Question about Kenmore 4292x Front Load Washer
Door Locked and Won't Open
Error F02 then Sud then F02 again and beeping. Door locked and can't open, even if press Pause/Cancel twice as manual says, or turn off (unplug). Have Sears Repair booked but can't come for 2 weeks. How do I manually unlock the door so I can get my wet laundry out before it molds? Model# is 110.42936
    President:
  • 1,294 Answers
FO2 is the code for long drain. Your filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 screws. The panel will drop and come off. The filter cover is right in front. Get yourself a bunch of towels and unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in.
1. Press the Chime and Delay Start pads at the same time for
three seconds.
2. The Child Lock light will illuminate.
3. To unlock, press the Chime and Delay Start pads at the same time for three seconds. The Child Lock light will go out.
If above 3 dont work try 'end of cycle' button for 3 seconds.
Posted on Mar 28, 2009
SOURCE:
Received a SUD error
F02 Long Drain If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Whirlpool Fault Codes
Aug 26, 2014 | Washing Machines
Washer won't complete cycle. F02 flashing
F02 = long drain
try this
If the drain time exceeds eight minutes, the water valves are turned off and "F02" is flashed.
Press PAUSE/CANCEL two times to clear the display.
NOTE: After four minutes the "Sud" error will be displayed, then four minutes later the "F02" error code will be displayed..
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filterfor foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Oct 23, 2012 | KitchenAid KHWV01RSS
Error code HF
Washer displaying code message and tone sounds S "HF" 0Nater Inlet Problem--no water or insufficient water supply) Select PAUSE/CANCEL twice to cancel the cycle. Unplug washer or disconnect power. Check the following: Are water faucets completely turned on? Are screens at inlet hose connection to washer clogged? Are water inlet hoses kinked? Are water inlet hoses frozen? Plug in washer or reconnect power. Re-select cycle and press START. If the problem remains, call for service. "F02" (Drain Problem) Select PAUSE/CANCEL twice to cancel the cycle, Unplug washer or disconnect power. Cl_eck the following: Is the drain hose kinked? ts the drain hose frozen? Is the drain hose clogged? Is the drain hose more than 96 in. (2.4 m) above the floor? = "SUD" (Suds Routine) When excessive suds are detected, a suds routine
Sep 23, 2010 | Kenmore Elite 45986 Front Load Washer
Whirlpool AWM9000 front loader Gives SUD on display then F02 and beeps.
it is a Long Drain error
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Thank You
Sep 10, 2010 | Whirlpool AWM9000 Front Load Washer
Kenmore elite washer he3t- beeping F02
"F/02"
Long Drain
Feb 13, 2010 | Kenmore Washing Machines
Got an f 02 message, now the door is locked and will not open. Have unplugged and then plugged in again, still locked and cannot unlock and need to get clothes out. What is an F 02 error?
F01 refers to Long Drain Error.
Reason -
Long Drain
What Needs to be Done -
* Check the drain hose
* Check the electrical connections at the pump and make sure the pump is running.
* Check the drain pump filter for foreign objects.
* If the above does not correct the problem, replace the pump.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 13, 2009 | Kenmore Elite 45986 Front Load Washer
I have a Kenomore Elite HE4t Washer. I am getting an F02 error message. I've tried to rerun washer & get SUDS on and off. Fo2 message appears again and cycle shuts down. Door will not unlock. Any...
HI. this code represents a Long Drain issue.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
Oct 14, 2009 | Kenmore Elite HE4 Electric Dryer
F02 code flashes and stops rinse cycle
Long Drain If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be disp NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the displaylayedPress PAUSE/CANCEL twice to clear the displayCheck the drain hose and make sure it is not plugged or kinkedCheck the electrical connections at the pump and make sure the pump is runninCheck the drain pump filter for foreign objects.g. If the above does not correct the problem, replace the pump.
Jul 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Started getting an F2 error code
I looked up the F02 code online and this is what it says:
Potential Causes
Hope that helps.
May 18, 2009 | Whirlpool GHW9400 Duet Washer
Kenmore Elite HE4t Washer
Error code F02 f the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed. Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the ?Sud? error will be displayed, then 4 minutes later the F02 error code will be displayed. Potential Causes ? Check the drain hose and make sure it is not plugged or kinked ? Check the electrical connections at the pump and make sure the pump is running. ? Check the drain pump filter for foreign objects ? If the above does not correct the problem replace the pump
Sep 11, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 4292x Front Load Washer Logo
174 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
