Question about Canon PIXMA MP190 All-In-One InkJet Printer
My printer(canon pixma mp190) keeps telling me that there is a paper jam, but i checked and there is no paper jammed, is it broken?
  • 310 Answers
If i not paper in the printer,you must unzip the printer,the paper sensor is skipped.The paper sensor is under the scanner in the middle of printer.If the sensor id broken you need to replace,if the sensor is skipped try to put in the rigth position.Good luck!!!
Posted on Apr 09, 2011
  • kerlifan1
    kerlifan1 Mar 05, 2012
    im having the same problem what does the paper sensor look like??
Alarm light blinking and it keep showing E3,when i want to print,it keep asking me to remove the jammed paper,but i've checked 101 times!! no jammed paper
If the paper out tray is closed or not fully opened, then open it fully.
If that doesn't fix it, then the printer may believe that paper is jammed. You've already checked for jammed paper, so reload the paper supply and press the BLACK or COLOR button.
If that doesn't work, then disconnect the power for a few minutes and reconnect.
If that still doesn't work, there is probably a bad paper sensor or controller board.
Is your printer still under warranty?
Jul 13, 2014 | Canon PIXMA MP190 All-In-One InkJet...
Canon mp190 printer says there is no paper when there is?
1- take out all paper in tray, is there one that started to go up? \
2-turn printer aound, look at the back there should be a door open, either by squeezing tabs or turning knob.
is there a paper there?
3-did you tear paper when it had a paper jam? there might be a piece stuck on a sensor.
There are actuators that spring back when a paper passes over them, telling the machine if paper is there or not, and for a determined time.
9_6_2012_6_15_36_pm.jpg there should be no more than 3. look for them, see if they move freely and spring back,
Sep 06, 2012 | Canon PIXMA MP190 All-In-One InkJet...
My daugher is using Canon MP190, and there is a blink error message E3, which according to the online manual, it is due to a paper jam. We checked, and there is no paper left in the printer, but the error...
Hello, Welcome to FixYa!
E3 error is mostly because of paper jam. their may be small bit paper jam in side
There are some "micro-sensors" that detect a paper jam. There will be tiny piece of paper, or a lump of dust, inside those sensors, thus "tripping" the sensor and saying you paper jam.
To solve it
Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
If you become sure that now really there is no paper, dust or foreign objects then
Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air.
If still problem exist then best & final option is to just contact to any Canon service provider
Anymore help regarding the issue, I am here to help
Thank you for using FixYa!
Concerned: Angel Bird
Apr 10, 2011 | Canon PIXMA MP190 All-In-One InkJet...
Paper jammed
maybe your printer roller broken.. you can check the sensor too....
May 27, 2010 | Canon PIXMA MP190 All-In-One InkJet...
Small paper jam
Unplug the power cord and open the cover and remove all the cartridge and try to look I inside around the roller and try to manually roll the roller and if you can see the paper try to pull is slowly.
Have a nice day and do not forget to rate please...!
Feb 04, 2010 | Canon PIXMA MP190 All-In-One InkJet...
Canon MP470 keeps saying "paper jammed"
I had the same problem for DAYS and there was no paper jammed at all. I went to the cannon site as a last ditch effort & the solution below fixed it. Just clean the rollers and the link tells you how. Good luck!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403
Jan 04, 2010 | Canon PIXMA MP470 All-in-One Printer
I am having trouble loading paper into my Canon MP190 Printer?
Try loading less paper AND try this trick:
Holde the stack of paper you are going to load with both hands... grip tight with the right hand and "bend" the paper like an arch. Then grip tight with the left hand, loosed grip with right, and "bend" the paper like a valley. Repeat this a few times to quickly seperate the individual pages so they don't stick together and thus jam in the printer!
Hope this helps!
-- RT
Sep 01, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Pixma mp750
it seems the lever for the paper jam is having problem you have to open the printer and check for any broken or dislodge part.
Aug 18, 2008 | Canon PIXMA MP750 All-In-One InkJet...
Canon PIXMA MP190 All-In-One InkJet Printer Logo
746 people viewed this question
old marine
old marine
