Error code 04 is displayed on the machine, a Bosch Nexxt Washing Machine 300 series, How can I resolve this? The machine is slightly over 1 year old, and the laundry is still inside with some water undrained. The door will not open on this front loading machine
    Brigadier General:
  • 6,277 Answers
Bosch 'F04' is a problem with draining.
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
Please score this solution accordingly.
Thanks and good luck!
John C
Posted on Apr 09, 2011
Is there a way to reset the computer my bosch 300 nexxt series washer?
turn off THE POWER by c. breaker, wait by 45 seconds, and turn ON again and try it.
God bless you
Jul 10, 2013 | Bosch Nexxt 300 Series WFMC2201UC
D19 error code
I have checked the fault codes and there does not appear to be a D19 fault, can you confirm fault code and full ENr (from rating plate on machine) pls
Mar 24, 2013 | Bosch Nexxt 300 Series WFMC2201UC
Is there a reset button on a bosch 300 series washing machine
turn off the power to the unit for 45 min, that resets it
Dec 05, 2012 | Bosch Nexxt 300 Series WFMC2201UC
The error code Sud is on, what does that mean? How do I fix it?
That's because there was too much soap put into the machine . Try to run empty cycles ( 1 towel only , no soap) until the over sudsing is gone.
Mar 15, 2011 | Bosch Nexxt 300 Series WFMC2201UC
I have a bosch nexxt 300 series washing machine. The problem is it had beeped code E04 the hoses were somewhat dirty and i cleaned those,but now the pump doesnt seem to be running and its getting hot. ...
bosch nexxt 300 series washing machine This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Dec 31, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Error code E02 on washing machine-3 beeps -machine stops cycle
you should buy a new one..
check this one..
http://www.washingmachineadvisor.com/
Jan 13, 2010 | Bosch Nexxt 300 Series WFMC2201UC
Hello! My Bosch Nexxt series 300 washing machine is showing a E: 13 error and won't open. I have tried unplugging it but that doesn't seem to help.
e 13 is a door lock error if you are lucky you may have a manual release check where filter is for a red pull release this mechanically activates the door to retrieve trapped washing,if not lock will need replacing engineer visit unfortunately.
Aug 05, 2009 | Bosch Nexxt 300 Series WFMC2201UC
My brand new Bosch is not draining and is showing E:13 error code
Put the washer on cold and run "TWO" cycles. There is too much soap or fabric softner.
Mar 28, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Washing Machines Logo
138 people viewed this question
Top Washing Machines Experts
