Question about Dryers
My inglis model 43 00SQ is not heating properly. after it was moved, it now requires 3 or 4 cycles to dry a load of clothes.
    Problem Solver:
  • 11 Answers
There's a possibility that one leg of the 220v to the heating elements shook loose. Even a good manufacture can miss a properly tighten wire. It happens more that you realize. The other possiblity is that the rough treatment during the move could have caused a break in one of the heatiing elements. If you have voltmeter or have access to one, pull off the back panel that gives you access to the wiring, make sure the dryer is unplugged, and disconnect one of the leads to the elements. Now set your volt meter to the ohms position, kinda looks like a horeshoe, put one lead of the voltmeter to the detached wire and the other one to the wire that is still connnected. If the element is good it should show how many ohms or resistance the element has. It will show an amount, for this purpose it's unimportant, that means the element is good. If the reading is "0" that means the element is broken and neads to be replaced. Repeat with the other element.
There is another possibility that could have happened. During the move, part of the element may have come loose and is touching element somewhere in the middle. If this has happened it can be put back and your full heat will return. If it stays like that it will eventually burn out early.
Posted on Apr 09, 2011
Maytag Centennial Dryer (MEDC400VW) not drying properly
First of all, please make sure the vent is clear all the way through. Next the vent must be straight as possible. Next it can not be to long. People think that because they feel the air outside the vent is clear, not always true. The vent can be partially clogged. So make sure. Next, if the vent hose has sags or bows and even tight turns. It can accumulate the moisture in it from the drying proceed. If water has collected in the vent hose the clothes will not dry properly. If the vent is to long it can not dry properly either, the blower on the dryer can only move air so far. So the shorter the better. If all of these requirements are meet. Then, I would have to start checking the thermostats. I hope I have helped you. Please respond if you need further assistance.
Jan 29, 2014 | Maytag Dryers
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
My LG front loading dryer doesn't dry well
Check the exhaust vent when running and be sure there is a good flow of air. You may have to clean the exhaust pipes all the way through. Dryers require a good flow of air for proper operation.
Jan 10, 2012 | LG Dryers
Dryer is not working
The air heater and the blower requires to be tested/checked.
Apr 06, 2010 | Malber WD1000 Front Load Washer/Dryer
My GE dryer takes 3-4 times as long as I expect it to to dry my clothes. I've read that it should take about 45 minutes to dry a load but after the first cycle the clothes are still damp. It usually takes...
You have checked a lot already ... thanks for the comlete story. Often the questions here hurt for detail.
Are your clothes getting hot?
Two reasons for not getting dry ...
No heat
No air.
You need warm air (heat and air) going through your drier to achieve dryness.
Sounds like you have no heat. Are you properly setup on the control panel (you selected heat)? You have physically inspected the entire exhaust sustem including the outside vent, hose and lint trap - absolutely clear ...
check the heat my friend
Oct 20, 2009 | Dryers
LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
Sep 28, 2009 | Dryers
Forgot how to use
Doing a Load of Wash for Portable/ Kitchen Faucet
1) Make sure machine is set to Cold/Cold and never use Hot/Cold button (Hot/Cold is only for permanent hook-ups). Connect water hose to kitchen faucet. Turn on water to temperature of choice.
2) Load machine half to three-fourths full of clothes. (only half full is recommended if you intend to use the dry cycle right after the wash cycle. For half loads, push in the half-load button. )
3) Add detergent and fabric softener:
a. Liquid detergent into 2nd slot: only 1 tablespoon, 2 tablespoons maximum
b. Fabric softener into 3rd slot. this really helps in preventing wrinkles
(****NOTE: THE MOST COMMON AND MOST DAMAGING ERROR IN THE USE OF FRONT-LOADING MACHINES IS OVERSOAPING. oversoaping causes - pump failure, drain failure, etc. - none of
which are covered by the warranty. The only reason top
loaders use so much soap is because they use so much water and this dilutes the soap. Also, always use detergents that have an HE -- High Efficiency -- rating.)
4) Select Wash Cycle
Permanent Press is likely to be fine (32 minutes) as the USA has softer water than in Europe for which machine was originally designed. Hard water, as in Europe, means it requires more detergent and more washing motion than in the USA. Prewash and/or Superwash (53 minutes) might be preferred for dirtier clothes.
5) Select Spin Cycle
600 should be fine. A higher cycle means dryer clothes, perhaps more wrinkles, and certainly more noise. (Malber USA suggests 800-900 as the norm).
6) Make sure Spin cycle has cold water.
Faucet should be changed to cold water AFTER the initial fill even if you are not drying - all rinses should be in cold water for more complete removal of soap residue
If you use Dry Cycle
7) Select time for desired dry cycle. Make sure to change the faucet to cold water. If you do not want to use Dry cycle, select 0 minutes. Otherwise, use 120 minutes the first time until you can gauge what types of loads require how much drying time. Here's how the Dryer works: A heating element inside the washer heats up the load. During the dry cycle, as the cold water from the faucet circulates into the machine (in tubes, not mixed in with the load), it cools the steam and condenses it into liquid water which is pumped out.
After Wash & Dry
8) It takes approximately 90 seconds after the cycles are completely done before it allows you to open the door. Malber USA says it is due to safety requirement of UL. Who knows what UL security feature is for. Perhaps extra time to finish draining.
9) door slightly ajar to let the machine dry out. I have read postings that say the machine becomes smelly with mildew if you do not. Malber USA says this is true for all horizontal axis (front-loading) washers.
Most common complaints
1) Using too much detergent.
Front loader machines do not need so much water, and thus not so much detergent. Also USA water is softer than European water, for which the machine was originally designed, and that may explain why the detergent compartment is so big to hold more detergent. Soft water is easier to get suds. Damage is caused by suds. Suds migrate up the hot air duct during wash cycle and come to rest on the heating element. After repeated occurrences, suds (which are corrosive) will cause rusting and eventual failure of the heating element.
2) Dryer does not work, for several main reasons:
(thanks to Malber USA for points a and b)
a) the system may have overheated, tripping the safety thermal switch. This switch is located under the top of the machine and can be easily fixed by the consumer.
b) broken working thermostat. It is a relatively inexpensive repair to remove and replace this part and takes only about 10 minutes. It can be done by the consumer but it
is recommended that a qualified tech do the job.
c) Machine is too full and/or fabrics are too heavy.
Even though you can wash a maximum load of 11 lbs. of clothes, the manual suggests to dry no more than 7 lbs. of cotton clothes and 5 lbs. of heavy or extra large fabrics. Thats because the dryer works by heating up the clothes and then condensing the steam from the circulating air into liquid water which is pumped out. If the machine is filled too much or if the fabrics are too dense (e.g., jeans), the system cannot condense enough water and the clothes remain humid. Perhaps a second 2 hour dry cycle could work, but who wants to dry clothes for 4 hours.
d) Broken heating element
Seems that the heating element breaks after 2-3 years and needs to be replaced. And why is that? Most common reason for heating element failure is oversoaping. Suds migrate up the hot air duct during wash cycle and come to rest on the heating element. After repeated occurrences, suds (which are corrosive) will cause rusting and eventual failure of the heating element. But many people simply choose to not use the dryer rather than have it fixed.
Hope this works. Please be sure to rate me. thanks
Apr 17, 2008 | Malber WD1000 Front Load Washer/Dryer
Dryers Logo
43 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
