Question about Sharp AR-153E Copier
Changing Developer Is it hard to change the developer myself? What steps do I need to take?
  • Sharp Master
  • 2,794 Answers
Developer is supposed to be replaced by a technician because all of old developer has to be removed from the machine usually with a vaccum. You have to be very careful how to remove it off of the mag roller so you don't scratch it and you have to leave a finger on it so you don't mess up the polarity of it from the vaccum.
Then there are some service codes that need to be ran to initialize it. This way the toner/developer sensor can be calibrated.
If any step is missed it will effect the copy quality and the developer can be contaminated as well and will have to be replaced.
Posted on Aug 09, 2008
Xerox 3030 (engineering copier)-- "Toner Fault. Call for assistance" is on the little display screen. Can I easily fix this myself?
I expect you've probably got this fixed by now? In my experience people who own these machines want them working all the time. This error code problem can be over concentrated or under concentrated developer. Possibly needs developer changing, or the DEV sensor could be U/S. Good luck.
Dec 05, 2014 | Xerox Office Equipment & Supplies
Fix a xerox 6350DT
If you have a white stripe in only one color, then you might have a bad developer. Each color has its own developer
116-2008-00 Yellow
116-2009-00 Magenta
116-2010-00 Cyan
116-2011-00 Black
Changing the developer is not super easy. You'd have to remove the left cover, HV Power Supply board, then remove Image Unit and the Developer Frame, where all the Developers are mounted. Detach the feed hose for the Developer you want to change and release the Developer's 2 spring clips.
The attached photo shows old developers which have dead spots that would cause the missing stripes on prints.
Sep 12, 2014 | Xerox Phaser Office Equipment & Supplies
Add developer to dp-262
YOU DONT ADD DEVELOPER, YOU CHANGE IT LIKE CHANGING THE OIL IN YOUR CAR. THIS REALLY NEEDS TO BE DONE BY A TECHNICIAN BECAUSE ONCE YOU CHANGE THE DEVELOPER YOU NEED TO RESET THE COUNTER FOR IT AND DO A DENSITY ADJUSTMENT WHICH REQUIRES A SERVICE MANUAL. GOOD LUCK !
May 04, 2012 | Panasonic WORKiO DP-C262 Printer
Developer leakage while copying
after replace  developer you dont turn round the developer wheel left side. only right side.try this take out the developer and after re fill in to the developer unit. and u change the main charger unit also.
Feb 06, 2009 | Toshiba e-Studio 161 Copier Copier
Changing developer in afficio 450
Preform SP 2-801 then 2-805.That will do it!
Jan 21, 2009 | Office Equipment & Supplies
RIcoh MP-4500
It's probably happening because the cleaning blade on the drum needs to be changed or replaced.
Oct 25, 2008 | Office Equipment & Supplies
Thank you
The developer has to be changed by removing the old developer out with a vacuum cleaner. This includes removing it from the mag roller. It has to be applied evenly. Then a service program has to be ran to calibrate it. If any step is missed, the developer can be ruined and copy quality can get real bad.
The drum can be a messy project. The drum as well as the blade needs to be replaced.
Oct 06, 2008 | Gestetner Copier
How to change developer on Toshiba 2060 copier?
Changing the developer is a procedure for service technicians to do.  You might want to ask that question on copytechnet.com.  There are Toshiba service technicians on that can help you with that.
Sep 13, 2008 | Toshiba 2060 Copier
Changing Developer on E-Studio 150
The developer you need to purchase is 1620 , and the drum unit also the 1620, you can see this number in the toner catridge itself. or in the toner catridge box. Regd. the 161 you need to purchase the products name 1620 number and the concerned part like developer, drum, toner, some gears etc.
Aug 19, 2008 | Toshiba e-Studio 161 Copier Copier
Sharp ARC270, washed out color
I would have to say that they did it wrong or that you have a transfer or drum charge problem
Jul 08, 2008 | Sharp AR-C270 Color Copier
Sharp AR-153E Copier Logo
94 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
