Samsung washing machine 3e error - Washing Machines
voodoomox
  • 1689 Answers
SOURCE: i have a samsung washing
here is a list of 3E's, if your error is 3E1-4 it may cost you since the DD motor can be around 150 bucks almost same with getting the motherboard replaced.
3E
Tacho error
Switch off the power/reconnect and try again
If error code persists a service call is advisable, switchboard (motherboard) replacement possible.
3E1
DD Motor fault
Check DD motor
Service call advisable
3E2
DD Motor fault
Check DD motor
3E3
DD Motor fault
Check DD motor
3E4
DD Motor fault
Check DD motor
good luck
Posted on Jul 24, 2008
SOURCE: i have a samsung J1043 7kg washing machine, apon
3E means the motor is running below or above the programming RPM's, this is a real problem. hold down the two left buttons while pressing the power button. this will present you with the testing system. Press the temp button and T1 will appear. press the start button on the machine will move through the phases in 3 second bursts. if your drum doesn;t move your motos shot. Good luck
Posted on Jan 31, 2010
supernova278
  • 1932 Answers
SOURCE: hi, i have front loading samsung
Hall Sensor is sensed every 5OOms. 1 second after motor starts to work.
If data of hall sensor is less than 2 (2RPM), the Washing motor will stop at once.
During Washing and Rinsing when a motor restriction is sensed, the motor stops and then proceeds to the next water -flow action. If the motor stops working and this happens in one direction ten times, “3E” Error is displayed.
During dehydrating. when a motor restriction is sensed. the motor stops working and then returns to the initial stage of the dehydration unbalance sensing cycle. After ten times, “3E” Error isdisplayed, When the motor Is told to stop because of an operating function. no error is shown.
Power 81W OFF can clear the motor restriction error.
Thank You
Posted on Sep 04, 2010
blueextc3221
  • 15935 Answers
SOURCE: samsung washing machine ji453s
The ECU has failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
SOURCE: Samsung big wash, Q12355 7.5Kg. what is meaning of
I GETTIN ERRER CODE E38 ON SAMSUNG BIG WASH
Posted on Feb 27, 2011
I have a samsung front loader WF7700N6W1 WHICH KEEPS COMING UPWITH THE ERROR CODE 3E IVE checked the drainage plug and cleared that but mavhine still not working.
The 3E error code to indicate a drive motor tach fault.
Here's a good website that discusses how to troubleshoot and possibly repair. (Could be as simple as unplugging the machine for a few minutes).
How To Fix 3E Error Code On Samsung Washing Machine
Here's an EXCELLENT YouTube video on removing the motor and replacing the brushes (if equipped).
Samsung Washing Machine 3E Error Code not spinning or turning
Jun 15, 2017 | Samsung Washing Machines
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
I need a Samsung Vrt steam manual. What does the error message 3E stand for on the, VRT Samsung Front Loader washing machine?
This video will help you diagnose the fault on Samsung Vrt steam 3e error codes and the video will help you solve the problem
Oct 24, 2015 | Samsung 3.9 Cu. Ft. VRT Steam and Power...
Samsung vrt wf44aap/w front loading washing machine will not start cycle. Beeping and flashing 3E
Unplug for a few then plug back in. Sometimes his will reset the machine.
Jun 08, 2013 | Washing Machines
Samsung Model WF220 won't spin after it fills with water. It displays Error code 3E.
This video will help you diagnose the fault on Samsung Model WF220 3e error codes and the video will help you solve the problem
Sep 08, 2012 | Washing Machines
As soon as the machine is on an error message of 3E appears and the machine stops
3E - MOTOR RESTRICTION ERROR
Hall Senior is sensed every 5OOms. 1 second after motor starts to work.
During Washing and Rinsing when a motor restriction is sensed, the motor stops and then proceeds to the next water -flow action. If the motor stops working and this happens in one direction ten times, "3E" Error is displayed.
During dehydrating. when a motor restriction is sensed. the motor stops working and then returns to the initial stage of the dehydration unbalance sensing cycle. After ten times, "3E" Error is displayed, When the motor Is told to stop because of an operating function. no error is shown.
Sep 14, 2010 | Samsung WF337AA Front Load Washer
Hi, i have front loading samsung washing machine,capacity 5.5 kgs. Its showing 3E error. could i know what it is and how can i get my machine working again???? thank you, Vaidehi
front loading samsung washing machine,capacity 5.5 kgs.This video will help you diagnose the fault on 3e error codes and the video will help you solve the problem
Sep 04, 2010 | Washing Machines
Washing Machines Logo
54 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
