Question about Fujitsu Siemens LOOX N560 Pocket PC
Hi, I forgotten my password for my N560 Pocket PC...Is there any way to reset the device or access it to change the password? Thanks
  • 3 Answers
OK so you have to perform hard reset.
You do this by pressing and holding the power and calender button, then pressing and releasing the reset button. You continue to hold the power and calender buttons for a few seconds. When you release the power and calender buttons the unit should beep and then reset.
Posted on Apr 09, 2011
  • MAHESH PATEL Apr 09, 2011
    .Where is the rest button on the N560?
    Ans:On the bottom to the left hand side of the sync/power connection (looking from the front).
I have forgotten Windows 8 password on Samsung Smart PC. How should I do to reset Windows 8 password? I'm in hurry to access Samsung Smart PC.
Samsung Smart PC, also called Samsung 700t, is installed with Windows 8 operational system.
  • 1. If you have created PIN code for Windows 8 logon, when the Windows system prompts you that your login password, you can change to select login Windows 8 with PIN code. It is the easiest way.
  • 2. If you don't have PIN code and another administrator account, you can think about third-party password recovery software. Here, I recommend you Windows Password Genius. And this is a software you just need USB device and accessible computer. I just learned from here Get access to Samsung 700t after Windows 8 password forgotten .
Jul 19, 2013 | Computers & Internet
Tip
Problem: You do not have access to change the settings in BIOS? . Have bought a...
There are two passwords in BIOS. One is start up password, the other isBIOS setting password. If you have forgotten the start up password thatmeans you cannot open computer at all. Then the first method is theonly thing you can do. Other methods can use to clear setting password.
==①:Motherboard Battery Discharge==
The common way toreset start up password is discharge Motherboard Battery. Most of thecurrent motherboard BIOS is using the button batteries to provideelectric power.That means if there is no electricity, the informationit contains will be lost. When it’s on power again, BIOS will set backto its original state, of course, there will be no BIOS passwords. Butyou will lose your setting at the same time.
What we need to dois to power off computer, open the computer box, and then unplug thepower plug of the computer to make sure that it is no electricity atall. Then locate the white silver button battery on the motherboard.Remove the battery carefully. Perhaps 30 seconds later, put back thebattery.
After put back the computer box then power on, thesystem will prompt “CMOS Checksum Error-Defaults Loaded”. That meansCMOS errors detected during inspections, had been included in thesystem default, BIOS password cracking success!
On somemotherboards, the battery is soldered to the motherboard, making itdifficult to remove. If this is the case, you have another alternative.Somewhere on the motherboard you should find a jumper that will clearthe BIOS password. If you have the motherboard documentation, you willknow where that jumper is. If not, the jumper may be labeled on themotherboard. If you are not fortunate enough for either of these to bethe case, you may be able to guess which jumper is the correct jumper.This jumper is usually standing alone near the battery. If you cannotlocate this jumper, you might short both of the points where thebattery connects to the motherboard.
==② : Backdoor BIOS Password==
Eachmotherboard manufacturer has set a backdoor password in order tofacilitate the provision of technical support. The backdoor password isa BIOS password that works, no matter what the user sets the BIOSpassword to. These passwords are typically used for testing andmaintenance. Manufacturers typically change the backdoor BIOS passwordsfrom time to time.
AMI Backdoor BIOS Passwords
Reported AMIbackdoor BIOS passwords include A.M.I., AAAMMMIII, AMI?SW , AMI_SW,BIOS, CONDO, HEWITT RAND, LKWPETER, MI, and PASSWORD.
Award Backdoor BIOS Passwords
Onereported Award backdoor BIOS password is eight spaces. Other reportedAward backdoor BIOS passwords include 01322222, 589589, 589721, 595595,598598 , ALFAROME, ALLY, ALLy, aLLY, aLLy, aPAf, award, AWARD PW, AWARDSW, AWARD?SW, AWARD_PW, AWARD_SW, AWKWARD, awkward, BIOSTAR, CONCAT,CONDO, Condo, condo, d8on, djonet, HLT, J256, J262, j262, j322, j332,J64, KDD, LKWPETER, Lkwpeter, PINT, pint, SER, SKY_FOX, SYXZ, syxz,TTPTHA, ZAAAADA, ZAAADA, ZBAAACA, and ZJAAADC.
Phoenix Backdoor BIOS Passwords
ReportedPhoenix BIOS backdoor passwords include BIOS, CMOS, phoenix, andPHOENIX. Backdoor BIOS Passwords from Other Manufacturers Reported BIOSbackdoor passwords for other manufacturers include:
ManufacturerBIOS Password
VOBIS&IBM merlin
Dell Dell
Biostar Biostar
Compaq Compaq
Enoxxo11nE
Epox central
Freetech PosterieI
Will iwill
Jetway spooml
Packard Bell bell9
QDI QDI
Siemens SKY_FOX
SOYO SY_MB
TMC BIGO
ToshibaToshiba
Remember that what you see listed may not be the actual backdoor BIOS password,this BIOS password may simply have the same checksum as the realbackdoor BIOS password. For Award BIOS, this checksum is stored atF000:EC60.
