Our small format stereo centrios 1315050 worked perfectly before I unplugged the device to paint the room. When I set up the device again r days later, the power comes on and all the functions appear to work but NO SOUND ( set to 10 on Volume) . I reconnected the spkrs and reset the battery & clock. Still no sound.
  • 76 Answers
Check the fuses in the receivers
Posted on Apr 09, 2011
My pro form elliptical is no longer getting power using the ac adapter. Unplugged it to paint the room. Now there is no power. Any help?
1) Measure the outlet plug with another device such a lamp desk 115Vca.
2)If there are voltage with the lamp , the problem is with the fuse+c.breaker in your treadmill.
3)If there are NOT voltage with the lamp, the problem is c.breaker from your house Reset.
4) If after you reset there are NOT voltage again, the problem is the wires had been isolated with the paint, You must take out the paint, for to conduct the electricity to the outlet, and try again with the lamp desk
see the diagram.
God bless you
May 11, 2012 | Proform Exercise & Fitness
Wake up with the radio is always set to level 19... I would like to set my radio alarm with a lower volume... my centrios is a Speed to Sound CENTRIOS IPOD/IPHONE CLOCK RADIO I will return this
We also have this problem. Found this info in the product's Q&A on the website: http://answers.thesource.ca/answers/9026/product/1218694/centrios-centrios-ipod-iphone-clock-radio-white-questions-answers/questions.htm
"Ok. there is a way that you can LOWER the wakeup radio volume. turn on the radio (forget about the alarm right now) and go to the station that you want. when you get to the station, you should be able to press the 'skip/fast forward' button on the remote. when you do this, number 5 should show up beside the station #. When you do this, it lowers the overall volume of every volume level, so now level 19 is equal to volume level 9/10, which for me is loud enough to wake me, but not give me a heart attack! so, now when the alarm goes of, the volume is a lot lower. BUT if you want to wake up to your ipod, this method will NOT work, it will still be up at level 19. so when you turn on your ipod, it will be really LOUD. again, this only works with the radio."
Also if you are waking to ipod and not radio this was in the reviews:
"Fooled with it for a bit and discovered that you have to turn down the volume of the iPod first before putting it on the dock. We've tried it a few times just to make sure and it worked every time!!"
Still not a perfect solution, but a great improvement. Hope this helps someone.
Jan 08, 2011 | Centrios Classic Flip Clock
Hi, We just purchased a vicks warm mist humidifier. We used it for two nights in my daughter's bedroom...we then noticed a sticky residue over sections of the wall as well as crackling paint? Is this...
is it possible that you have the mist turned up too high? If the room is very small, the high setting could be providing too much humidity to the room. I'm thinking that the paint crackled as the humidity climbed.
Nov 04, 2010 | Vicks Warm Mist V745A 1 Gallon Humidifier
My dehumidifier is frozen solid
Unplug it ... let it defrost.
Set it to a higher % humidity and make sure the fan is on its fastest speed. If you can set it not run continually (a selection option), do that. Also, set a small fan close by to move more air around the machine. If you have the option, put a hose on the collection device to drain to a sewer.
As your space starts to dry out, set the humidity setting to a lower number. This may take a week or more.
I believe perfect humidity is slightly above 50% - no need to try to get to 40% except in unusual circumstances. If that is the case, get a second device. Or, if your space is large, you may want to add a second device.
I hope this info helps you and your problem is solved.
thanks for using Fixya.com
a
Oct 25, 2009 | Danby DDR556RH Dehumidifier
My daughter dropped creativ zen mosaic in the fish tank. at first in worked a bit now its completely dead
remove battery, remove any flash-cards, unscrew open it , let it rest in warm, well ventilated place (on top of a cup board or so, do not expose to direct sunlight and don't place it near a heating or other magnetic fields such as stereo speakers or tv-set,
let it restand dry for one day at least, put it together again, put in a fresh battery:
keep your fingers crossed and turn it on!
as the files on the device may have gone, hook it up to a pc, if it is recognized by windows: good sign,
format the player, copy one test.mp3 to it, unplug and hit play!
good luck
Jun 18, 2009 | Audio Players & Recorders
Heater shuts off as soon as the room is warm
I take it once the temp is set to 71, and the ambient temp reaches 68 or so, it shuts off, never to come on again?
If that is true the thermostat in the unit is damaged, worn out or in need or replacement, but try a couple tricks.
First, if there are access panels to clean, clean it per the manual, it could be that a dirty filter or air inlet is confusing the thermostat.
Next, unplug the unit for at least 5 minutes, try it again.
Next set the unit on it's highest temp and blower setting, let it rip for 20 minutes, shut it down, unplug and remain unplugged for 5 minutes.
Next set the unit at 71 HIGH MODE.
see if we have a mode switch problem or thermostat if it works on high mode, it is not the thermostat, but I imagine it is, but I am curious as to if it once goes off, it never again comes back on?
Will
Dec 01, 2008 | Bionaire BCH-4138 Ceramic Compact Heater
White lines when you take photos in light, but perfect in the dark
The problem lies in you camera's CCD unit which is located on the back of the lens held on be 3 small screws it could also be a setting in the camera's menu try going into the menu and reseting the camera to default it works some times if that does not work than you need the ccd replaced pretty easy fix I fixed 1 with the same problem about two weeks ago for someone it happens I hope this helps you out.
Jan 30, 2008 | Casio EXILIM EX-Z1000 Digital Camera
Will not power on
you have damged the micro chip when you unpluged your set it is possible that a static charge caused it have cheked out by tech.as you cannot do it by yourself if you are not a qualified tech.
Mar 10, 2007 | Centrios EDW8020 DVD Recorder
64 people viewed this question
 Grubhead
Grubhead
