Question about Ryobi Garden
Ryobi trimmer safety guard, got damaged where can I get a replacemnt please
  • Roy Cagle
    Roy Cagle Apr 09, 2011
    Many, many online parts jobbers carry Ryobi parts. I can't look up YOUR part without knowing the exact model number of your trimmer. Please repost the model number and I will continue to help. I will send you links to various jobbers who carry and sell the guard you need, On a side note, i know for a fact that Home Depot stocks and sells parts for Ryobi trimmers. They may even have your guard. Can't hurt to check. They have spark plugs, filter, blades, string and fuel line kits even. Repost and we will reply.
2 Suggested Answers
AlmostBob
  • 550 Answers
SOURCE: Gas/oil mix ratio for Ryobi Trimmer
50:1
Posted on Oct 10, 2008
Ho to take side cover of chain saw model rcs4246b ryobi
Remove the large nut(s) that holds the bar tight. There may be a screw at the rear of the cover too. Ensure the safety brake(connected to the hand-guard) is not engaged.(Hand guard needs to be pulled back towards motor).
Oct 15, 2016 | Ryobi Garden
Attach Worx Trimmer Safety Guard
check for a hole in the head or shaft that the screw will be positioned in when fully screwed in
Jul 31, 2016 | Worx Garden
How to I fix a Ryobi Miter Saw Blade Guard which is not retracting?
Sound like a piece of wood may have driven the arm up which operates the guard, if you remove the screws holding the guard support plate to the saw you should be able to remove the guard assembly, the arm can then be re-bent down on the end so that it meets the angled plate on the back of the guard and pushes the guard through the entire stroke, the other reason could be a damaged guard, when the centre screw is removed the plates can be removed from the guard, note how the spring and plates are assembled prior to dismantling, check the inside centre of the perspex guard and ensure the 4 protrusions which engage with the drive plate haven't broken off, if sow the guard will need to be replaced, this may now be an obsolete part , if so purchase a Makita guard as they are the same
Jul 18, 2015 | Ryobi 10 In Miter Saw With Laser
Excessive vibration in Ryobi RY30120 trimmer
the center bushings that holds the shaft center are worn and need to change. this damage is caused bu using a to heavy nylon and because of the damaged you will get vibration on all attachments used
Aug 03, 2012 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How to put the worx gt 18v trimmer safety guard on
The trimmer comes with the screw "pre-inserted" on the TOP side of the guard. After 30 frustrating minutes--I realized it actually screws in to the BOTTOM side of the guard (beside the trimmer head.) Must've been designed by a Man! (ha ha) :)
May 19, 2012 | Garden
To get the blade guard on a Ryobi circular saw to stay up.
Blade guards are spring loaded so they will not stay up unless you hold it up manually
May 05, 2010 | Ryobi 18v One+ Circular Saw P501 18 Volt V...
Trimer buing Question
Double position trimmers For extended reach while on the ground, a double position trimmer avoids you having to climb up high by allowing you to adjust the handle into a right angle to the blades for a level cut across the top of the hedge. Clippings collector As you trim your hedge, collect those stray cuttings in a clippings collector for a neater finish. Automatic cut out An important safety feature, this automatically switches off the hedge trimmer once the trigger is released. Hand guard For reassuring safety, a hand guard will protect you from the moving blades and from falling cuttings as you work.
Aug 27, 2008 | Corona Hedge Shear 10 1/2" Blade Aluminum...
Ryobi string trimmer 32.1 what do mix gas and oil or just gas?
Ryobi trimmers I have had use a 32:1 oil mix. Just pick up a little bottle of Ryobi 2-cycle oil and read it to see that it will give a 32:1 mix in a gallon of gas. Pour it into a gallon of gas, and maybe a little fuel stabilizer too, shake it up and you should be good for the season.
May 28, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
76 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