==③: Software Crack==
There are a lotsoftwares to test systems or start up password, but they need to run onWindows. So it is only used to reset BIOS setting password.
!BIOS will recover the BIOS password for most common BIOS versions, including IBM, American Megatrends Inc, Award and Phoenix.
CmosPwd will recover the BIOS password for the following BIOS versions:
•ACER/IBM BIOS
•AMI BIOS
•AMI WinBIOS 2.5
•Award 4.5x/4.6x/6.0
•Compaq (1992)
•Compaq (New version)
•IBM (PS/2, Activa, Thinkpad)
•Packard Bell
•Phoenix 1.00.09.AC0 (1994), a486 1.03, 1.04, 1.10 A03, 4.05 rev 1.02.943, 4.06 rev 1.13.1107
•Phoenix 4 release 6 (User)
•Gateway Solo - Phoenix 4.0 release 6
•Toshiba
•Zenith AMI
Ifall else fails, you might be going to lose some money for technician.But they will use these same methods, try hard by yourself.
on Jan 29, 2010 | Computers & Internet
I lost my net gear n150 cd and i want to change my password..
How to View or Change Your Wireless Network Password Symptoms:
  • You have lost or forgotten the password to your wireless network
  • You have lost or forgotten the password for the router, access point or other network device
  • You left the default password or used a weak password and someone has hijacked your network
Depending on the router, you can either view or reset the wireless network password (also referred to as the passphrase or security key) if you can log into the router. Some routers mask the wireless network password, so while you cannot recover it, you can enter and save a new password.
If you cannot log into your router because you have forgotten the router password or your network has been hijacked, please refer to "Lost or forgotten password for router or other device" below.
To view or reset a wireless network password:
  1. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  2. From the left-hand navigation menu of the Router Manager, select Set Up > Wireless Settings.
  3. From the center screen, select your encryption type from under the Security Options heading.
    • If the wireless network passphrase is visible, review it and use it to log devices onto your network.
    • If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
If you cannot log into your router:
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
NOTE: Restoring factory defaults on a device will erase any customizations you have made. You will lose any configurations saved to the device!
Sep 10, 2011 | NetGear WNA1100 WirelessN 150 USB Adapter...
I ahve forgotten my forgotten netgear password on WGR614 router. Please advise Thanks Tony
or
if there a small hole in the front or back of the router push a hair pin in to reset to factory settings
hope this helps
Dec 14, 2010 | NetGear WGR614 Router
| can't make hard reset
Push together three bottums Power,Calendar and Soft reset
Dec 28, 2009 | Fujitsu Siemens LOOX N560 Pocket PC
How do I make sure that my N560 PDA is 802.11g?
go to <findmyphone.com> and give your phone details to see your phone
Oct 17, 2009 | Fujitsu Siemens LOOX N560 Pocket PC
Forgot my password
Most of the NETGEAR devices have the following default username and password except ReadyNAS products and Fully Managed switches:
  • Username is always admin
  • Password is password or (for older devices) 1234
If you have changed the default password and have forgotten the password, you may need to reset the NETGEAR device to factory default settings.
Write down configuration information such as IP addresses, security keys, opened ports and services, etc., that you modified. (The default username is admin and the password is either password or 1234. Try these before resetting the router.)
  1. Press the reset button on the back until the test light blinks. This takes about 10 seconds. (To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
  2. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password. If the router configuration was not cleared, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 26, 2009 | NetGear RangeMax WPN824 Router
Battery replacement pocket loox n560
If you want to buy the battery for your Fujitsu N560, kindly check these links and it might help:
http://cgi.ebay.com.sg/Extended-Battery-Loox-N560-N560c-N560e-N560p_W0QQitemZ330287493568QQihZ014QQcategoryZ75446QQcmdZViewItem
http://www.lelong.com.my/Auc/List/2009-06DeSale35361186_AUCTION_--Best-Price-Gtoracer1-Siemens-Look-400-410-420-N520-N560-Battery.htm
http://shop.eten.hu/mugen-power-3000mah-extended-battery-for-fujitsu-loox-n520-n560-with-battery-door-p-167.html
Hope it helps and have a great day!
Jun 10, 2009 | Fujitsu Siemens LOOX N560 Pocket PC
Fujitsu Siemens LOOX N560 Pocket PC Logo
714 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Lee Durbin
Lee Durbin
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
