the top gap and you will feel it stop pull out a little and then push in do that on both sides and front pulls to you and then you can see everything
good luck
Dec 08, 2007 | GE WBSR3140DW Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
97 people viewed this question
Dan Webster
Dan Webster
Sal De
